Question about Boating
What size fuse goes into the following on my year 2000 Stingray 180-RS boat: engine is 3.0 (Volvo) Merc Cruiser Horn? ignition? Nav light? blower? wiper? bilge? accy???? recept??? stereo? Thanks, dan
    President:
  • 3,085 Answers
All are 15 AMP
Posted on May 15, 2010
Bayliner boat cabin cruiser 1986 26 ft with gm motor and volvo penta carburator Need owners manual
What engine? 4cyl, 6 cyl, 8 cyl? 2.1 2.3 2.5 3.0 3.8 4.3 5.0 5.7 7.4liter?
Jul 31, 2017 | Volvo Boating
Need horn wiring diagram for 2006 pt cruiser
http://www.bbbind.com/free_tsb.html Ok here is a wiring diagram for the horn circuit on your 06 PT Cruiser . Enter your vehicle info year , make , model and engine size . Under system click on interior & driver Amenity . Under subsystem click horn . You will see
1 diagrams found. with a search button under it , click search . Click on the blue link and then your horn diagram will pop up . It's probably nothing your going to understand . Do you have a air bag light lit on the instrument cluster ? Do you know anything about computer controlled systems on automobiles ? C.A.N - controller area network ? You should read this before you mess with any wiring How to Diagnose Controller Area Network CAN Also google chrysler TIPM - totally intergated power modul problems .
Feb 13, 2017 | 2006 Chrysler PT Cruiser
How to find fuse boxs
FUSE PANEL LOCATION
The fuse panel is located in the engine compartment. A label on the inside of the cover lists the fuse amperage and circuits protected.
volvo 850 fuses fuse panel layout service repair manual
FUSE PANEL IDENTIFICATION
Fig. 1: Fuse Panel Identification
Courtesy of Volvo Cars of North America.
WARNING: Always disconnect battery ground cable before servicing "high-current fuses. It is recommended that "high-current" fuses be replaced by a qualified technician.
* 1 - 15 Amp
Fuel Injection, Distributor Ignition, Automatic Gearbox
* 2 - 15 Amp
Fuel Pump, Alarm System
* 3 - 10 Amp
Courtesy Lights, Oil Level Sensor
* 4 - Not Used (1993-95)
* 4 - 10 Amp (1996)
Electronic Start Inhibitor (Immobilizer)
* 5 - 30 Amp
ECC Blower (Speed 4)
* 6 - 25 Amp
Central Locking System, Alarm
* 7 - 15 Amp
Audio System (Amplifier)
* 8 - 25 Amp (1993-95)
Power Antenna, Trailer Connector
* 8 - 40 Amp (1996)
* 9 - 30 Amp
ABS, Traction Control System
* 10 - Not Used (1993-95)
* 10 - 15 Amp (1996)
Heated Rear Seat (If Equipped)
* 11 - 30 Amp
Heated Rear Window & Side Mirrors
* 12 - 10 Amp
Brake Lights
* 13 - 15 Amp
Hazard Flashers, Headlight Flashers, Alarm
* 14 - 30 Amp
* 15 - 10 Amp (1993-95)
Audio System, Courtesy Lights, Door Open Light, Trunk Light, Glove Box Light, Remote Control Central Locking System,
Oil Level Sensor, Seat Belt Reminder
* 15 - 10 Amp (1996)
Oil Level Sensor, Seat Belt Reminder, Data Link Connector
* 16 - 30 Amp (1993-95) Accessories
* 16 - 30 Amp (1996)
Power Antenna, Trailer Connector, Accessories
* 17 - 10 Amp
Key Reminder
* 18 - 25 Amp (1993-95)
Heated Front Seats, Power Mirrors
* 18 - 15 Amp (1996) Front Fog Lamps
* 19 - 15 Amp
Left High Beam Headlight
* 20 - 15 Amp
Right High Beam Headlight, High Beam Indicator
* 21 - 15 Amp
Left Low Beam Headlight
* 22 - 15 Amp
Right Low Beam Headlight
* 23 - 10 Amp
Left Parking Light, License Light
* 24 - 10 Amp
Right Parking Light, Bulb Failure Warning Sensor
* 25 - 10 Amp
Rear Fog Lamps, Fog Lamp Indicator
* 26 - Not Used (1993-95)
* 26 - 25 Amp (1996)
* 27 - 15 Amp
Back-Up Lights, Turn Signals
* 28 - 10 Amp
Cruise Control, Heated Rear Window, Seat Belt Reminder Light, Shiftlock, Bulb Failure Warning Sensor, Heated Rear Seat
* 29 - 15 Amp
* 30 - 10 Amp
Cigarette Lighter
* 31 - 25 Amp
ECC, ECC Blower (Speeds 1-3)
* 32 - 10 Amp
Audio System, Remote Controlled Central Locking System
* 33 - 15 Amp (1993-95)
Power Seats, OBD Test Socket, Tailgate Washer/Wipe (Wagon)
* 33 - 15 Amp (1996)
Power Seats, Tailgate Washer/Wipe (Wagon)
* 34 - 25 Amp
Windshield Wiper/Washer, Horn, Headlight Washer/Wiper
* 35 - 10 Amp
Instrument Lights, Sun Roof, Traction Control System
* 36 - Not Used
* 37 - Circuit Breaker
Power Windows, Power Sun Roof
* 38 - Not Used
* 39 - Circuit Breaker
Drivers Power Seat
* 40 - Circuit Breaker
Passengers Power Seat
RELAY PANEL LOCATION
The relay panel is located at the left corner of the instrument panel.
i copied this off a volvo site Hope this helps
Oct 10, 2016 | Volvo 850 Cars & Trucks
Simple horn diagram for 19ft. ski boat
One lead is power when button is pushed the other ground.
Jul 26, 2012 | Boating
Replaced horn and now it wont work. Where is the fuse for the horn on a 2000 Merc Mountaineer
The fuse for the horn would be in the power distribution box located under the hood in the engine compartment (see picture below). Also below is a diagram of the fuse layout. The fuse you want to check will be the fuse in the number 10 position and should be a 15 amp fuse. There is a horn relay as well and the is the relay in that same box in the number 7 position. I hope this helps and good luck.
Aug 30, 2011 | 2000 Mercury Mountaineer
2000 ford explorer, fuse box don't show me what fuses are for
There are two fuse boxes. A baqttery junction box under the hood on the drivers side and one inside on drivers side. Good luck.
Fuse/Relay
Location
Fuse Amp
Rating
Power Distribution Box
Description
1 60A** I/P Fuse Panel
2 40A** Blower Motor Relay
3 50A** 4 Wheel Anti-Lock Brake System
(4WABS) Module
4 30A** Power Windows, Power Moon
Roof, Power Seat
5 50A** Ignition Switch, Starter Relay
6 20A** Transfer Case Relay
7 - Not Used
8 20A** Air Suspension
9 40A** Air Suspension
10 30A** PCM Power Relay
1 10A* A/C Relay
2 30A* Heated Seats
3 30A* Heated Backlight
4 15A* Fog Lamps and Daytime Running
Lamps
5 4 3 2 1
10 9 8 7 6
12 11 10 9
8 7 6 5
4 3 2 1
15 14 13
2 1 1
9
6
10
8
7
5
175
MEGAFUSE
Roadside emergencies
197
Fuse/Relay
Location
Fuse Amp
Rating
Description
5 - Not Used
6 10A* Powertrain Control Module
7 30A* 4 Wheel Anti-Lock System
(4WABS) Module
8 15A* Rear Wiper Motor
9 20A* Fuel Pump Relay and RAP
Module
10 15A* Horn Relay
11 15A* Parklamps Relay and Mainlight
Switch
12 30A* Mainlight Switch and
Multifunction Switch
13 15A* Heated Oxygen Sensor, EGR
Vacuum Regulator, EVR Solenoid,
Camshaft Position (CMP) Sensor,
Canister Vent Solenoid
14 30A* Generator/Voltage Regulator
15 - Not Used
1 - Wiper Park Relay
2 - A/C Relay
3 - Wiper High/Low Relay
4 - PCM Power Relay
5 - Fuel Pump Relay
6 - Starter Relay
7 - Horn Relay
8 - Rear Wipe Down Relay
9 - Blower Motor Relay
10 - Rear Wipe Up Relay
1 - Not Used
1 - DRL Diode
2 - Electronic Engine Controls Diode
Apr 06, 2011 | 2000 Ford Explorer
My boat Merc Cruiser V8 4brl, Thunderbolt IV 1978. Won't run well or idle, it back fires stutters and dies. This happens after it worms up. I rebuilt carb, cleaned out the old fuel, new fuel tank, Runs...
you need to replace your coil it is only about 15.00 it doe not sound like a fuel problem if the coil doesnt work you need to look at your cdi if you have the outdated box it will be mounted on the distributor it about a 1/4 inch thick 3 inches long and 2 inches wide with one flat plug going in it. before you do that change your plugsand wires wait im sorry i just saw the year of the boat now were getting somewhere you have a bad codenser if your boat has points under the distributor cap the condeser is the little siver cylinder while your in there you should just get a kit cap,rotor, button,points and condesor the points should be set at 25 to35 thousands i asume that 1978 is theyear modle if not like i said the new cdi box is out of date and very expensive $498.00 to be excact i would do a good tune up before turning to that but if it is a 1978 the distributor tune will fix your problem kit is about 70.00
Jun 27, 2009 | Boating
1994 940 volvo will not crank once engine is shut off. There is
take off cover to fuses in the centre consol reachin and push down the large black relay i get this myself on my volvo 940 1991 this relay does a number of things but to long to explain
Apr 27, 2009 | 1992 Volvo 940
Missing Fuses, Volvo S40
Where is the fuse located for the 12 volt accessory plug in the front passenger compartment?
Jul 13, 2008 | 2000 Volvo S40
Boating Logo
163 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
