Question about Sharp Microwave Ovens
Microwave making loud, rapid noise (grinding/knocking)
Our microwave is making a loud, rapid noise (grinding/knocking) when operating (except in convection mode).
The noise appears to come from the under turntable area. The turntable stops turning.
Can anyone please give us some ideas?
Thanks
FRANKSFIXIT
  • 72 Answers
SOURCE: Microwave turntable is loud and clunky sounding.
If the unit is brand new as you say then it is covered under the warranty and the 800# for Bosch is in your paperwork that came with it.
It sounds like the glass platen (turntable) hub is either binding or else the drive mechanism itself either has a bad tooth on the main gear or tooth wheel. Some may still use a chain type drive mechanism as well.
If you call that 800 number - the customer service dept there will advise you as to what needs to happen next. It's possible they will either replace or repair at their expense.
Who installed the unit?
Let me know?
Best regards,
Frank
Posted on Mar 07, 2008
MicrowaveSvc
  • 9098 Answers
SOURCE: ge spacemaker xl microwave oven turntable
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
If yours is a GE, you can usually find helpful exploded view diagrams and order parts by entering your full model number here.
If yours is a GE, there should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Posted on Aug 02, 2008
rickzilla
  • 706 Answers
SOURCE: microwave turntable won't turn
You may have a tunrtable motor or spindle problem..
This info is from GE website..( link : http://genet.geappliances.com/geasearch/Dispatcher?REQUEST=GETSEARCHRESULT
To minimize the possibility of electric shock, unplug this appliance from the power supply before attempting any maintenance or cleaning.
  • Make sure the turntable is centered and seated properly. On models with a stirrer motor there is a shaft protruding up through the floor of the microwave. Make sure the turntable is securely fastened to this shaft. On models that turn on a ring with wheels attached, make sure the turntable is seated securely on the ring.
  • Check the turntable to make sure it is placed right side up. If the turntable plate is upside down it will drag on the floor of the microwave.
  • Check to make sure that there is no food or debris under the "wheels" of the turntable ring. Food can prevent the wheels from moving forward.
  • Be certain you are pressing a cook function rather than a timer function.
  • If the microwave has a turntable on/off feature make sure the turntable was not inadvertently turned off. Try depressing the turntable on/off pad to re-engage the turntable.
Posted on Sep 21, 2008
vitg55
  • 78 Answers
SOURCE: GE Spacemaker Microwave JVM1653WD004 Turntable not Working
Here is few site that should help you:
http://www.repairclinic.com/
http://www.partselect.com/
Posted on Dec 01, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: Sharp 930 AK Convection/Microwave Oven
When you close the oven door the latches operate a couple of interlock switches that control power. It may be that one of the door switches is bad or out of adjustment. It's also possible that one of the door latches is broken so it's not hitting the switch. There should be two door latches. Are they both there? This oven could be fixed by adjusting or replacing the interlock parts as needed. Because of concerns about microwave leakage from an improper door seal, you should have this oven serviced by a professional.
Posted on Jun 04, 2009
Speed queen noise when on spin
follow this test and fix it. God bless you
  1. MagnetronIf your microwave is emanating high pitched or growling noises during operation, the magnetron could be going bad. Normally a nearly silent part, the magnetron uses high voltage and induces the frequency required to cook food. Although normally not a safety hazard to operate, this is a sign that the magnetron is failing and will need to be replaced as soon as possible.
  2. Exhaust fan motorIf your microwave is making a very loud humming noise during operation, it could possibly be the exhaust fan motor. If defective the part will need to be replaced to silence the appliance once more.
  3. Stirrer motorAnother leading cause of a noisy microwave is an expired stirrer motor. With use this part becomes worn and makes a loud grinding noise, which is usually a leading indicator that the part needs to be replaced. The stirrer is a metal blade that is slowly turned by the motor. This action disperses the microwave energy in a random pattern, which heats the food evenly. If the stirrer motor is determined to be nearing expiration, it should be replaced to halt the grinding noise.
  4. Turntable motorA very common cause for a noisy microwave is a worn out turntable motor. This is a relatively easy repair and will put an end to the noise once replaced.
Nov 19, 2013 | Microwave Ovens
Microwave occasional loud buzz
make this test and fix it. God bless you
Nov 14, 2013 | Jenn-Air JMV8208AAS Microwave Oven
GE microwave occasionally buzzes loudly.
Nov 14, 2013 | Microwave Ovens
Made a grr noise then shut off will not turn back on
Nov 06, 2013 | Emerson MWG9111SL Microwave Oven With...
Buzzing noise
follow this steps and fix it. God bless you
Oct 23, 2013 | Panasonic Microwave Ovens
Sharp sound bar buzzing
test this steps and fix it. God bless you
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#13#ixzz2hVe8AHvJ
Oct 12, 2013 | Microwave Ovens
Buzzing noise
follow this instruction and fix it. God bless you
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#13#ixzz2ZYUSVYSH
Jul 19, 2013 | Morphy Richards AM925EF Microwave Oven
Gh5184xps3 microwave
this cause noise ; God bless you
  • MagnetronIf your microwave is emanating high pitched or growling noises during operation, the magnetron could be going bad. Normally a nearly silent part, the magnetron uses high voltage and induces the frequency required to cook food. Although normally not a safety hazard to operate, this is a sign that the magnetron is failing and will need to be replaced as soon as possible.
  • Exhaust fan motorIf your microwave is making a very loud humming noise during operation, it could possibly be the exhaust fan motor. If defective the part will need to be replaced to silence the appliance once more.
  • Stirrer motorAnother leading cause of a noisy microwave is an expired stirrer motor. With use this part becomes worn and makes a loud grinding noise, which is usually a leading indicator that the part needs to be replaced. The stirrer is a metal blade that is slowly turned by the motor. This action disperses the microwave energy in a random pattern, which heats the food evenly. If the stirrer motor is determined to be nearing expiration, it should be replaced to halt the grinding noise.
  • Turntable motorA very common cause for a noisy microwave is a worn out turntable motor. This is a relatively easy repair and will put an end to the noise once replace
  • Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#13#ixzz2ZPm395lp
    Jul 18, 2013 | Whirlpool Microwave Ovens
    Microwave makes sound like something moving inside
    follow this steps and use the VOM , and fix it. God bless you
    Jun 18, 2013 | GE JVM1490 Convection/Microwave Oven
    Microwave made a loud grinding noise while heating a cup of coffee for 1 minute,now everything is shut off. We checked the curcit breakers all ok, and there is power going to it!
    see this causes and fix it. God bless you
    Turntable Motor If the microwave is loud or noisy the turntable motor might be worn out. This is a common problem and relatively easy to replace.
    Stirrer Motor If the microwave is loud or noisy the stirrer motor might be worn out. The stirrer is a metal blade which slowly turns around, deflecting the microwave energy in a random pattern inside the microwave oven. As the motor nears the end of its useful life it begins to make grinding noises. The microwave will not heat food evenly without this stirrer, the motor should be replaced.
    Exhaust Fan Motor If the microwave is loud when running the fan motor might be
    Magnetron If the microwave is loud or noisy only when cooking, the magnetron tube might be defective. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. Under normal circumstances the magnetron is nearly silent. However if it is damaged or nearly burned out it can begin emitting high pitched or growling noises. It's not normally dangerous to use a microwave oven when it makes these noises, but they are an indication that the magnetron is almost dead and will need to be replaced.
    Oct 15, 2012 | Microwave Ovens
    Microwave Ovens Logo
    110 people viewed this question
    Top Sharp Microwave Ovens Experts
    William Miller
    William Miller
    Devabhakthuni...
    Devabhakthuni...
    Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
