CarGurusMar 17, 2013 - 93 toyota previa having white smoke while starting and stu-off while running on the road. ... Lift the cylinder head off the engine block and move to oneside. Remove the ... 1992 Toyota Previa 3 Dr LE Passenger Van ... was going down the road one day and it just shut off. it will turn over but wont crank.Missing: water
repairpal.com > Questions > Toyota > Previa > 1994 Toyota Previa
1994 Toyota Previa Questions ... Idle is perfectly smooth for first 1 - 2 minutes after overnight cold start, before .... This may be because the throttle position sensor is signalling just off idle. .... My check engine light came on with PO-420 code. ... theengine was turning over under starter motor that would bring the engine to an ...
www.toyotavantech.com > Forum > Technical Discussion > Toyota Previas
Dec 3, 2011 - 20 posts - 2 authors
Okay, so you've got a Toyota Previa with a blown head gasket. ... The next few pix are taken after dropping the engine out from the bottom using a ... You can see a definite path between the water jacket and the cylinder. ... I believe this was a result of #1blowing and over pressurizing the cooling system.
Did you prime the new pump with some engine oil? Another trick is to use some light grease to coat the pump gears so they will seal against themselves. If you primed the pump and are sure the pump is working, you may have worn out engine bearings or some internal oil leak that is keeping the oil from getting pressure.
try to change the trans oil and filter possibly need to change, looks like a transmission shift solenoid is the problem or trans computer the oil and temperature will get it last longer also but would likely recommend to have it diagnose by a transmission specialist to fine what causing it
have the oil pressure checked ... if you are not using too low a viscositity of oil (the weight) you might be able to use a thicker weight oil to raise the pressure.
the oil should be black,brown or gold(new) with no other colors in it. shouldnt be milky or streaky. the trans fluid should be light red or semi light red.as for the engine being oily its hard to discern unless you rinse it off to metal and drive it. if you mean the oil pan has black oil on it then it may be ok.
remove the the diff unit and refit into your casing ,,,easy job,Preload on pinion bearings and set crownwheel backlash to a very small wiggle woggle.handful of LM grease in unit before you refit cover then use ep90 gear oil .job done shouldnt take more than a morning to do.
When you say "warning light is on", I assume you are not talking about the oil pressure gauge...
If not, here is your solution:
What you have is a very common problem: The oil LEVEL sensor has failed. Previas have 2 sensors; pressure & level of the oil in the pan...What you need to do is replace it, Toyota part number : 89491-28030.
BUT...This part is $380.45. Not cheap; Sorry but true.
