Question about Canon PIXMA iP90 Mobile Printer
I have a new computer with Windows 7...tried to install my blue toothed iP90 printer and get message saying they don't support this printer.
    Sergeant:
  • 148 Answers
You have to download and install drivers from here..
Click on "Select OS" and chose "Windows 7"
If you are satisfied with my answer, be sure to click on the "Thumbs-Up". If you have further questions, please feel free to ask them. Thanks for using our service!
Posted on May 15, 2010
Unable to install blue tooth driver for windows 7 in my lenovo 3000 G430 series laptop.as i try to install the driver it gives me error saying no blue tooth device was detected.
Restart the laptop and check the bios. Make sure that Bluetooth is enabled.
For Fn-F5 to power on and off the wireless connections on a ThinkPad, you need the Lenovo Power Management Driver installed.
Just a couple of things to check.
Sep 25, 2013 | Lenovo 3000 Computers & Internet
Toshiba nb505 atom bluetooth driver
1) Go to the following link:http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=2861099&rpn=PLL50U&modelFilter=NB505-N508BL&selCategory=2756709&selFamily=2336267
2) go down and select your operating system3) click where it says "all categories" and select blue tooth.
4) two download links will appear. Download and install the second one first (driver package). Then if you have windows 7, download and install the first one (blue tooth stack) but only if you have windows 7. no need to install "BLUETOOTH STACK" if you have windows xp.
i hope i was helpful.
Sep 07, 2012 | Toshiba NB505N508BL 10.1" Intel Atom...
M500 not blue tooth
install software then plug it in
Nov 03, 2017 | Palm m500 Handheld
My ip90 says that cartriges are not installed properly. I have tried replace them, but get the same error. What could cause this?
mcdevito75 here, Don"t know too much about printers but the printer could have just gotton a wrong electrical message during change of Cartridges. Try to remove electric to the printer shut it down and re--start do this a;so with the vartridges out of the printer. Also check with Radio Shack, Staples for advice.
Jun 23, 2010 | Canon PIXMA iP90 Mobile Printer
I have purchased a ''Virtually Mint'' Canon Pixma ip90 printer however, when I try to print a document a message pops up stating ''the following ink tank is not installed: black ink tank, colour ink tank....
Hi there you can try.
Following step by step resetting canon Pixma iP90 :
  • Before resetting printer canon iP90, start with printer power off.
  • Press resume button coincide with power button.
  • While pressing power button, release resume button.
  • Press resume button 2 times and then release both button
  • Green LED indicator will blinking and then stopped blinking.
  • When the Power LED lights in green, press resume button 4 times.
  • Press power button and the printer power will off. Otherwise off, depress again power button.
  • And the turn on the printer again, your printer canon iP90 should be response as normal.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jan 21, 2010 | Canon PIXMA iP90 Mobile Printer
Can I use the same installation disk that came with the printer when I installed it for windows xp for my nre windows 7
No.
Instead, access the manufacturer's web-site:
http://www.usa.canon.com/consumer/controller?act=SupportIndexAct
Step 1: select "printers".
Step 2: select "Pixma iP series".
Step 3: select "Pixma IP90"
Click "Go".
Click "Drivers and Downloads".
Select "OS is Windows 7".
Download the appropriate "Guides" and "Manuals", and read them.
Download the appropriate device-driver.
Follow the instructions in the "Easy Setup Instructions" guide.
Nov 17, 2009 | Canon PIXMA iP90 InkJet Printer
Message saying color ink cartridge not installed
This is a common problem with the Canon IP90 printer. The printer keeps saying color cartridge not installed. The problem is caused by the small micro switch under the color tank. This problem is not common with new IP90 printers because ink has not had enough time to build up under the micro switch which will insulate the contacts. To cure this problem is very simple, unless you have screwed around the print head and busted the little micro switch clip off.then you really have a problem........
So if everything is still there and you haven't messed around to much.here is what the fix is.
First get a can of CRC Electronic cleaner for sensitive electronic equipment ,the quick drying formula.CRC#05102. This cleaner is safe and harmless to plastics. Do not use electricial contact cleaner it will disolve plastic.
First center the cartridge carrier,shut off power . Carrier should stay to center. Remove black and color tanks. In front of the carrier is a small print head button , push it in and up and the arm that holds the head in will release. Move the small metal arm up and remove the print head.
This will give you a clear view of the small micro switch. Using a long wooden tooth pick pack small pieces of paper towel under and around the micro switch and carriage.
The can of cleaner should have a long plastic tube nozzle so attach this to the spray head.
Point the spray tube right near the micro switch and spray a couple of short bursts . You will notice a lot of ink on the towel. Change the pieces of towel out ,because they will be wet with cleaner and ink. Two or three times is all that is required. Assemble and try it.
Jan 10, 2009 | Canon PIXMA iP90 Mobile Printer
CanonPIXMA iP90 Color Ink Tank installation problem
yeah it sounds like a cartridge sensors are stuck or broken. i would say to replace the whole print unit. It will need a service support dealer to fit this part unless you can buy it and fir it yourself.
part number: QM2-2020-020
hope this helps
Oct 20, 2008 | Canon PIXMA iP90 Mobile Printer
Blue tooth
just go to control panel and enable bluetooth in your pc ...if problem continues there may be some virus in your pc blocking the bluetooth connectivity check and remove it
Jun 14, 2008 | Computers & Internet
Canon PIXMA iP90 Mobile Printer Logo
57 people viewed this question
old marine
old marine
