Question about E-Machines eMachines Desktop PC
Emachine i have a emachine i can hear it whe i power it on but nothn else
  • foxy37 Mar 30, 2008
    i can power it on and hear it but no light not even the light on the monitor come it its a emachine w2040
    President:
  • 2,351 Answers
Hi foxy37, so what you mean is that you have no display on your monitor? I can only ask you to check a few basic things & than I'll need you to post the model number for your e-machine so I can suggest other information.
1. First check that the monitor cable is securely connected at both ends (monitor & PC), & that the monitor's power cord is plugged in & is turned on.
2. The last time you recall running the PC did you or anyone else install any software? Was any one inside the PC? Did the PC run correctly? Now I'll need to know what model your e-machine is, so I can go here & check what you may need to do to check the PC.
Click this link. http://www.emachines.com/support/product_support.html?cat=Desktops
Mike
Posted on Mar 30, 2008
  • Mike Peluso
    Mike Peluso Mar 31, 2008
    Hello foxy37, thanks for the updated information. Concerning your monitor. You must turn on the monitor. The light on the monitor will turn green when first powered on & a few seconds after turning green if there is not a video single coming from the PC the light will change color to amber. (this is normal for all monitors). Still have your PC manual? Turn to pg. 2-2 & check the back of the power supply, there is a red slide switch. It should be set to read 115v.
    When you press the power button on the e-machine W2040, watch the front of the PC. See pg. 1-1. You should see the power button turn green (it's not very bright). You should also see a smaller (red) flashing led. This is your hard drive is working/running. Your monitor's light should go from amber to green. Can you borrow a monitor from a friend just to see if your monitor is bad? If you have checked everything from my last post & you also tried another monitor than it is possible your video adapter is bad. If you have never been inside a computer before than I strongly suggest you take your PC to a service center. I can not talk you through trouble shooting the internales with out you hurting yourself or the PC.
    Mike
SOURCE:
No Video
If its a flat screen monitor ?
eMachines flat-screen monitors offer high quality at low cost. eMachines flat-screen monitors are compatible with most brands of PCs. Issues with eMachines flat-screen monitors can arise from faulty power sources, cable problems and incompatible settings. These issues can be resolved by testing step-by-step each possible cause.
Plug the computer's power cable firmly into a working AC outlet. Press the computer's power button.
Check the LEDs on the front of the computer case to confirm that the computer receives power. Plug the eMachines monitor's power cable into a working AC outlet. Press the monitor's power button. Check the LEDs on the front bezel or power button of the eMachines monitor to confirm that the monitor receives power. Orange or blinking LEDs indicate low power or no signal. Green LEDs denote a working connection.. Perform a monitor self-test. Switch off the monitor. Unplug the video cable from the monitor. Press the eMachines monitor's power button. An eMachines logo, Windows logo or "no signal" message indicates that the monitor is working properly. Plug the eMachines monitor's video cable into the video port on the computer. Attach the monitor's included DVI-to-VGA adapter to the monitor's VGA cable if your computer has a DVI port (15 or 25 pin-slots with 1 side slot) in place of a VGA port (15 pin-slots, no side slot). Press the eMachines monitor's input button to change the monitor's setting to match the computer port used. Set your monitor to DVI if connected to your computer's DVI port. Set your monitor to VGA if connected to your computer's VGA port. Connect the eMachines monitor to a known working computer with a known working video cable if the problem persists. Contact Gateway, eMachines manufacturer, if the monitor issue is not resolved. Hope this helps.
Jan 03, 2013 | Computers & Internet
Samsung microwave child error/ turnd power off now se appears in window and does nothn when push buttons
SE indicates a short in the keypad membrane, the keypad control board will need to be replaced, a costly venture.
Apr 06, 2012 | Samsung 1.8 Cu. Ft. Over-the-Range...
Emachine D2880 worked fine yesterday will not power on today
when you push the power button, fan or blower on power supply spinning or not? of not. your problem is power supply, nut if yes... did you hear any beeping sounds?
Jun 19, 2010 | E-Machines eMachines Desktop PC
Help
call 1-800 4 my xbox they will help you
Sep 15, 2008 | Microsoft Xbox 360 Console
Zune
do u get any type of error mesg ???
May 23, 2008 | E-Machines eMachines Desktop PC
Emachines doesn't start
Hi!
Is the power supply the same rating?
Is the HDD spooling up?
Do you hear the post beep?
let me know soon, Thanks
May 22, 2008 | E-Machines eMachines Desktop PC
Emachine T2984 won't power up
First, Check your ram. If not seated, it will not power up. Also, do you hear a series of beeps or not? Need a better & more exact description of problem and what occurs
Apr 14, 2008 | E-Machines eMachines Refurbished EMA...
EMACHINE T2642 W/ IMPERIAL GV20030812
Can you provide at bit more info?
You say it wont power up, are you getting any power through at all? DO the LEDs light up? Can you hear the noise of the fans etc powering on?
Mar 23, 2008 | Computers & Internet
Emachines 5210
Can you hear fan inside the PC? Any flashing lights next to the power button? Please give us more details.
Oct 23, 2007 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Ekse
Steve Allison
Steve Allison
Thomas F. Schneider
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
