Question about Craftsman Replacement Belt for 42" Deck
Mower suddenly shut off and engine starting smoking. Now it won't do anything. seems to be locked up. Sears craftsman riding mower only 1 and a half years old. has oil and gas.
  • 5,568 Answers
About the first thing I would do is to pull the plug lead(s), tilt the mower up (resting it on something solid) and see if the motor shaft could be turned at all. I suspect you initial thought that it is locked up is correct.
Posted on May 15, 2010
I changed the oil on my sears riding mower and it run fine for over an hour and then started smoking real bad.
What weight of motor oil did you put into the tractor? And how much? The capacity of the crankcase is 1.7L (1.75 qt.). The recommended engine oil is SAE 30. If you put a 10W-30 product into the engine and operated it under heavy load or heat conditions, the oil may not be capable of providing sufficient lubrication.
Aug 05, 2014 | Craftsman Garden
My 1976 sears 18 hsp riding mower quit running now it just cranks but won't fire it has a onan engine
check for spark then spray a little carb cleaner or starting fluid in the carb if it fires its a fuel problem filter pump carb
Apr 10, 2012 | Craftsman Garden
Sears Craftsman riding mower V belt getting chewed
I believe you may have the belt over one or more of the belt retainers next to the pulleys. They are 5 or 6 inches long and about a 1/4 inch in diameter. You have to loosen them when you put the belt on then adjust them to where they are just barely touching the back of the belt. They keep the belt from jumping off.
May 01, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Sears Craftsman model 917.270.711 (10 years old). This is a followup question. The mower had been starting roughly with white smoke. It got progressively worse, to the point where the mower stalled with...
There is a possibility that the head gasket is blown.
Until you are certain the issue of fuel being in the oil is resolved, internal engine damage could be happening. Inlet needle/seat leakage must be check with a leak detector or pressure guauge.
Nov 15, 2009 | Craftsman Garden
Using oil...no leakage...no smoking
by recently, do you mean, since it got hot outside? if you're using a multi-vis oil, it gets too thin in hot weather and will "vaporize" and burn, not enough to cause smoking. use a good 30 weight oil. other than that, can't think of anything else that would cause it with no leaking or smoking
Aug 18, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Lawn Mower won't start
Its a thing of beauty to see problems solve themselves. It seems to me this trial and error approach is very taxing and could have been avoided if 1, your small engine repair guy/Craftsman/Sears had sold you the right parts from the start, or 2, you had bought the right part... from the start.
Oct 21, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman Replacement Belt for 42" Deck Logo
140 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
