The water inlet valve is bad allowing the water to drip into the tube and allowing it to freeze there clogging the tube. This is the most common cause for the tube to freeze. You will need to replace the "water inlet valve" on the back of your unit. Here is the part you need to order.
Sounds like the dual water control valve is sticking open while off allowing water to slip by the valve an into freezer compartment. Best to turn water off at source untill the=> WR57X10051 Water Valve - Dual Outlet
Yes, every time the icemaker cycles, it will switch in power to the icemaker water valve. the icemaker is pretty much a standalone device. All it needs is power and water supply, and valve. If it has both, and is not working properly, then the icemaker is bad.
This sounds like your water valve is not completely closing allowing water to drip and freeze. First check to make sure that the water tube going into the cup of the ice maker is lined up correctly and not causing this problem - if it is lined up correctly then replace the water valve on the back of the refrigerator that your main line is connected to.
The water dispenser and the icemaker both operate on different soleniods on the water valve so the chances of a bad valve are slim. I would assume you issue is in your water supply. The easiest thing you could try first would be to check your saddle valve that taps into your main water line to supply the ref. They are known for calcium deposits which obstruct the flow of water. This issue is IDed by very slow water pressure through th door. If its gunked your icemaker fill tube may also be frozen.
Sounds like the inlet water valve for the icemaker is not shutting off 100%. That would result in either A.) a block of ice plugging the tube where the water passes through from the outside of the freezer into the freezer compartment, or B.) an ice waterfall in the freezer into the ice bin and/or down the back wall of the freezer compartment.
Solution to either: replace water valve and remove ice with the aid of a hair blower.
