Question about Shakespeare Ugly Stik Freshwater Fishing Rod
Fishing pole replacement tip. I have a replacement kit but how do you get the broken tip off. The end of the pole is not broken and the broken tip is still firmly glued on.
Most fishing rods are made of graphite, and are very easily breakable. i suggest that you find a way to CAREFULLY saw or file off the tip as close to the glue as you can, preserving as much of the rod as you can. maybe a knife or serrated blade of some sort could get through the tip. i have lost ALOT of fights with BIG fish and i usually end up replacing tips... NOTE that using a new tip will reduce sensitivity in your rod but not too much
Posted on Jan 29, 2013
    Problem Solver:
  • 12 Answers
You can melt the glue i think
Posted on Jul 29, 2010
Fuel lione and filter came off in the tank
This is a simple repair.
1. Drain tank save fuel can be used again
2.Purchase fuel line replacement kit Lowes -Home Depot
3.Kit needs to contain feed wire and gas hose.
4.Disassemble cover to reveal fuel line connection to carb.
5. Feed wire from kit into fuel tank through fuel line hole.
6. Install new hose over wire connecting end into hook at end of wire
7. Pull hose through tank up to the carburetor
8. Remove wire and connect filter and hose to carburetor
9. Replace gas into tank, Ck for leaks
Nov 15, 2015 | Stihl HT101 Pole pruner
The legend of zelda twilight princess
You will need the fishing pole you receive from the family who's son promised it to you!!! To obtain it there is a mischievous monkey who is at the back of the canyon with the mother of the son's baby crib in it's hands. To get the crib from the monkey there is a spot on one of the roof's of the houses with some special grass that you can blow into to make an eagle's cawing sound. When you do this a raptor "aka the bird of prey" will come down onto your hand and you can launch it at the money and he will drop the basket. Then you go get it and give it to the mother and she will lead you to the next step for getting the fishing pole her son has created for you. Follow all the steps and you will get to the fishing pole, which you then can use to fish out a fish for the cat and he will go inside the storekeeper's house.
Apr 06, 2014 | Nintendo Wii Console
Echo ppt-266 pole chainsaw will not cut with the pole extended
A very common problem is that the tip of the drive shaft breaks off. If it cuts with the pole retracted and won't cut with it extended, than the drive shaft is pulling out at the clutch end or at the head. Try loosening the screws where the pole goes into the cutting head, stand the unit straight up and twist the cutting head to see if it drops down even just a little bit. After trying that, loosen the screws where the pole goes into the engine assembly and twist it there also. If this doesn't work, remove the pole at the engine end and pull the drive shaft out to inspect the ends of the shaft. Good Luck. George
Oct 20, 2013 | Echo 12 in. 25.4 cc Bar Telescoping Gas...
Berkley poletap
Take a pet bottle of that size. Cut one side and put it around it and then make holes as requires and necessary
Jun 04, 2013 | Fishing
Need instructions on how to restring the spiderman shakespear rod
i just followed this kid on this video and it worked for the spiderman shakespear kids fishing pole. http://www.youtube.com/watch?v=XddYxI4ZF0c
Jan 18, 2011 | Shakespeare Spiderman Fishing Accessory...
I want to attach the chain saw to the pole
ahhhg i would say NO if its made for a pole get the right pole ! you will find that the first time you use it you come back with just the pole and no saw.. and the you break you neck trying to retrieve your saw way up in the tree.. WHY U ASK ? the saw blade will get pinched . means stuck in the cut. and will need another saw to rescue it.. fun huh .if you need a little extra height use a truck bed. never use a ladder . good luck be safe..in the gas tank is a filter. you can use a clothes hanger to fish it out, remove it blow it it out backwards with air . or replace it. if this don;t work buy new fuel lines ,carb kit,carb cleaner spray(parts master #1736 my fav) and a new spark plug. when doing the carb just replace gaskets and diaphragm .. don't worry about all the other stuff in the kit, you are just washing the carb to get gunk or dust out of it .. all back together and wa la.. ning ning niiing.. back in biz.. one other thing that goes bad is the crank shaft seal( the 1 next to the clutch) and it can be a pain to replace ! vote if'n i was of help.. remember BUY USA MADE PRODUCTS.. Jay
Aug 08, 2010 | Remington Electric Pole Saw
Broken part for the pole attachment
RemingtonPower has stopped production of everything except unhappy customers. Replacement parts are almost exhausted.
I went here:
Remington.com
http://www.desaparts.com/index.htm
  • Typed "111182-01" into the "Part #:: window, then clicked search.
  • Click the 111182-01 - USE REPLACEMENT PART # 111304-01 "View Part" link.
Results follow:
Part #: 111304-01 Price: $15.00
Description: CHAINSAW BRACKET 747
If this is what you need I suggest you order it soon here:
If you have questions, or need assistance with any of our services, please do not hesitate to call our customer service team at 1-800-475-5660.
Please use the phone and get a name of the person providing service. HTH
Lou
Nov 12, 2009 | Desa International Remington 14" Electric...
Ive just got a browning pole can you advise on set up please
A browning fishing rod? Or a power pole?
Aug 14, 2009 | Boating
Shakespeare Ugly Stik Freshwater Fishing Rod Logo
272 people viewed this question
Top Shakespeare Sport & Outdoor - Others Experts
Bill Eager
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Are you a Shakespeare Sport and Outdoor - Other Expert? Answer questions, earn points and help others
