Question about Frigidaire GL30LKEC (LP) Grill
I am having troble replacing an ignitor switch on a charcoil gas grill
  • Frigidaire Master
  • 2,597 Answers
Buy a lighter from homehardware for $2 works just as well,
Posted on May 16, 2010
How do I replace ignitor switch in thermos gas grill, if this is what is what I saw?
If that white is ceramic, I think it is the actual ignitor, not the switch.
Apr 29, 2017 | Thermos Stainless Steel Gas Grill
The ignmition switch stays down when I push it and does not pop back up. bhalupnik@msn.com
the switch spring will go out often in the push button types. it is two wires you will have to disconnect and reconnect when you buy a new one like such --> ( http://www.csgrills.com/Common/Product/CatProduct.aspx?ID=186243&Src=GoogleBase&SrcID=2248467 )
Mar 23, 2011 | Weber Genesis Silver B Grill
The electronic ignition on my grill no longer sparks to ignite the gas. I replaced the battery and cleaned the contact points but there was not any improvement. Can the entire assembly be replaced?
Yes you can replace the entire assembly.
However you can try adjusting the spark gap to see if this will resolve the issue.
Heat will often expand the spark gap thus rendering a spark impossible.
Small adjustments and be careful not to break the ceramic insulator.
Many gas grills use a static ignitor that does not require a battery.
Big red button you push that causes a snapping noise. This makes a spark and lights the gas. These can last quite a long time and inexpensive too.
Oct 03, 2009 | Weber Genesis Silver C Grill
Replacing ignitor battery
Has it got a battery or has it got a Pitzo crystal? They eventually wear out, you may need to replace the ignitor button unit.
Jun 09, 2009 | Kenmore 555 sq. in. Cooking Area Gas Grill...
How to replace ignition switch
where does the ignitor switch plug into ? genesis ....came unpluged
May 21, 2009 | Weber Genesis Silver B Grill
Grill won't light. We press ignitor switch, and nothing happens
Have you replaced the ignitor? Also check the spark and make sure that it is sparking where the gas is coming out
Apr 24, 2009 | Kitchen Ranges
Gas grill ignitor no longer ignites burners
it is bad you need a new igniter, the flint part goes bad
Feb 20, 2009 | Grilling
When I try to light my jenn air gas cook top it clicks but will not light. But it will light with a match
Your electronic ignitor is bad. You can buy a replacement ignitor where you bought your grill. Just about any hardware store will have a replacement ignitor. They are real easy to replace. There is 1 wire to the back of the ignitor. There is a retaining nut on the switch. Remove the switch and replace with new switch. Plug wire into ignitor, Turn gas on and test ignitor.
Happy Grilling
Please rate this solution
Jul 31, 2008 | Jenn-Air Kitchen Ranges
We bought our grill last summer and it worked fine. When we got it out of the garage this summer and replaced the gas, it wouldn't start. We can smell the gas so we know it is reaching the burners.
this sounds like an ignitor problem to me. You could replace the ignitor or you could light with a match. Most of these grills have an access point usually on the right side to light the burners with a match just make sure you light the match first and hold it into the access point before you turn the gas on.
Jun 20, 2008 | Char-Broil CharBroil 4637318 Grill
Gas grill ignitors
Check the electrode.  That is the end at the burner.  It may be corroded and no longer creating a spark.
Jun 05, 2008 | Weber Q300 Grill
Frigidaire GL30LKEC (LP) Grill Logo
Top Frigidaire Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Dan Webster
Dan Webster
Are you a Frigidaire Grilling Expert? Answer questions, earn points and help others
