Not spinning, leaving cloithes kinda wet
I have aheavy duty kenmore washer 80 series that has stopped spinning which is leaving the clothes kinda wet
  • oldguy5 May 15, 2010
    Can you provide the exact Make, Model and Kenmore model number? .......... Kenmore model numbers use the format ###.######## with the first three digits of 110 for Whirlpool manufactured machines......... The model number on top load washers is usually found by lifting the lid and looking above the tub. The Fixya numbers are Stock Numbers. Since basic top load direct drive, top load electronic and front load washers are very different, the actual Model Numbers are necessary to correctly diagnose the problem. WILL IT DRAIN??? WILL IT AGITATE WELL??? CAN YOU HEAR THE MOTOR???? HAVE YOU TRIED A DIFFERENT CYCLE???
  • Washing Mach... Master
  • 43,501 Answers
Here is a tip that I wrtoe about washing machinesNot spinning, leaving cloithes kinda wet - 2_bing.gif that don't spin out right..
Washing Machine does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
heatman101
Posted on May 15, 2010
Washer doesn't rinse well. Doesn't spin water out properly.
Ok.you need tro make sure that its pumping out okay...if not check the filter..then pump..
Feb 21, 2010 | Washing Machines
Kenmore Series 80 washer NO High Speed Spin
It could be a timer, motor or wiring problem. You would need to check for 110 volts at the timer or motor when in the higher spin mode. If you are getting 110v you have a bad motor. No or low volts you have a bad timer. The motor is either a 2 or 3 speed motor and you would have to determine which winding to check for the 110v. The schematic is usually glued to the inside rear cabinet. Please rate this post.
Dec 14, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Agitator not spinning
agitartor stripped
you can order the dogs at sears
agitator dogs
Oct 04, 2009 | Washing Machines
80 Model will spin sometimes -with help- but never fast
Likely the out of balance sensor is bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 11, 2009 | Kenmore 24032\24036 Top Load Washer
Wet clothes
the reason the clothes are wet is the washer is not shifting to high spin,does the washer have a speed switch(normal wash spin,high wash spin)if its not the speed switch than the clutch is bad,how old is the washer?mike
Apr 19, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series washer not completly spinning clothes dry
Belt going..
A bit of a pain to replace, but doable..
Belt dressing will keep it going for a while..
Dont get your fingers caught in it..
Serious injury is possible, unplug the machine
and stand on the plug while moving the
belt to goop it..
(why? that way it cant get plugged in!)
Feb 07, 2008 | Washing Machines
Washing Machines Logo
114 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
