Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Do not rinse and spin
Timer gets stuck on wash does a half spin then beep lid
  • Whirlpool Master
  • 43,501 Answers
Here is a tip that I wrtoe about washing machinesdo not rinse and spin - 2_bing.gif that don't spin out right..
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
heatman101
Posted on May 15, 2010
Hello, I have a Maytag Bravos MVWX550XW washer that will not rinse or spin, only wash. The drum moves. I replaced the washer inlet valve, did not fix the problem. Removed the lid switch assembly...
hi Melanie.
this is all i could find out.
If the water won't drain out of your washing machine, either something is stuck in the drain hose or pump, or the pump is broken. Both fixes are simple if you're even just a little bit handy with tools. We're showing the repair on a Maytag washing machine.
How to Drain Washing Machine That Won Drain Family Handyman
What is wrong with a washer that does not spin? If your washer fills with water but doesn't agitate, the problem is likely to be a faulty lid switch, a broken belt, or a problem with the motor. (Note: Direct-drive washing machines do not have belts.) To diagnose the problem, do the following: 1Check the washing machine's spin cycle
Washer Doesnt Agitate or Spin
Maytag Washing Machines will not rinse or spin Google Search
Dec 12, 2017 | Maytag Washing Machines
My whirlpool washer periodically gets stuck on rinse.. the water continues to run but its only about half full so it must be draining. My water bill was over $100 last month, please help.
check the lid switch, if it isn't working right the machine will not enter the spin cycle, also the timer may be going bad, it could stay stuck in between the rinse fill and rinse cycle
Jun 21, 2011 | Whirlpool Washing Machines
My topload Roper washer cycles fine but stucks in rinse stage. It makes a noise on that stage. I manualy put it in spin mode (skipped the rinse) and it works from there. Please help.
Your timer is bad. There must be a pause in the timer for the neutral drain transmission to lock in.
No Pause.
No Spin.
To double check this,when the timer gets to the Spin cycle, open then close the lid.
If it starts to spin at that point the timer is bad.
Jan 09, 2011 | Roper Washing Machines
Whirlpool washing machine stuck on rinse cycle. Might have had to much in the machine and now will not proceed with rinse.
If it will not pump the water out and spin, it could be the lid switch. If that is not it, then it is probably the timer. Advance it to the spin cycle and try it.
Jan 03, 2010 | Washing Machines
Rise and spin
While the machine is operating take the timer knob and wiggle it around. If the machine cuts out momentarily then the timer is bad. If not then I would check out the lid switch to see if it is affecting the rinse and spin cycle.
Eric
Sep 17, 2009 | Kenmore 24032\24036 Top Load Washer
Rinse problem
Sounds like a timer issue. Try this, Yes it sometimes works. Spin the timer knob vigorously six to ten complete turns. It may be that the contacts are stuck together and this frequently frees them. Timers are expensive, so this is worth a try. Good luck.
Jul 01, 2009 | Kenmore 22642 Top Load Washer
Spin/drain cycle won't start
If the timer gets to the rinse cycle and stops,
Check the lid switch for continuity. If no continuity replace the lid switch.
If the timer continues through rinse and spin without doing either, replace the timer.
May 21, 2009 | Kenmore Washing Machines
Rinse cycle not happening
CHANGE THE LID SWITCH AND OR TIMER
Apr 08, 2009 | Haier XQJ50-31 Top Load Washer
Washing machine won't rinse or spin
sounds as if you have a faulty lid switch, for safety reasons if the machine doesnt think the lid is closed it willnot spin/drain the waer out.
Feb 23, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
114 people viewed this question
Dan Webster
Dan Webster
Sal De
