Question about Dryers
My May Tag Atlantis dryer will not heat up - Dryers
  • Dryers Master
  • 7,482 Answers
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Sounds like your problem may be with the heating coil. Remove the back of the machine and try to
locate the air duct going from the blower to the drum. Normally inside the air duct you will find
the heating coil and the thermostats/thermistor. Once you have located the heating coil, remove
the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it
is faulty. If the heating coil is ok, then: You can check the thermostat/thermistor by removing
the two wires and taping them together with electrical tape. If the coil heats up then replace
the thermostat/thermistor. DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST. This could cause
a fire, as you have removed the safety of overheat from the machine. I will include these two web
sites for parts and further help:
http://www.partselect.com/ http://www.appliancepartspros.com/index.aspx
Both also have chat assistance 24/7.
Good Luck, Hope this helps
Please do not forget to rate me, Thank you
Posted on May 16, 2010
4 Suggested Answers
CMV9
  • 594 Answers
SOURCE: Maytag Atlantis dryer no heat
check the thermostat and heating element those are the main reasons a dryer will still work but no heat.
please do not forget to rate and comment about your experience on fixya.
Posted on Aug 17, 2008
localwonder
  • 6784 Answers
SOURCE: Maytag Atlantis electric dryer Model
Check the following to address this issue.
1. No power to the dryer
Make sure there's power getting to the dryer. Check for tripped circuit breakers or blown fuses. An electric dryer uses two circuit breakers or fuses, and if only one of two is tripped or blown, the dryer might still run but not heat. Sometimes the power cord disconnects or burns at the dryer, if this is the case, the wiring and the terminal block must be repaired or replaced.
2. Heating element
A burned out heating element will show no continuity when measured with a meter. Replace the element if found defective.
3. Thermal fuse
Most dryers have a thermal fuse, which burns out when the dryer overheats, in which case the dryer will either not run at all or stop heating. The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Posted on Aug 08, 2009
Illeagle
  • 525 Answers
SOURCE: dryer heats up ,then loses heat after 10 minutes
Based on your description, you may have a Gas Valve Coil failure. Below is a link, courtesy of www.repairclinic.com, showing the part(s) involved. http://www.repairclinic.com/SSPartDetail.aspx?s=b4a8c237i3479&PartID=3479
More assistance below: You will need your model number to access the information.
Model Number Locator Tip
1. A zero in the model number might be the letter O.
2. A lower case L might be a 1.
3. Some models have 3 digits and a period first, like this 555.66666666
Look for an aluminum tag--or a silver and white adhesive label in the locations illustrated below. The model number may be printed or stamped onto the tag and may be printed in different type sizes. NOTE: There may be partial model numbers on marketing stickers or in the owner's manual. These are often incomplete. For best results use the model number from the tag.
1. Parts Breakdown/Disassembly Procedures: http://www.repairclinic.com/Dryer-Gas-Maytag-Style-Appliance-Diagram
2. Diagnostic tips: If your dryer doesn't heat, check these:
Igniter
Gas valve coils
Thermal fuse
Igniter Modern gas dryers use an electric igniter to ignite the gas from the gas valve. When it's working properly, the igniter glows bright orange. When it burns out, the dryer tumbles but there's no heat because the gas can't ignite. When the igniter burns out, you need to replace it. If the igniter is held by a tension bracket, you very well may need to replace the bracket too.
The igniter is inside the dryer housing, near the bottom front, usually in a cone-shaped metal tube (the force cone). It's about 2 inches long. It's mounted to the far end of the burner tube, and it has two wires attached to it--or to the tension bracket, if there is one.
Gas valve coils Watch the igniter. Does it glow bright orange, then shut off without igniting the gas? (When the gas ignites there's a large blue flame.) If so, there may be defective coils on the gas valve. Mounted on the top of modern gas valves, there are black electrical coils. The coils, when energized, open the gas valve. If one or more of the coils are defective, the valve doesn't open and the gas cannot ignite. Because it's often difficult to properly test the coils, it's usually best to replace both (all) of them at the same time.
Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Posted on Aug 27, 2009
Maytag atlantis gas dryer not heating up
I thank you need a new Heating Element Assembly part # Y308612 here is a image of the Heating Element Assembly
Jan 20, 2013 | Maytag Atlantis MDG7400AW Gas Dryer
Why does my Maytag Atlantis dryer not heat up at all?
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Aug 08, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Atlantis MDG6400AW Gas Dryer: there is no heat...
heatman101
May 18, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
My maytag atlantis gas dryer doesnt get hot.
Hi this is Phil, I will help you determine what is causing the no heat situation in your dryer. To make sure I am directing you properly can you send me the complete model number, it will be on a tag that is located just inside the door or possibly on the top of the control panel.
The second thing I would like to ask is if the dryer heats at all or just blows cold air whenever it is on? Some drying problems will heat but not dry and some will not heat at all.
Thanks!
May 03, 2010 | Dryers
Maytag gas atlantis dryer. It starts but after a
I love the Maytag Atlantis!!! This sounds like your motor may be bad. It's NOT the element or it would not heat at all. Hope this helps!
Aug 13, 2009 | Maytag Atlantis MDG6400AW Gas Dryer
Maytag atlantis gas dryer, will start, heat up but then no heat
Try running it with the vent disconnected and feel the air coming out of the dryer. It should have good flow. If it dries good, your pipe may be clogged.
Mar 29, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag atlantis dryer does not heat
Perhaps the thermal fuse is open. All thermostats and thermal fuses should be closed for continuity at room temperature on this dryer.
Go here for more Maytag Atlantis Dryer repair help: http://www.repairclinic.com/0047_8.asp
www.RepairClinic.com
Feb 01, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
May tag Dryer
yor dryer might need new gas coils !
Nov 13, 2007 | Maytag Atlantis MDG6400AW Gas Dryer
Dryers Logo
Top Dryers Experts
