Question about Cherokee (REF) AM/FM Stereo with CD Player and Hands-Free Capability
Removing Door side Panels?
How do I remove the side Panels on the doors too get to the speackers to replace them with new ones?
    New Friend:
  • 113 Answers
What is the make model and year of the vehicle?
Posted on Mar 31, 2008
SOURCE:
How do I get the armrest off drivers door,to put in new window control on a 2003 aztek
Hi Anonymous
There is discussion here about removing the door panel on an Aztek - see the 2nd or 3rd discussion bloc down
http://aztekfanclub.com/upholsterymods-interior/removing-interior-door-panels
there is also an older Fixya thread here talking about removing the panel
How do remove the drivers side door panel on an aztek Depending on how much of a hurry you may be in, I've found that the tools for being able to pop the plastic pop-fasteners in car panels have a much higher batting average than screwdrivers in removing the fasteners without breaking them. See for instance many choices on eBay door panel removal tool , and the same sorts of things, marked up a lot more, can be found at most any auto parts store.
Hoping that helps, and Happy Holidays!
D
Dec 14, 2015 | Cars & Trucks
Tip
How do I change freezer door opening side?
Hi.
Details on how to change the fridge door opening side depend on the appliance model.If this is a chest unit, you will simply need to rotate the unit. On most upright units the general procedure to change door opening orientation is more or less the one ilustrated below:
  1. Disconnect power from the appliance.
  2. Get to the top side of the unit, and remove the hinge plate. This is usually held by two Torx or Philips screws. You may need to help yourself with a putty knife to remove a protective panel covering the plate. Be careful not to damage any part.
  3. Remove top hinge and put it on one side.
  4. After removing the plate you may need to remove the plastic clip located at the top on the handle side of the door, oppositely to the old hinge side. Use the putty knife to pry up and remove the plastic clip.
  5. Open the door and lift it from the lower hinge pivot.On many fridges you will have to remove the bottom hinge too, often held by two screws, and covered with a proective pane, to free the door before removing it
  6. Carefully place the door on the floor.
  7. Remove protective panels on top and bottom on handle side of the frige cavity, reinstall the hinges on handle side position, swapping them with the protective panels.
  8. Remove the door pivot and mount it on the opposite side.
  9. On the door disassemble and refit handle or any other part if needed.
The precise and complete procedure is usually illustrated on the appliance user manual. If you need manual or schematics, try asking a new Fixya question. Ensure that you are providing full model number, as printed on service tag.
To get more detailed info you can also try calling the appliance manufacturer at the number listed on the owners manual.
Regards.
on Mar 30, 2010 | Refrigerators
How do I take the glass out my oven door model AP578X-8
Hi, I have pasted the instructions for your Smeg oven you below:
9.4 Removing the internal glass panels
The glass in the door should always be kept thoroughly clean. To facilitate
cleaning, it is possible to remove the door (see 9.2 Removing the door) and
place it on a canvas, or open it and lock the hinges in order to extract the glass
panels.
The glass panels of the door can be completely removed by following the
instructions provided below.
Warning: before removing the glass panels, make sure that at least one of the
door's hinges has been locked in the open position as described in "9.2
Removing the door". This operation may have to be repeated during the glass
removal process if the door is accidentally freed.
Removing the internal glass panel:
• Remove the internal glass panel by
pulling it upwards, following the
movement indicated by the arrows. Doing
this detaches the 4 pins attached to the
glass from their slots in the oven door.
Removing the intermediate glass panels
(on some models only):
• Some multifunction models have an
intermediate glass panel. Remove the
intermediate panel by lifting it upwards.
Cleaning:
• It is now possible to clean the external
glass panel and the panels removed
previously. Use absorbent kitchen roll. In
the case of stubborn dirt, wash with a
damp sponge and neutral detergent.
Replacing the glass panels:
• Replace the panels in the reverse of the
order in which they were removed.
• Reposition the internal glass panel, taking
care to centre and insert the 4 pins
attached to the glass into their slots in the
oven door by applying slight pressure.
You can go to the website for further information: http://www.u-manual.com/download-manual-now-for-free-10/210209/oven-smeg-ap578x-8.html#.UumokD2Sxvg
Jan 29, 2014 | Smeg Ovens
Door panel removal
There are few help links to complete this task of removing door panels.Click the link below:---
How to Access car door panel?
How to remove the door panel to install a new window regulator?
http://howtobyme.blogspot.com/2011/08/how-to-remove-door-panel-to-install-new.html
window motor, regulator and door panel removal?
http://technoanswers.blogspot.com/2011/02/ford-explorer-window-motor-regulator.html
How to Remove Door Panels ?
http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-door-panels-on-acura.html
http://howtobyme.blogspot.com/2011/11/how-to-access-car-door-panel.html
Vehicle door panel components?
http://howtobyme.blogspot.com/2011/11/vehicle-door-panel-components.html
This will help.
Thanks.
Jun 11, 2012 | 2002 Lincoln LS
How do I remove the door panels
This will help.
Thanks.
Jun 08, 2012 | 2000 Dodge Grand Caravan
Remove door panel
This will help.
Thanks.
Jun 04, 2012 | 2002 Cadillac Deville
How do you remove rear door panel of seat altea
This will help.
Thanks.
Jun 04, 2012 | 2005 Seat Altea 1.6
How do you remove passenger sliding door handle on oldsmobile silhouitte
The process of removing car door panels is essentially the same for each make of car. You may need to remove these panels when your fixing locks or power windows, replacing window cranks, installing speakers or replacing the side mirrors. Learning how to remove the panels yourself can save money on simple car repairs.
Related Searches:
Difficulty: Moderately EasyInstructionsThings You'll Need
  • Set of screwdrivers
  • L pick
  • Small flashlight
  • Ratchet and socket
    • 1
      Check out how the door panels are attached to the car. Most panels use screws and bolts but others have snap-in fittings. Gather all the tools you need for removing the door panels. If the panel is attached with screws and bolts, you need a screwdriver or ratchet and socket. Car door panels with snap-in fittings are easily removed with a flathead screwdriver.
    • 2
      Locate where the screws and bolts are before starting. These are usually found in the arm rest area, along the bottom or sometimes near the door lights.
    • 3
      Roll down the car door window. Begin removing all screws and bolts that hold the door panel onto the car. If your car has snap-in fittings, pry gently on the bottom corner of the door panel until the fittings pop out.
    • 4
      Remove the power window control panel if your car has power windows. The control panel should pry out easily, and then you unplug the wiring harness from the back and place it to the side.
    • 5
      Use an L pick and flashlight when locating a manual window crank. Look behind the window crank and slide the pick under the edge of the metal clip that holds the crank in place. Remove the clip and pull the crank off.
    • 6
      Remove the door handle by unscrewing the small screw located in the center. Gently pull the door handle out until you see the back of the handle and unclip the rod from the door handle. This should remove the handle unless the handle and door lock are attached, then you just unclip the rod from the lock and remove them both together.
    • 7
      Unscrew the cap off rear upper corner door panel locks. These don't have a rod attaching them to the handle and unscrew separately from the door handle.
    • 8
      Pop the door panel off after you've removed everything. Gently pry on the bottom edge of the door panel until it releases. Pull out and up to completely remove the door panel.
Jan 10, 2012 | 1998 Oldsmobile Silhouette
Leaks from door gasket.Should I change the gasket or the whole door? Thanks
Replace the door seals/gasket.
You also have adjustment on the door hinge springs. You need to remove side panels to get to the hinge adjustment on the sides and tighten them. Sometimes the chasis of the machine gets bent from the weight of the door.
If you need instructions on removing the side panels let me know.
Ash
Sep 13, 2011 | LG 24 in. LDS 5811 Built-in Dishwasher
Two of my door locks will not unlock w/ remote or inside button.
The door lock actuators or 'solenoids' have failed. This seems to be pretty common on Windstars - I've just replaced a couple on my '02. (Ironically, the original batteries in the remote fobs are still going strong, they lasted longer than the actuators). You can buy third party replacement parts, the front door ones are 'handed' driver & passenger, but a common part will work for both sliding doors. I don't have instructions for removing the door panels, but search online - it's not tricky. The original actuators are riveted in place - you'll need to drill out these rivets. The new actuator can be held in place with a nut, bolt & couple of washers. Replacing these parts isn't too difficult - the first one took me about 1.5 hours, but once I knew what I was doing, the second one took about 0.5 hours. Good luck.
Oct 29, 2009 | 2001 Ford Windstar
Car Audio & Video Logo
113 people viewed this question
Top Cherokee Car Audio & Video Experts
xxxxxx xxx
chargerhp
chargerhp
Pierre Laplante
Are you a Cherokee Car Audio and Video Expert? Answer questions, earn points and help others
