Question about Proform CrossTrainer Treadmill
My treadmill's belt ripped in the middle, I don't know the model #, it only says proform 350s on the machine. Where can I get a belt from. I bought my treadmill at Sears
    President:
  • Proform Master
  • 832 Answers
Walking belt P# 206569 Cost $95.43
This can be purchase form iconfitness@ 1-800-999-3756
Posted on May 15, 2010
Proform 345s stripes on the walking belt. Powdery residue on the floor below the belt. Everything functions normally, and the belt is properly aligned.
1) this a normal problem. However you must know that you must LUBE the deck belt every 5hours aprox, in according with the use.
2) You must check the tension in deck belt aprox 3- 4"High aprox from the middle.
God bless you
Nov 14, 2012 | Proform Crosswalk 345s Treadmill Walking...
My proform 350s crosstrainer turns on but belt has stopped. trouble checked using the voltage diagram....all lights on board show as they are supposed to. help, please.
Dear Sir:
The problem is a worn treadmill belt and deck.
Most of the time not lubricating between the treadmill belt DECK vs deck. This causes friction and the surfaces wear putting greater stress on the electronics. The treadmill is shutting down to protect the electronics.
Try to RUN the software calibration for easy diagnose +trouble
See my personal TIPS for HELP
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Mar 13, 2012 | Exercise & Fitness
How do you adjust the belt on the ProFrom 350s. It'swanting gradualy drift over to one side (Left). Thank you
There are Allen bolts on both sides of the base, on the end away from the console. Turn one bolt one way the other the other way to move the belt from side to side.
Aug 10, 2011 | Proform CrossTrainer Treadmill
Proform 350s crosstrainer treadmill; surges 3 MPH to 4MPH
Walking Belt is Worn: The only certain way to test for a worn walking belt is to take a DC amp draw (if you have a DC treadmill) or an AC draw (for AC). Trying to look at the belt or a feel test is highly unreliable. Better tests, if you lack a DC ammeter (they are expensive for a good one), are a coast test or an incline test. The coast test is to get on the treadmill as the lowest incline setting and walk on the treadmill at 3 MPH. Pull the safety key and it should take you 2-3 full steps to stop (this is a general rule…some like a few Tunturi models stop on a dime even with a healthy belt but for most models, this tests works well upon). Fewer steps indicate high friction. The incline test is to put the treadmill at max incline and walk on it at 3 MPH. If the treadmill operates normally at max incline but bogs down at minimum incline, replace the walking belt. Gravity takes over for the drive system eliminating much of the friction problem. On some heavily worn walking belts, this test will not eliminate the problem. Go to your local hard ware store and purchase silicone spray. Apply Lubricant by lift one side of the running belt spray contents length wise starting at motor shroud to the back end repeat this process on the other side. If this unit bogs down again then you will have replace the running belt and possibly the deck
May 27, 2010 | Proform CrossTrainer Treadmill
Treadmill stops when I step on it?
your running belt might b on 2 tight or u dont have enough power going 2 the motor make shure u have a designated power line 2 your machine
Dec 20, 2009 | Proform 730 Folding Treadmill Model...
Proform CrossTrainer Treadmill Logo
190 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
