DEH-P7900 BT US model. Isthere any way I could change the tuner frequency to european one. Thanks.
  • 2 more comments
  • fisherman117 Mar 31, 2008
    As you described it the tuning in my DEH-P7900BT is in odd increments, but most of the FM stations in Erope are in even. my question was could i press any combination of buttons to change it from odd to even frequences( 95 instead of 95.1)
    Thanks for that reply, so I see there is no easy solution for my problem. I understand I will have to live with it. But the idea with new firmware was good. Is ther any place I could get it. The Pioneer doesn't provide any, they say in FAQ that nothing can be done. So I should have thought twice before buying.
  • Jerry Greenberg
    Jerry Greenberg May 31, 2012
    All of these digital type tuners (receivers) use a uPC to control them. The tuning is done using what is called a pre-scaler circuit that drives what in basic terms is known as a veractor type circuit. The uPC drives a chip or decrete type circuit (depending on particular design) that makes an extremely stable DC type control ramp voltage source. This voltage source controled by the uPC referenced from the user tuning, biases the veractor device (circuit).
    The veractor circuit controls the tuned circuits (RCL) network that consists of the resistive, capacitave, and inductivce (reactive) type circuits that do the actual tuning and receiving. The front end design with the RCL network also has frequency range limitations. I know the frequency band in EU is also slightly different than in NA. Even if you found a way to make the tuner work in the EU standard, there would be an issue with the frequency band range.
    Going back to the uPC, this microcontroler works on software, which is refered to as firmware. Manufactures like Pioneer, Sony, Panasonic, and etc, use prepietary type software design. Most of their chip devices like espcially the uPC are custom designed for them and their particular design requirment. Therefore I have my doubts you would ever be able to find another firmware that can be loaded in to your tuner.
    And... If in the case you wanted to access the internal firmware (software) in your tuner, you would need access to the uPC write port, which is not provided on the circuit board of any of these types of consumer devices that I know of. Some of the very high end audiofile type receivers have factory level access only.
    When the tuner uPC's and chipsets are manufactured, the firmware is burned in during the manfacture process. Most of the time, it is a one way burnin. It cannot be erased and re-written. This keeps the cost down, and also limits people from modifying the device performance.
    Jerry G.
Hola tengo el mismo estereo que ustedes, el deh p7900bt pero el mio no tiene usb atras, mas alla de que el manual dice usb opcional. e visto algunos modelos parecidos que sale por detras un cable con el usb hembra, pero el mio ni eso. me faltara un cable? o lleva un cable que se compra aparte? porque nadie me sabe decir
Posted on Nov 04, 2014
    Brigadier General:
  • 6,966 Answers
I believe I understand your concern.
To my knowledge, there are two (2) possible ways this can be done:
1. the easiest. offset/de-tune the tuner of the DEH-P7900. Specifically you would need a tech who is willing to adjust the VCO of the PLL. In effect the end result would be that the display would be 95.1 but internally it would be 95.0. This could be done using a frequency counter and an FM signal generator. An un-technical workaround would be to do just that in UK and whoever is going to perform the de-tuning would simply wing it by using his ear and the "stereo" indicator.
2. Technically correct but the most difficult. You need to reprogram the firmware of the DEH-P7900. The FM tuning increment must be adjusted from whatever its current setting is down to 1. In effect what would happen is the tuner will scan/select in steps of 1 or lower or whatever is applicatble in your region. Basically it will make the radio tune from 95.1 to 95.2 and so on not jumping 95.1 to 95.3. A 0.5 increment will make it go 95.1, 95.15, 95.2, 95.25 and so on.
In some versions this could be user programmable as part of the setup menu.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 31, 2008
  • 1 more comment
  • Louie  Role
    Louie Role Mar 31, 2008
    Hi again,
    If I may add, the FM radio preset stations in:
    United States from 88.1 MHz to 107.9 MHz in 200 kHz steps
    United Kingdom from 87.5 MHz to 108.0 MHz in 100 kHz steps
    hence making the tuning steps (FM tuning increment) go down from 2 to 1 (KHz) should make the DEH-P7900 UK FM stations compatible.
  • Louie  Role
    This might interest you. It's as Pioneer DEH-P7900UB, and I get the impression that it is already preset for European market
  • Louie  Role
    Louie Role Apr 01, 2008
    A variation of the firmware option
    It is also very possible to trick the existing firmware but that would need a tech who is very capable of component level modifications (in the logic circuitry)
    By chance would the Pioneer DEH-P7900BT US version be operated in UK? If yes, one of our resident expert, pauldonp is based there and I can send him details. One of his areas of specialization is car audio.
    Based on your last post "...will have to live with it..." then if for any reason it still doesn't work after Paul worked on it, you loose nothing. But if it succeeds, then it is your gain.
    Pls comment/post back if this is agreeable with you that I can initiate discussion with Paul.
    Cheers.
    Genius:
  • 1,226 Answers
Hello.
As i read in the forum could be calibrated but maybe the expert in radio can calibrate that. maybe this link can help you. http://www.cadillacforums.com/forums/cadillac-escalade-ext-esv-forum-1999/93999-changing-fm-tuner-frequency-us-standard.html
melnavz
  • 813 Answers
This is a US model and will tune most AM/FM stations in the UK/Europe. The FM broadcast band is 87.8 to 108.0 MHz. so it will not pick up any FM stations outside this range. Also, the tuning is in odd increments (such as 96.1, 96.3, 96.5, etc.) so some stations with even frequencies will be slightly distorted, depending on the power of the signal the station generates.
u have change its bit u have a proper knowlge of electronics componet of ur reciver so u have do this chage in ur radio trimmers its & coil of antina its change ur redio frequncy
i m not gudie u do it ur self in this problem suess reatio is 10%
if problem is not solve then u have to bye new readio set
  • 818 Answers
What is the radio FM Frequency range in my tuner?
All of the Pioneer head unit tuner for FM Frequency use range from 87.9MHz to 107.9MHz
Sergio
Posted on Mar 30, 2008
  • 4,102 Answers
The DEH-P7900BT is almost identical to the DEH-P85BT sold in Europe.
I found this bit of info for you but ill keep looking and let you know what i find out.
Also have you tried it in europe to see if it does work or not let me know ok
  • paul proctor Apr 01, 2008
    Hi fisherman here is a list of our stations in uk compare these to your frequency you can get on yours and tell me what the nearest frequency you get is ok
    Radio 1 is 97.9
    Brmb is 96.4
    Galaxy 102.2
    Heart fm 105.7
    please let me know the closest freq you can get to these stations are based on your stereo ok
    Hi check the freq and see how close you can get then ill compare it to where i am in uk and let you know ok
Clarion cz309 radio frequency step
I would say no, because Anything made in America Stays in america, its just how it works. Try calling their company and asking them.
Apr 07, 2010 | Clarion CZ209 Car CD/ MP3 Player
European Wiring harness not compatible with US bought Stereo
This is not as straightforward as you may think.
You can certainly buy a generic adapter harness which will plug into the European DIN harness and then provide you with the bare wire tails to patch into. You may even find one which plugs directly into the rear of your head unit without the need for patching.
But you'll find that your head unit still won't work properly as the US uses a different FM channel range to Europe (US frequencies are odd, e.g.102.7, Euro frequencies are even e.g.102.8). The channel spacing is also different.
The radio itself cannot be converted, but you may be able to buy an external converter. It won't be cheap, and the head unit display will still always show the wrong frequencies. Channel changing may have to be done directly on the adapter and not on the head unit as I don't think that the DEH-P3000 has any way to communicate a request for a channel change to any external device and this also means that radio channel presetting may be impractical/impossible.
Considering that the DEH-P3000 is an obsolete unit and nothing special to begin with you can buy a brand new Euro-spec head unit of equivalent quality for less than the cost of adapting your unit and it will work correctly without any awkward Heath Robinson adaptations.
Sell your Pioneer back to the USA where it belongs or bin it as it's useless over here.
Jan 24, 2010 | Pioneer DEH-P3000 CD Player
Converting built in infinity radio tuner to get european stations
Hi Barak, I have not seen an easy adjustment on any car stereo for converting the frequencies. The Crossfire stereo is manufactured by Becker. Try Becker of North America in Upper Saddle River NJ.
Nov 13, 2008 | 2006 Chrysler Crossfire
Region problem
Try this for the tuner fix. Turn unit on.Hold down (volume down and SRC )buttons and unit will power off.Keeping them in also press and then release the reset button(bottom right hand side) .Release the other 2 buttons and unit should now restart with 50khz fm spacing and 9khz am spacing.If you find out how to change region code,Post It
Jun 09, 2008 | Kenwood DNX7100 Car Video Player
Tuning steps/increments
Hi Benimur thanks,
What kind of mod would you be talking about and also the problem would be what part of uk hes going to that is if it is the uk hes planing on going.
Adjusting the firmware would change the frequency but is their that firmware out their for his make/model
Also what ive tried on my own stereos car and house is that fishermans frequence is like you say its 95.1 and 95.3 so its going up in .2 in odd incremants so what i tried on my stereos is the nearest frequency possible for uk stations ok.
So in uk one of our main stations is
radio 1 at 97.9 this station would be spot on
and brmb at 96.4
so if its going up in .2 incremants then 96.4 closest one on his would be 96.3 or 96.5 witch i tried and you can get this station and wont notice any bad signal even at high volume.
So for the range to be out by only .1 then i cant see their being a problem.
Even on DAB radios using manual tune instead of auto still picks up the stations with no problems.
So if your sure his stereo goes up in 95.1 and 95.3 then he should have no problems as the output from the stations is high.
Also radio 1 our main station in uk is 97.9 so his should pick up this station with no problems at all.
But please tell me if im wrong about his frequency as ive only worked with uk based systems witch are the same as europe .
Do you understand what im trying to get across.
If you think its going to cause loads of problems by being out by .1 then let me know.
If you think it wouldnt be a major problem then also let me know.
Ill wait till i here from you before i get back to fisherman as i dont want to give him information that would be no use to him ok.
Please let me know either way ok thanks and speak soon
Apr 01, 2008 | Car Audio & Video
Kenwood Tuner Frequency Steps Problem
MichaelBlackDo you know where I can find the remote key combination to do the same with KDC-MP538U? (To transform it to the European system)
Thanks in advance!
Jan 13, 2008 | Kenwood 2005 KDC-MP5028 CD/MP3...
Odd frequency
Hey, all you have to do is to turn off your radio and press on the audio botton until you can adjust your clock, then press again until you see "FM 100" on the display, now push the ">" botton to change it to "FM 50" and finaly another long press on the audio to wrap up.. and it's done.
Feb 15, 2006 | Pioneer DEH-245 CD Changer
338 people viewed this question
 Grubhead
Grubhead
