Question about Casablanca Fan Bel Air Halo Brushed Nickel Ceiling
How do i install a new receiver for my casablanca avan touch bel air ceiling fan? I ordered the new part and have taken the light kit off. What now? There are 3 screws to go further into the housing but I can't turn them.
    President:
  • 1,561 Answers
I advice you add more pressure to it, exact more pressure to turn the screw, if you are still unable to unscrew the screws after applying more pressure, then you will need to add little slippery oil on the screws and its sides, slippery oil like engine oil is good for this, leave for some minutes and now try to unscrew the screws, no matter how, you should be able to unscrew the screws now.
After having access to the inner kit itself, look carefully to see how the wiring lay out looks like before decoupling anything, fix back the new parts with exactly the way you removed the faulty parts in the kit and couple back.
Follow all instruction in the manual strictly.
Take care.
Posted on May 15, 2010
Fan working but light won't turn off from remote
Call Casablanca @ 1-800-715-0393. It could be a bad light kit ( which can be replaced) or bad receiver.
Jun 01, 2014 | Casablanca Fan 3245T Ceiling
Finding a light kit for a casablanca 652T fan
That's an old model so I don't know without seeing a pic for sure. If it has three screws on the bottom plate,you have to use an older Casa. light kit or almost any Bowl light should work. fanman9952@aol.com
Mar 27, 2013 | Dryers
I have an existing Casablanca Lanai Fan Model 79669D installed in ceiling. Is it possible to install remote control after the fact?
yes they have a kit at all hardware stores, you will need to take down the fan to put it up it is easy just use two people works out alot better, good luck ps dont forget to turn the power off before starting
Aug 07, 2011 | Casablanca Fan CAS 79669D Lanai Ceiling...
I have a Casablanca "trident"
Hello Duke,
I'm guessing you have a "prime touch" remote control system. I'm not exactly sure whats going on but the W-505 Prime Touch receiver in the fan is the brains of the system. They sell replacement W-505 parts at Fan Man Lighting.
Hope this helps.
Feb 08, 2011 | Casablanca Fan Trident COSMOPOLITAN...
I have a casablanca ceiling fan 35G11R( old model) lost remote,
I see you have an R on the end of your model# R designates Comfort Touch. I would be interested in buying the remote control from you.
As for ordering the parts, refer to www.casablancafanrepair.com
Jan 26, 2010 | Casablanca Fan Advan?Touch W-62 Remote...
No remote control
I'm sure you can buy a new remote for that fan, but you will have to access the remote reciever in the fan itself so that you can get the switch sequence so that you can match it with the remote you purchased, it should work fine.
P.S. Dont tear the hell out of the package just in case you have to return the remote. I find the easiest way is to cut the plastic package close to the cardboard on three sides with a box cutter.
May 17, 2009 | Casablanca Fan Bel Air 3811T Ceiling
Casablanca fan speed problem
If this fan has a pullchain that also controls the fan speed, and you have a remote, the pullchain has to be set for the highest speed. If it is set at medium or low, it will mess with the remote operation. Note: usually high speed is the first pull after the "off" position.
Oct 27, 2008 | Casablanca Fan Bel Air 3811T Ceiling
Our casablanca ceiling fan has power going to the fan and the remote works but the fan does not nor does the light
If you have the intelitouch system, It's probably the circuit board in the fan. Casablanca has great motors but touchy boards. I ordered mine from www.fanmanlighting.com and installed it myself, it wasn't too difficult. Hope this helps
Jun 25, 2008 | Casablanca Fan 3245T Ceiling
Ceiling Fan broken
clean and grease the fan check the black cap to see if it is not fauly if it is replace it.if that does not work the ammeture is faulty time to buy a new fan good luck
Apr 27, 2007 | Casablanca Fan Bel Air 3811T Ceiling
Casablanca Fan Bel Air Halo Brushed Nickel Ceiling Logo
80 people viewed this question
Top Casablanca Fan Dryers Experts
Jerry Greenberg
Jerry Greenberg
Paul Bade
Are you a Casablanca Fan Dryer Expert? Answer questions, earn points and help others
