Question about KitchenAid Kitchen Ranges
KitchenAid gas range, oven light bulbs won't turn on
I have a KitchenAid gas range, model YKGRC608. The two interior oven lights won't come on, though I hear a click when I open or close the door or touch the oven light control button. The switch on the inside (that gets pushed in when the door is closed) seems to move freely. Everything else seems to be working. I have changed one bulb, but I can't get the protective glass cover off the other light to change it too.
1) Is it possible that the lights are wired so if one bulb is burnt out, the other won't come on?
2) What else could be the problem?
3) Any tips to help get the protective glass cover off? I can move it a little from side to side, but not unscrew it, it's stuck. Is WD-40 safe to use on the inside of the oven?
Thanks!
  • alittlepecul May 15, 2010
    Update...I managed to get the cover off (put wooden block against cover, gently tap with mallet) and replace the bulb. Lights still not working. Any suggestions would be welcome. Thanks!
  • 254 Answers
SOURCE: Inner door glass replacement
open door fully, look down by hinges where enter unit, pull those metal tabs back that lock the door in place, close door to broil position 3/4 way closed and lift up, which should get the door off the unit.. once removed you would have to get acess inside that door by a combination on removing outer sccrews and hing screws and also seperating those glasses.....be careful to remeber how everything goes back i know of some techs that run into problems reassemblin those doors.. hope this helps,, some local service companies often charge a smaller in shop service call for small items like that if thats avaialable in your area,, hope this helps
Posted on Feb 07, 2010
Testimonial: "Thanks a million. Excellent!"
  • 1462 Answers
SOURCE: We have a Neff B1432
they are often very stiff due to crud burning on. use mole grips and there is a risk you will break bulb cover but that is not the end of the world.
make sure you use a heat proof bulb as a replacement
Posted on Sep 30, 2008
SOURCE: oven light exploded and seems fused in socket
I was able to remove the base from the socket by inserting pliers and opening them so that they pressed against the inner sides of the base and then turning while exerting pressure.
Posted on Nov 13, 2008
SOURCE: changing oven light bulb
The manual states to turn the cover counter clockwise. I was able to turn it about an inch and then it stopped turning. You really have to apply pressure, but it will turn more. It is similar to a tight light fixture. I was worried about breaking it, but it did finally loosen. I believe the replacement bulb is a 40 watt mini oven bulb also...
Hope this helps!
Posted on Nov 29, 2008
  • 254 Answers
SOURCE: Interior door glass cracked on my KitchenAid oven
thers the inner most glass then some inner glass packs then the outer determine waht u need take ur model and go to sears.com go to there parts direct or parts research link lookup ur model find the part number and a normal price ........anyways u are gonna have to take the door off and replace it, kinda hard to describr just have to get acesss inside and replace the glass... might need service might be cheaper if u have a local repair shop for u to take the door off and bring it in to them... to get that dooor off most have lil flappers or metal locks open the door fully inspect down by the hinge pulll those flappers back towards glass then move door to brooil position 3/4 way closed and lift striaght up... hope this helps reply or rate me if posible k thanks
Posted on Jan 28, 2010
Hi,My oven won't light but I can smell gas and hear the clicking when I went to light it Kit. Aid model # KGSS907 Thank you. Steve
which one is your model KGSS907SBL00 (30`` Slide-In GAS OVEN CONVECTION)
> KGSS907SBL01 (30`` Freestanding GAS OVEN CONVECTION)
> KGSS907SBL02 (30`` FREESTANDING GAS OVEN CONVECTION)
> KGSS907SBL03 (30`` Freestanding Gas Range with Convection Oven)
> KGSS907SBT00 (30`` Slide-In GAS OVEN CONVECTION)
> KGSS907SBT01 (30`` Freestanding GAS OVEN CONVECTION)
> KGSS907SSS00 (30`` Slide-In GAS OVEN CONVECTION)
> KGSS907SSS01 (30`` Freestanding GAS OVEN CONVECTION)
> KGSS907SSS02 (30`` FREESTANDING GAS OVEN CONVECTION)
> KGSS907SSS03 (30`` Freestanding Gas Range with Convection Oven)
> KGSS907SWH00 (30`` Slide-In GAS OVEN CONVECTION)
> KGSS907SWH01 (30`` Freestanding GAS OVEN CONVECTION)
> KGSS907SWH02 (30`` FREESTANDING GAS OVEN CONVECTION)
> KGSS907SWH03 (30`` Freestanding Gas Range with Convection Oven)
> KGSS907XSP00 (30`` FREESTANDING GAS OVEN CONVECTION)
> KGSS907XSP01 (30`` FREESTANDING GAS RANGE WITH CONVECTION OVEN)
Jan 04, 2013 | KitchenAid KGSS907SSS Gas Kitchen Range
Oven light won't come on
turn light switch off !! then take bulb out, then look inside socket u will see center little pin, with small flat head screwdriver gently pries out so that when new bulb goes in u r sure to make connection.
Oct 11, 2012 | Frigidaire Gallery 30" Self-Cleaning...
Kitchenaid Gas convection range lower burner will
whirlpool oven wont turn on top burner work.
model #SF315PPQ2
Sep 04, 2009 | KitchenAid KGRT607HBS Gas Kitchen Range
KitchenAid KGRT607 - Oven won't light reliably, can smell gas.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Aug 29, 2009 | KitchenAid KGRT607 Gas Kitchen Range
Ge oven model xl44. my oven will not lite, the broiler works fine.
Hi..
You need to do this
  • Replace the bulb
  • Test the switch
The interior oven light in most ovens is a standard 40 watt appliance bulb. Often, to change the bulb, you first need to remove a shield or glass dome. If the bulb isn't burned out, the problem may be with the switch on the oven door frame. If the switch works poorly, intermittently, or not at all, you need to replace it.
When an indicator light has stopped working, you may be able to replace just the bulb--but you usually have to replace the entire light assembly. Alternatively, there could be a problem with your burner sensor (stuck open or closed) or your indicator light circuit.
Good luck !!
Regards
PCmania
Jul 15, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
How do I change the light bulb in the oven
You can replace the light bulb(s) in your range/oven, though you may need to remove a glass covering or dome to reach it. Most interior oven lights use a universal 40 watt appliance bulb.
Apr 24, 2009 | Philips Ovens
I have a spectra gas range and the broiler works but the oven doesn't. When I turn the oven on the middle light blinks but oven won't light, what's wrong? Model#348A8035P017
Mar 30, 2009 | GE Kitchen Ranges
Oven glass shatter on kgst307gwh0
You would need to contact Kitchenaid about any possible product issues
Mar 05, 2017 | KitchenAid KGST300 Gas Kitchen Range
Changing oven light bulb
Hope this helps!
Mar 30, 2008 | Whirlpool GR460 Electric Kitchen Range
Interior Light
The interior oven light can be accessed in the following way:
1.Open door and remove the top grill via the 2 screws along the top edge.
2. In the interior light will be under metal plate with fasten by single screw. The halogen bulb is rated at 120V 20watt. Looks like a G-8 bulb with 8mm pin spacing with o.a.l. 1-5/8" long
Get these bulbs cheap at http://www.1000bulbs.com/120-130-Volt-G8-Base-Halogen-Light-Bulbs/
Jan 01, 2008 | GE JVM1790 1000 Watts Convection /...
Open Questions:
Kitchen Ranges Logo
152 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
