Question about LG 37LG30 37 in. LCD HDTV
LG 37" LCD TV Sound Fault
Hi, my 2 year old 37" LCD LG TV has developed an intermitent sound fault. The sound just goes off and the only way to get it back on is to power off the TV and leave it for varying lengths of time before powering it up again.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Please check the audio with a DVD player or cable box. Also try using component cables if using a RCA component cable or vice versa. Check that all of the cables are plugged into the back of the TV & MUTE button is not pressed. Do a hard reset by unplugging the power cord for more than 4 hours and power it again, then go into the on-screen-menu and make sure the sap is off and stereo in on. Also try audio from Phone and 3.5mm jacks (if equipped). If this all didn't resolves the issue then it is an Audio IC or bad speakers/speaker connection. Please do accept the solution if the issue is resolved else revert for further assistance.
Thanks
Rylee
Posted on May 15, 2010
  • yan_bowie May 17, 2010
    I have checked all the connections (only one HDI Cable from TV to Sky Box) and done the hard reset (powered off over night) but the fault is still there. It works ok but the longer the tv is on the more likely the sound will just go off. Sometimes turning it off and leaving it for a while works for a while but it soon returns. Is it likely to be related to the tv heating up and a speaker connection/card going wrong.
    Regards
    Yan
  • Rylee Smith
    Rylee Smith May 17, 2010
    If you have already checked everything else then you are right it can be either of these things: a bad HDMI Cable, an Audio IC and/or a bad A/V Board. Please do accept the solution if the issue is resolved else revert for further assistance.
    Thanks
    Rylee
LCD TV - INTERMITANT BLUE SCREEN
Fault in the main board. You have to replace the main board. As it's have SMD components is would be difficult to repair.
If you wish to get some more details then check the following link.
http://electro-medical.blogspot.com/
Jul 13, 2016 | LG 37LC7D 37 in. LCD HDTV
My 42" Sanyo LCD TV which is 4 years old no longer
This is not a user repairable fault. Should be checked from its main power regulator board, and is a skilled work. Actually this is a repairable fault, but can do only by any technicain.
Jul 11, 2013 | Televison & Video
I purchased an Sony Bravia LCD 26 inch of KLV S200A series 3 years back. The LCD has now started developing problems like automatically the power goes off when any particular channel is being viewed and...
You have intermitant problems which may be caused by contact resistance or circuit overheating.After it cooled down the tv starts again. Leave TV on standby at all times.
Jan 03, 2011 | Sony BRAVIA KLV26S200 26 in. LCD TV
There is a constant buzzing sound coming from the back of my lg 37" lcd i returned the last one for the same fault and the replacement is the same any clues?
The sound is generated by the power source - it doesn't run smoothly because either it's defective (but 2 tv with the exact same defect one after the other is quite improbable) or you have a very bad mains power line, filled with interferences. Plug the tv thru a mains filter then check the voltage - if it's at 120 volts as it should and the sound is still there then return this tv also - you are really one of the unluckiest men alive.
Sep 07, 2010 | LG 37LC7D 37 in. LCD HDTV
Hi I have a Toshiba Regza 37" LCD it seems to have developed a fault ie it keeps swapping to the scart channels as if someone is pressing the remote constantly, it seems to do it intermiterly? I have...
Hi i have the exact same problem and have done for about a month now, If you find a solution please could you email me.
smcglinchey4@hotmail.co.uk
Starting to get a bit bored of no TV now!!
Many Thanks, Stuart
Jul 02, 2010 | Toshiba Regza 32LV67U 32 in. LCD HDTV
I have an LG 42" LCD tv with blurred image on half the screen
lg 42 in lcd tv power button blinks nine times before staying on and has sound but no picture
Feb 04, 2010 | LG 42LC2D 42 in. LCD HDTV
Crackling from set volume button makes no
Sounds like a loose connection with one of the audio/video cables inside the TV or a short. Contact a qualified service technician to do the fix.
Jan 25, 2010 | LG 32LX1D 32 in. LCD Television
LG 37LG30 HDMI no sound problem
This is more probably a software fault within the TV. They need instructions for HDMI inputs & a no sound is a related fault. I would get in touch with your dealer to arrange the TV to be updated to cure this problem. Hope this helps.
Apr 11, 2009 | LG 37LG30 37 in. LCD HDTV
37" lg television
sounds like u have a dead solder joint or loose connector. poor workmanship LG (formerly known as GOLDSTAR is known for)
Dec 05, 2008 | LG 37LC7D 37 in. LCD HDTV
LG 37LG30 37 in. LCD HDTV Logo
48 people viewed this question
Computer Repairing
Computer Repairing
