Question about Mitsubishi WS-55859 55" Rear Projection Television
Tv wont turn on
Hi! My ws-55859 55 inch mitsubishi hdtv wont turn on - the power light blinks and then turns off. How do I find the fuses to see if thats the problem? have exactly the same problem,same unit, WS 55859, wont turn on,production date 1/02. Unit was fine then just just down. Your help is greatly appreciated, Would even make donations for solutions TY Contact [email protected]
  • 5 more comments
  • Blyde Apr 04, 2008
    WS-55859: Had a tech out today ($170.00) and I still have the same problem. He re-soldered some suspect joints and replaced 2 capacitors. An hour after he left, the TV shut itself off again. He ask me to press the device and menu buttons if it occurs again and report the error code. The error code I received was 2-3. The document he left stated this may have something to do with Deflection Protection (loss of vertical or horizontal deflection). He did not replace the big IC or any fuses. Is this likely to be fuses or IC related?
  • Anonymous Apr 12, 2008
    My Mitsubishi WS55859 will not power on. When power switch is pressed, it turns on for 2 seconds then goes off. Any one can help, It will be much appriciated, I just can't buy a new TV now;
    ANS
  • Sgt_Hoit Aug 07, 2008
    I have a similar problem. While watching TV, it will turn off by itself. If you try to turn it on back on you can see the green light for about 2-3 seconds and the TV will turn itself back off. A picture doesn't appear, you just get kinda like a horizontal flash to the center of the screen, and the light goes off. If you wait a little while (30 - 45 minutes), you can get a picture, but it is kinda bouncy / jittery, and then it shuts off. The really strange thing is after a few days of trying to get it to stay on it will work correctly for about a week and then the whole thing starts doing the shut off thing again... Help...
  • bluedragonmt Aug 13, 2008
    HAVE NOT HAD TV ON FOR ABOUT 5 MONTHS. WAS WORKING FINE BEFORE. HAVE HAD ABOUT 6 POWER OUTAGES. WHEN DOWN TO TURN TV ON AND WILL NOT TURN ON. GETTING THE GREEN BLINKING LIGHT OF DEATH AS I HAVE READ OTHERS DESCRIBE. WHAT CAN I DO?
    [email protected]
  • rosey627 Aug 19, 2008
    MIne does the same thing....purchase date 2001, any solutions? [email protected]
  • villan1 Aug 25, 2008
    I push the power botton and the lil green light turns on, within a second it turns off. purchased 2002.
  • april78244 Aug 28, 2008
    i am looking for the dm module the tv won't turn on power light keeps blinking it's a mitsubishi 2002 and a repair man looked at it and he says this is what i need he says they don't make this part anymore so i'm looking for a used part which is the dm module for a mitsubishi ser. # 111477 and model ws-55859.
  • 149 Answers
Ok is in shut down mode kine of proteccion some of the fuses are pico fuses but you may have problem with convergence IC's that what I' check first if that is ok go to HVT .. if U still have problems e-mail me
Posted on Apr 01, 2008
6ya staff
SOURCE:
I have a WS-65907 tv, it wont turn on
Mitsubishi self check: MOST OF THESE SETS HAVE A SELF DIAGNOSTIC:
UNPLUG TV AND THEN PLUG BACK IN---TURN ON---GREEN POWER LIGHT COMES ON FOR A MOMENT AND GOES OFF.
PRESS AND HOLD "device"(input) and "menu" buttons on front of tv for at least 5 seconds and then release both together.
Watch for power light to blink in a sequence:
1 blink-then 2 blinks-------no error
2 blink-then 1 blink-------X-ray protection
2 blink-then 2 blink-------SHORT PROTECTION*******
2 blink-then 3 blink---------deflection circuit problem
2 blink-then 4 blink---------vertical circuit problem
******2, then 2 is most common---usually means one of the fuses that protect the Convergence IC or IC's is blown---set will detect no voltage to convergence IC and shut down.
SET WILL REPEAT BLINK ERROR CODE UP TO 5 TIMES AND THEN TO GET IT TO REPEAT MORE YOU HAVE TO UNPLUG SET AND TRY TO TURN ON AGAIN.
IF IT IS 2 AND THEN 2---USUALLY
CONVERGENCE CIRCUIT PROBLEM
let me know what you find--hope that you find 2 blinks, a pause and two blinks--this is the most common and easiest to fix.
Oct 30, 2012 | Mitsubishi WS-65907 65" Rear Projection...
Turning off when trying to turn tv on..
If power light comes on for a few seconds and then goes off: On the front of the set press and HOLD both the menu and input (device) buttons at the same time for at least five seconds and then release both.
The power light should blink a two digit error code: 2 blinks, a pause and 2 blinks is the most common.
Tell me model number and what error code you find and I will tell you what it means and if possible what needs to be done.
This is a self check feature all WS model numbers had.
SD TECH
Apr 27, 2010 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi WS 55807 wont turn on
SECONDARY POWER SUPPLY IS OUT
Dec 05, 2009 | Mitsubishi WS-55807 TV
I had a power outage and now the tv will not power on. This is for a 55" Mitsubishi WS-55511. no green blinking lights.
You may have a blown fuse. Unplug the TV and remove the back. Look for a small fuse near where the power cord goes in.
If it is blown that may be the problem.
Use a magnifying glass to read the AMP rating.
replace the fuse and plug it in. If the fuse blows again you need expert repair services.
If the fuse doesn't blow then try to turn it on.
If it turns on then check the operation of the TV.
If the fuse blows again or the TV won't work correctly then you need expert repair service to fix your TV.
You may be able to have your household insurance pay if it is damaged by lightening or a power surge.
Lee
May 02, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi Big Screen Digital 65 inch
you have a short in power supply the light should stay on check all power supply parts
diodes,power transisters
you need to test all parts, i could fix this in
30 mins
need help call 0403960527 jeff......
Feb 16, 2009 | Mitsubishi WS-55807 TV
Blinking green light, will not power up
my 55613 tv wont turn on just blinking green light
Sep 18, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Mitsubishi WS-55857 won't turn on
Thank you for posting your concern details however i would be needing few more details from your side if necessary and allow me few mins to come up with the resolution.
May 19, 2008 | Mitsubishi WS-55857 55" Rear Projection...
Mitsubishi Medallion HD 1080 model ws-48413
my mitsubishi medallion tv wont power on.
all I get is a blinking light. How can this be fixed
May 08, 2008 | Mitsubishi WS-65413 65" Rear Projection...
Tv wont turn on
This problem very well could be a DM board problem. I have a how to fix file if this is indeed your sets problem. Leave your email and I will send it to you. Good Luck
Jun 15, 2007 | Mitsubishi WS-55859 55" Rear Projection...
Mitsubishi WS-55859 55" Rear Projection Television Logo
249 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
