Question about Hotpoint Aquarius WF000 Front Load Washer
Error/fault code f08
What does this mean and how do i fix it
  • Anonymous Aug 18, 2008
    i dont have a manual taped to my machine, could you tell me what to do when it comes up with F08
    Genius:
  • 1,554 Answers
In the bottom access panel taped to the side is a service manual with codes
Posted on Apr 13, 2008
On a Whirlpool washing machine model # ghw9150p I have error codes E01, and F08 what or how do I find diagnostic code meanings.
go google and type in --fault codes for whirlpool washing machine model ghw 150p if one is available there will be a pdf version that you can down load
or go google and type in --workshop manual for whirlpool washing machine model ghw 150p
or you can make a call to an authorized service agent and ask what the codes mean
Oct 13, 2015 | Whirlpool Washing Machines
F08 error code
F08 error code: Door open when program started
May 01, 2015 | Bosch Washing Machines
Whirlpool washer wfe1485bd error code F08 what does this mean and is it easy fixed
It means there's not enough water supply pull the hoses and check the screens and make sure no dir is trapped in them
Jan 03, 2015 | Washing Machines
Fault f08
The heating element is gone open circuit. Replace element.
Error F08 means that the heater relay cannot be activated. Check connections on:
- pressure switch.
- heater element.
- control module.
If you still cannot get it to work, then you are probably going to have to call an technician service.
Hope this helps.
May 25, 2011 | Washing Machines
Hi I have a hotpoint wf630 washing machine and it keeps flashing error codes f08. Could you tell me what this codes means. many thanks, Stuart
Most Hotpoint, Ariston and Indesit (who make the other two) use similar fault codes. Although I cannot confirm it on your particular machine, f08 means there is a problem with the heater/its relay/its control. Often a cure is to re-seat the cables/wiring to and from these items.
REMOVE POWER BEFORE ATTEMPTING ANYTHING OF COURSE.
Good luck,
John C
Mar 09, 2011 | Washing Machines
What does "f08" mean on
The error F08 indicates that the heater relay is stuck. This could be a fault with either the pressure switch, heater or the module connections.
Think you need to book a service call from engineer.
Feb 06, 2011 | Hotpoint Ultima WF860 Front Load Washer
Came up on red service light with fault F08
Error code F08 is indicating that the heater relay is not being activated.
You need to check all the connections on the module, the pressure switch, and the heater element.
Dec 07, 2010 | Whirlpool Washing Machines
Hotpoint ultima WT965A fault code F08 what do i need to do to fix it please. wachine is full of water and i cant select any cycle to empty it.
To empty the washer, remove the drain hose from the outlet, and lay it down to floor level, this will let the water run out into a bucket or similar.
Code F08 is indicating means heater relay cann ot be activated.
Check all connectios to and from the pressure switch, the module, and the heater.
Hope this helps.
Jan 06, 2010 | Hotpoint Ultima WF860 Front Load Washer
Fault code '' F08'' what does this mean
The fault code F08 means that the heater relay cannot be activated. I would you check heater, and the thermostat for a fault. Replace them if required.
Let us know if you want any further clarification.
Thanks for contacting fixya.com
Dec 05, 2009 | Kenmore Elite 45986 Front Load Washer
F08 keeps flashing
probably heater relay cannot be actived, you will need an engineer.
Nov 18, 2008 | Indesit WA 125 Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
728 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
