Question about Garden
I have a 4020ps ingersoll was running great then died while mowing, starter would not ingauge replace starter tractor ran about 20 minutes died and had no power from ign. switch replaced switch now have power to lights no power to starter blue wire. can't find where there would be a safety if you have any ideas pleas help e-mail me at vtmathieu@cox.net if cost involved let me know need tractor to finish mowing 2 acres. dealer no longer around thanks vic mathieu
5 Suggested Answers
SOURCE: LTX1000 42" 18HP Kohler - Blowing fuse after 2-4 min mowing.
i hav a 18hp ohv eng. back fires and gas is coming out of muffler.
Posted on Jul 18, 2009
wilsodfarm
  • 986 Answers
SOURCE: 3020 carburetor ? john deere gas tractor, 3020
those carbs are real simple you will not have any problem
Posted on Jul 29, 2009
kamakani
  • 104 Answers
SOURCE: Murray Lawn Tractor Model 42576x92A will not start...no spark?
http://www.partsandservice.com/bin/ipl.cgi
I found a wiring diagram that I hope helps you out.
  • 146 Answers
SOURCE: John Deere 0-turn serpentine belt keeps coming off.
Make sure the belt is under good tension -- shouldn't be able to deflect the belt more than 1/2 inch or so with firm thumb pressure. The belt could be worn and stretched, if so, replace. With the belt off check every spindle and pulley to see that they turn freely. Check that idler pulleys are level to deck and not wobbly -- a sign of worn bushings that cause them to tilt, and that would throw the belt off. The bushings are inexpensive to replace. Good luck!
Posted on Jun 12, 2010
Engine starts runs well but after 45 minutes or so will die . I can choke as it starts to die and engine will continue running.When it dies will restart easily.Ihave replaced gas filter ,cleaned tank,new...
Carb. needs to be rebuilt. If your choking the engine it to keep the alive and you've cleaned and replaced everything else, I would recommend carb. overhaul.
Sep 23, 2013 | Garden
I have a cub cadet 1550, Blew fuse and wont disengage from gear
You have a bad wire which rubbed on the plastic housing to the engine block near the starter mower which causes a short and blows the fuse. I have the same tractor and this happened to mine also. The wire is red.
Jul 28, 2009 | Cub Cadet Garden
sounds as though you are on the right track
but be sure to check the wiring directly from the electric clutch on the front of the motor back to the switch
a wire could be pinched in the frame and shorting out intermittingly
look around and find those wires and move them around and look for chaffing and tightness
and what you could also do is to unhook the clutch at the connection to it at the front of the motor and engage switch and ride around and see if fuse blows and if not you may have an electric clutch issue
Jun 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Sears lawn tractor. While mowing, ran over a
the branch probably got cought in the belt that runs the rearend it may have caused it to come off check the drive belt
Jun 06, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Mower will not start
you could have water in gas,look in the gas tank for any bubbles floating on bottom of tank this is water empty gas from tank and remove carburetor bowl too remove water from it .
May 13, 2009 | Garden
Craftsman 19hp riding mower wont stay running
The carb jets are partially clogged and needs to be cleaned.
Apr 04, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
78 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
