Question about Honeywell Enviracaire Elite F300E-1019 Air Purifier
Light not on in front of filter . Its a Honeywell Electronic air cleaner and I cant tell if its working because light is off.
  • 99 Answers
Neon light on air cleaner does not come on
1. Make sure the furnace or air conditioner fan is running.
2. Make sure the access door is firmly closed.
3. Make sure the On-Off switch is in the On position.
4. On models without the Solid State Performance Indicator, if the electronic cell(s)
are wet, check again in two to three hours.
Link: Manual
Posted on May 25, 2010
Have honeywell air geius 5 can't reset filter lights
Hello, this is Ava with Think Crucial.
Make sure that the new filters you installed are undamaged and correctly seated in it's assembly. When resetting the unit, unit must be powered on then press and hold the appropriate filter indicator button for approximately 10 seconds until the light turns off. If nothings happens, unplugged the unit from the power for about a minute and then try to reset the unit. If all else fails, I would suggest to contact Honeywell for more assistance.
You can purchase a wide variety of high quality Honeywell replacement parts for your Honeywell Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.thinkcrucial.com/search?type=product&q=honeywell
I hope this was helpful.
Ava B.
Think Crucial Customer Care
Feb 15, 2016 | Honeywell Airgenius 5 Air Cleaner/odor...
Loose Fins on Electronic Air Cleaner Cell
I would use hot melt glue to hold everything in place. The air cleaner works by charging the air particle at the front and there is high voltage on the plates. The polarity of the plate alternates where the first plate is positive, the second is negative, the third is positive, forth is negative, etc .
With first wire in front charging the dust particle, the plate attract the charged dust particle to the plate to capture it.
Jan 14, 2014 | Honeywell (F50F1032) Air Purifier
My Honeywell Type No. F50A Electronic Air Cleaner arced continuously even though I had cleaned it a few days prior. I shut the unit off and removed the air cleaner cells. Is it safe to run the furnace...
Yes you can run the furnace with out the electronic air cleaner for awhile.... It you are in a very dusty conditions than I would not run it very long a day or two....because you will not have any protection for dirty getting stuck on the evaporator coil or if you have a 90% gas furnace the secondary heat exchanger...and restricting air flow.... You can put in a 1" pleated air filter the same size as the total of the two cells in place of the cells till you can get the electronic working..... Sounds like either something big is caught across the cell plate or they are still wet and have not dryed out completely. Hope this helps.
Mar 02, 2011 | Honeywell (F50F1032) Air Purifier
Honeywell Furnace Air Filter clicking noise after cleaning it
I also have this problem as soon as I pt a new filter in - does anyone have a clue what this problem is?
Apr 09, 2010 | Honeywell (F50F1032) Air Purifier
I have an F50f electronic air cleaner. none of the
you need to change the power supply please contact your heating and cooling contractor for service on the unit.
Mar 03, 2010 | Honeywell (F50F1032) Air Purifier
After cleaning my electronic filter, it runs well for about a day. Then, it begins to continuously arc until I wipe the wires clean. Again, no arc for awhile, then, continuous arcing. Is there something I...
It is normal to hear occasional snapping from your Electronic Air Cleaner. This occurs when larger particles are caught by the ionizer wires. Continuous snapping is not normal however, and should be investigated as outlined below: Please note that the metal electronic cells may have some sharp edges; use care when handling the cells. Wear gloves to protect your hands from being cut if needed. Remove both electronic cells. Make sure that there is no hair, dirt, sand or any debris on the bottom inside the Electronic air cleaner. If there is, remove what you can by hand. If a lot of debris is left in bottom of the Air Cleaner, you may want to use a vacuum attachment to see if you can vacuum up what you can. Do not vacuum the Pre-filter or Post filter this may damage it. Close the access door, and then turn on the Electronic Air Cleaner and the system fan. If the snapping continues with the cells removed, contact your heating and cooling contractor for service on the unit and turn off the Electronic Air Cleaner’s power. If snapping does not continue, make sure the electronic cells are clean, dry and properly installed. Inspect the electronic cells for bent collector plates, broken wires between the plates, dirt on the insulators, and damaged collector contact tabs located on the top of the cells. Make sure the pre-filters are in good condition and are in the cabinet slot farthest from the furnace (The order of the Electronic Air Cleaner Filters are from the return duct to the furnace is: Pre-Filter, electronic cell, and then Post filter, if your Electronic Air Cleaner has one). If the snapping persists and you are unable to locate any physical cause, please contact your heating and cooling contractor for service on the unit and turn off power to the Electronic Air Cleaner.
Jan 25, 2010 | Honeywell Enviracaire Elite F300E-1019 Air...
F300e filter clicking
You may have a large particle of debris trapped or one of the cell plates is bent and too close to one another.
Jan 17, 2010 | Honeywell Enviracaire Elite F300E-1019 Air...
Eletrical snapping sound
This is normal....when dust passes through this filter it is "Zapped" that's how the electronic air filter works
Oct 25, 2009 | Honeywell HFD-130 Air Purifier
Electronic Air Cleaner problem
The presence of “white dust” is actually an indicator that your Electronic Air Cleaner is working properly. The Electronic Air Cleaner can only filter the particles that are passing through your system’s duct work. The staining particulate is generally lighter, and more able to be drawn through the return registers in your home, leaving the heavier, non-staining particulate behind. This heavier, non-staining particulate settles out of the air and is left behind on your furniture: because it is more visible, it may appear as though there is actually more dust in your home than there was prior to installing the air cleaner. To ensure that more particulate is able to reach the Electronic Air Cleaner to be filtered, you should make sure that the return registers are clean and not blocked by furniture.
Apr 29, 2009 | Honeywell (F50F1073) Air Purifier
Honeywell Enviracaire Elite F300E-1019 Air Purifier Logo
503 people viewed this question
Top Honeywell Air Purifiers Experts
Bill Long
Jay Finke
Jay Finke
Are you a Honeywell Air Purifier Expert? Answer questions, earn points and help others
