Question about Light Outboard Motor Boat Bass Fishing Saltwater Base
How do I drop off the lower unit on my 70 hp evinrude engine? I believe the shifter fork is worn.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Light Master
  • 1,190 Answers
Below the carbs is the shift rod and take the small pin out , then remove all bolts that hold the gear case to the leg then drop the unit and place in a vice to hold by the skeg fin below the prop ! normally its the edges of the gears and the central slide clutch that wear, remove and have re cut at machine shop ! saves buyin new gear set !! check all linkages ok for wear FIRST though !!
Posted on May 26, 2014
I have a 50 hp Johnson outboard or do I disconnect the shift linkage to get the lower unit off
have a look at the videos
How to remove the lower unit on a outboard engine - YouTube
? 3:24
https://www.youtube.com/watch?v=R6wVMc8GD0w
Mar 29, 2015 - Uploaded by Greg Drinkwater
How to remove the lower unit on a 1989 Johnson 88 SPL Help me remove lower unit. Johnson 90 hp ...
Johnson 50hp Outboard Lower Unit - YouTube
? 2:15
https://www.youtube.com/watch?v=DnU7vKcJkeE
Apr 9, 2016 - Uploaded by Stacy Wyoming
Removing Bearing Housing From a 50 HP Evinrude - Duration: 2:15. Brandon's Garage 274 views · 2:15 ...
how to remove lower unit on johnson outboard - YouTube
? 0:47
https://www.youtube.com/watch?v=_ygxZSxU6-I
May 24, 2016 - Uploaded by 2222buster2222
How to remove your lower unit on a 1984 Johnson Outboard 70HP.
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump ...
? 24:26
https://www.youtube.com/watch?v=Hv8gXqsO2fg
Jun 3, 2015 - Uploaded by Ralph Pierre
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump Service. ... Just bought a Bass Tracker ...
50 hp Johnson outboard remove lower unit Google Search
Jul 07, 2017 | Johnson Boating
What size and year is this E70 TLCCA
Douglas, Outboard appears to be 1988, 70 HP. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Find 1988 Evinrude E70TLCCA 70hp Outboard Motor Parts by Engine Section
Evinrude Johnson outboard parts Drawings How to videos
1988 Evinrude E70TLCCA 70hp Outboard Motor Google Search
Jul 03, 2016 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
I have a 1998 model E25RMECA I NEED TO KNOW WHAT TYPE GAS TO USE IN IT. AND IF IT IS 2 CYCLE OR 4CYCLE.
I found a mixture of sites for the information
one owner of a 1998 25 hp evinrude says that it is a 2 stroke with a fuel mix ratio of 50:1 as 25:1 is a bit smokey
another site says that the recommended octane fuel rating is 87 although it might run better on 91
best advice is to find an evinrude service dealer and get the right information as the later 25 hp units are etec engine which will be 4 strokes
Oct 23, 2015 | Clymer Evinrude/Johnson 5-70 Hp...
I have a 1975 70 HP evinrude it runs great on land
With this little information I would say you are not hitting on all cylinders. The motor not you. Pick up a plastic fuse pulling pliers at a hardware store. Start the engine on a flush and remove one plug wire at a time and listen to the drop in engine speed. If there is no drop, the cylinder is not firing. It helps if you remove and reinstall the plug boots before you start the engine as they can be hard to remove. be careful, the spark can hurt.
Aug 28, 2014 | Boating
Year model serial number
1978 It is in the model on an Evinrude. 6804.... 6 HP.....1978
Jul 22, 2014 | Clymer Evinrude/johnson Manual 2 Stroke Ob...
1997 Evinrude 50 HP SPL. I have removed all the bolts holding the lower rnd to the engine, it seems to be hanging up on the shify shaft, and I can't find a way to drop the unit. It drops down about...
Okay this is on total memory. The shift shaft for a lot of those engines goes right up through the pilot shaft and exits just in front of the block under the carburetor(s). You will see the **** linkage arm connected to this shaft sometimes it's double nutted. See if you can slide the lower unit back up to the housing and put a bolt in it to hold then undue the shift shaft linkage, Remove the bolt and drop the lower unit. Be careful of the water tubes and check make sure the rubber grommets are in place in the pump housing not on the tubes. Clean up the pump housing and install the new impeller kit.
Put the impeller down the shaft on top of the impeller plate, lightly grease the inside of the housing the impeller plate and impeller. Then lower the pump housing down to the impeller while turning the drive shaft clockwise lightly push down on the impeller housing. This will fold the impeller blades all in the correct position and provide lubrication to the pump until the water gets into the pump. To make life easier re-grease the drive shaft spline and the water tube grommets this will ad ease in reinstalling the lower unit. be careful to make sure you thread the drive shaft, water tubes and shift shaft all in at the same time. After installation you may find you need to adjust the **** linkage.
Dec 11, 2010 | Boating
Where does the water exit a 1971 25 hp evinrude? how do I know it's pumping water?
I do believe the water jets are down on the lower unit by the prop. There should be a white swirl of white bubbles shooting out.
Apr 16, 2010 | Light Outboard Motor Boat Bass Fishing...
Need to change impellor on 1988 70 hp johnson how to please
first go to www.crowleymarine.com to get a picture breakdown of your water pump. website instruction, click on part catalog tab, click on omc Johnson and evinrude tab. choose product line, year tab, engine size, choose model. click on gearcase. the picture showes all parts you have and the correct order they go. ok now we are ready to disasemble the lower gearcase from the motor.(1) trim the outboard down using the tim and tilt system (2) shift remote control into forward gear, this lines up the shift rod so you can reach it. a picture of the linkage is refernce number 50 on the picture from crowleymarine.(3) Remove engine coul, under the carburators you will be able to see the shift rod. if you can't see it follow the shift cable to the shift linkage to the shift rod(4) the shift rod has a hole in the top, that a long screw goes through, connecting shift rod to shift linkage. remove this screw(refer to picture downloaded)(5) again refer to the downloaded picture remove these bolts that i list. number 66 there is 4. #77 there is 1. pull off #76 trim tab.#68 there is 1. #70 there is 1. lower unit will drop after you remove all bolts. remove the impeller housing. look at impeller you will see the fins are bent in one direction. put new impeller in with fins bent in the same direction. reinstall housing and gear case following my dirction in reverse order.
Oct 05, 2009 | Boating
Light Outboard Motor Boat Bass Fishing Saltwater  Base Logo
195 people viewed this question
Top Light Boating Experts
ray gallant
fordexpert
ka4iup
ka4iup
Are you a Light Boating Expert? Answer questions, earn points and help others
