My unit wont turn on
My dvd player doesnt wont to turn on. I tried switching outlets and opening it up and seeing if anything is wrong. Im running out of ideas.
  • 6,993 Answers
from my experience, I think your player is having a power problem. It must have received excess voltage/irregular power supply which has damaged an IC or capacitor on the power board of the player.
Sometimes this excess power supply might damage the player's main board. This is why it is advice able that you use step down for your player, because DVD player don't need excess power as something might be damaged.
To solve this problem, you will be needing a meter. Open the player, use the meter to read the components on the power board as it will help you discover the component that got damaged and you can then replace the bad component.
But if you do not have the knowledge of fixing this problem, you might be needing the help of a service technician.
Take care.
Posted on May 15, 2010
MY MEMOREX DVD PLAYER suddenly WONT TURN ON?
Unplug power cord, wait 30 sec. Plug back in. Worked 4 me
Mar 20, 2011 | Memorex MVD2042 DVD Player
Just hooked up my new Magnavox DV220MW9 DVD Player ? VCR Recorder. I was able to set the time and a vcr timer program but now I can't switch the source. It now comes on as the DVD but neither the remote...
You need to release the timer to access the VCR. Press the Timer Set button on the remote or the Stop/Eject button on the recorder. Then press the VCR button.
Please note: the scheduled recording will not run as programmed unless you press the Timer Set on the remote again. (The timer locks the VCR until the scheduled ON time.) The DVD player is controlled separately and becomes the default unit.
I hope this helps.
Oct 04, 2010 | Philips Magnavox DVD/VCR Dual Player
It wont play anything just says wrong disk no matter what then it wont open or turn off
it is a big problem. this type of problem coming from optical laser unit if it is weak to read data from disk. so u have to change the unit.
note: if u don't have any idea how to change then please contact with qualified service technician.
thanks
Oct 06, 2009 | Protron PD-800 DVD Player
1995 acura legend wont start
assuming the engine run good and nothing wrong with it, check ignition relay, can get them from junk yard if need to replaced them and will cost you barely nothing. my guess would be your ignition switch, it tend to wear out over time and loose contact. the unit is not cheap to replace and is common to some vehicle over time, some has better luck than others; this part run some where around 340-350 bucks. you can try to take ignition unit apart and jump the wire to see if that the problems. ignitions switch is like a master switch, if it faulty, it will not turn anything on, it seems like the battery is dead or something is disconnected. try this first before you decide to take ignition column apart, the next time it wont start, try to jiggle, wiggle and play with ignition unit with the key is in it, turn they key back and forth, try until the car turn on or start and see if that work. you have to play with it for awhile, if its faulty, it will also be stubborn.
Sep 25, 2009 | 1995 Acura Legend
Dvd player just freezes and wont do anything
I suggest the garbage can. I bought my husband the DVDR05 and it has not worked from day one. It will play about 15 minutes and then freeze up. We have read the book to see if it was something we did wrong. We finally shut off the tv and turned the player on before turning the tv on and we got half way through a movie that way. It is very upsetting.
Apr 22, 2008 | Yamaha DV-S5350 DVD Player
Dratted Coby TF-DVD7100 Portable DVD player not working!
Its defective. Coby doesn't repair the units. The lense is off balance which is causing the laser to not read the dvd/cd.
Apr 17, 2008 | Coby TF-DVD7100 Portable DVD Player
Wrong Disc
I work for Coby technical support.
Thanks for using FixYa.
If the unit is showing "wrong disk" on every disk that you try to play, unfortunately, the unit has developed a defect and needs to be replaced. It can not be repaired. Our warranty is 90 days from the date of purchase. If you received the unit as a Xmas present, please call 1-800-727-3592 for instructions on getting the unit exchanged.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may better assist you. If there is anything more I can do to help, I will!
Aug 09, 2007 | Coby TF-DVD7005 Portable DVD Player
DVD Player not working
i have dvd player, but me inser disk. then dvd told me error disk, then me inser another one disk, same reply, waht i can i do?
Apr 03, 2006 | Sony D-VM1 Portable DVD Player with Screen
661 people viewed this question
 Grubhead
Grubhead
