Question about Microwave Ovens
How do i increase the flame on the pilot lights for the burners on a "premier" 30" gas stove?
  • cynthia miller May 15, 2010
    Thanks, that was the perfect solution! Except the oven adjusting screw was almost totally obscured from sight. The one for the burners was in plain sight & a snap to adjust. thanks again for making my life a little easier!!
Lift the top of the stove and follow the two aluminum tubes from the pilots back to where they both come together, there will be a small screw that you screw in clockwise to turn them down. On some stoves this screw is under a piece of tin that runs across the front of the stove. There will be a very small hole that you can put a small screwdriver through. The screw never seems to be directly under the hole and takes a bit of fishing to find the screw slot. The oven pilot can also be adjusted same as above follow the aluminum tubing back til you find the adjustment screw. The oven has a primary and secondary pilot the primary is the standing pilot and when you turn the oven on the pilot gets larger [secondary pilot] and heats a thermocouple up which allows the main gas valve to turn on. If you adjust the oven pilot down too low the secondary pilot will not heat the thermocouple enough and the main burner will not turn on so you will have to check this when adjusting.
Posted on May 15, 2010
I have a maytag super capacity plus stove and need to adjust the air mix for the burners. How to do it? Please help thanks
Open the top of the range. I believe there are a couple of spring clips in the front between the range top and the top of the door. Not sure on the Maytag. However, when you get the lid up, (it should be hinged at the back), set the burner pieces back on. (These burner pieces HAVE to be there or you'll just have a blowtorch pointing up!) You'll see that going to every burner there is a tube to carry the gas. on the side of every tube there will be an adjustable, sliding air vent. They are usually held in position by a set screw. Loosen the set screw. Light the burner and carefully slide the vent closed or open to adjust how much air is being brought into the mix. If the flame is way too high and or orange in color....you have too much air. You want as much flame as possible on high without the flame being orange or white-ish. Once you get the flame the way you like it, tighten the set screw back. Hope this helps.
May 15, 2011 | Microwave Ovens
I am painting in my kitchen and it is recommended to turn off stove pilot gas so know combustion happens. I have a Tappan gas stove that says "electronic ignition" on it. How do I turn off...
If you have an electronic ignition, there are no open flames. So you are ok to paint. Just make sure to not turn anything on while the paint fumes are in the air and you will be good.
If you do want to turn off the stove, unplug it from the wall. To turn the gas off you will need to pull it away from the wall and turn off the valve behind it, if it has a valve, some do not.
heatman101
Apr 23, 2011 | Microwave Ovens
When stove is on a yellowish orange flame comes from burner.This has not occured until now. We own this viking oven for about 10 yrs without any issue whatso ever. Can you help to resolve this issue
You need to replace the burner if you want blue flame. Since its 10 years old, it's about time to replace the burner with similar size and shape. Old burner have big hole causing yellowish flame compare to new one.
I hope I solve your problem.
Mar 30, 2011 | Microwave Ovens
All 5 burners are burning orange-yellow flames.
According to this thread:
http://www.dslreports.com/forum/r23696179-Gas-stove-orange-flame
It sounds like it is impurities in your (or more likely your suppliers) gas line. If it goes away but reoccurs semi regularly, then I would guess this is what it is.
If it is happening all the time, or you are concerned about it, call your gas company and ask them about it. I am sure they havve heard of the problem before.
Good Luck!
Mar 03, 2011 | Microwave Ovens
The gas flame on my 4 burner Chambers stove top is very low. When we try to adjust the air flow the flames increase for a moment but then return to being low. What could the problem be and how can we fix...
I had the same problem after a melted butter accident... I shut off the gas under the stove by a valve. Then I took the burners off and cleaned every orifice I could find. Still no luck. Then I cleaned out the main orifice right out of the controls for the burners, it was tiny and had to get a very small pipe cleaner made for an air brush gun. That did the trick! But now I have soaring flames and I'm trying to figure out how to adjust them back down.
Jan 11, 2011 | Microwave Ovens
When one of the gas hobs is on ,it does not burn with a blue flame but a more yellow one .also black soot forms under the burner plate.it is on lpg
Have to adjust the piolot lights for the amount of gas coming out. U have too much gas coming out(yellow flame). On older gas ranges, there was a small screw between the piolot light & burners that had to be adjusted. (if this is a older model) have to turn the screw just a little at a time, till ur flame returns to blue on ur burners. Hope this helps.
Sep 12, 2010 | Microwave Ovens
I have a kenmore stove whose burners wont light. oven works fine. burners will spark but no gas comes out. recently I turned off the power to the stove by turning the fuse off. what do I need to do to get...
If the gets give no gas then sounds like a Thermocouple, this is a device that allows the gas to come on after a period of time ensuring that the pilot is lit and heated up this thermocouple, once it heats it then allows gas to enter and ignite the main burner..hope this helps ,please leave feedback.
Apr 12, 2010 | Kenmore 66469 / 66462 / 66464 Microwave...
Hi! I am converting my Maytag oven to propane from natural gas. I've flipped the cap at the main (n to lp) and snugged down all the orifices at the four burners, so far so good. But I am not sure if the...
Hi Kim,
First of all, read and follow all the safety instructions in your installation and operations booklets.
If Maytag recommend that only a certified gas fitter should do this conversion, then follow the advice.
If you are a certified gas fitter you would know the answer.
There are too many variables to take into account for this type of conversion like altitude, propane pressure regulation, age and wear of the stove, state of repair of all supply pipework, proximity to open flames in the area like water heater pilot lights. Leaking propane is heavier than air and will collect at the lowest part of the home like the basement where the open flames might be.
So my best advice is to ask a certified/ticketted gas fitter to do the job or check what you have done and ensure that everything complies with all local codes.
"If in doubt don't" is great kindergarten advice for everything which is potentially risky.
I hope this helps,
jenni.
Sep 09, 2009 | Microwave Ovens
Stove won't stay lit!!
So, you cleaned the burner per the manual (or the one you looked at when visiting the appliance store,) and it still flames out right after coming on? Sometimes things catch in the works and there are a few methods to clear them out (e.g. at the controls) depending on the model. Beyond that,in order to disconnect the stove and check the inlet filters, you might want to call the appliance or gas co for a technician. No use having leaks, searching forever for the main shutoff valve, etc.
Mar 24, 2008 | GE XL1800 1100 Watts Microwave Oven
Microwave Ovens Logo
35 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
