Question about Bose 3·2·1 II System
How can i connect a turntable to my Bose 321 - Bose 3·2·1 II System
    President:
  • 3,130 Answers
If you are refurring to connecting to an AUX or tape input, you will neede to use what's called a impedence PREamp.
Techman
Posted on May 15, 2010
freetek
  • 5568 Answers
SOURCE: Bose 321 won't turn on
I'm amazed at the range of comments regarding this system; they range from unbridled enthusiasm to some **** words.
Before I try to help, if I am not familiar with a specific model but have a clue to what the nature of the problem might be, I research the item to see if I find some support for my suspicion.
You might keep tabs on some comments I found relating to a possible class-action lawsuit due to the array of problems that have appeared with this system.
This link will give you a sample of them:
http://www.amazon.com/Bose-DVD-Home-Entertainment-System/dp/B0002JY6SQ
Posted on Oct 17, 2008
  • 899 Answers
SOURCE: bose 321 system reads bad disc on all dvds
if will not read a laser lens cleaning disc , then it will need to be opened up and the laser lens will need to be cleaned manually with the cleaning solution and a cotton tip , but do it easy and dry the lens with the cotton tip
if that don't do it then the laser mechanism will need replacing
electech
Posted on Nov 27, 2008
SOURCE: bose 321 cd/dvd tray stuck closed
can you post the disassembly page in with a larger view? This is too small to be useful
Posted on Jan 19, 2008
SOURCE: communicating with your tv message on bose 321 series 2
Well, it seems that this may be a common issue with this BOSE unit. My 321 GSIII was working fine as well for about a week. After a full frustrating day of switching, disconnecting, reconnecting cables and resetting the unit and TV several times, I was forced to call the BOSE Technical. They tried to help with the situation over the phone by directing me to do just about everything I did before I ever called them. After about an hour of their unsuccessful help, they left me in saying that I will now have to run Composite cables because my TV will not connect for some reason through HDMI even though it was working for a short time. AHHHHH...I custom prepared the walls in my new office to accommodate non-exposed cables and wires and now BOSE is saying to expose Composite cables. Tomorrow, I am going to connect the Composite cables to confirm if the 321 will now work that way (for curiousty). I will then call BOSE back and demand a replacement unit. I will keep all in the loop with my progress of this situation.
Posted on Feb 13, 2010
futurework
  • 70 Answers
SOURCE: Bose 321 won't eject DVD
the dvd system is built around a pc style dvd rom drive. You can remove the top cover by prying the back center up and sliding the cover back then off. Remove the metal bracket that holds the drive in place and then remove the drive. the front tray cover should pop off as you remove the drive. There is a eject hole in the front that if you put a paper clip into it will release the tray. That way you can get your dvd back. I refurbish these drives and I may have one for sale. Contact me if you would like to send the unit in to me i can complete the repair for 85.00 Bose does offer a repair service if you call them at 1-800-999 2673
Posted on May 04, 2010
Bose 321 no sound on auxiliary
Check the connections of the cartridge. If connection to cartridge is not right, this kind of fault can occcur.
May 12, 2013 | Audio Players & Recorders
Can i connect turtable to bose 321
You can BUT you need to have whats called a Phono Preamp. Without this your turntable will sound quiet and rubbish.
The preamp boosts the signal from the TT to line level (suitable for aux input) and also puts adjusts the eq for the MM cartridge
Nov 12, 2011 | Technics Audio Players & Recorders
Have a Bose 3-2-1 Series III. When I put in a DVD, I get sound through the Bose but no picture on my Pioneer TV. This is the second time it has happened. The first time it, we managed to get it going...
Here are 3 things to try and an if all else fails at the end.
1) Make sure the TV is set to the correct Video Input to see the video from DVDs on the Bose system.
• Make sure a DVD is in the disc tray.
• If the TV is connected to the media center using the HDMI cable:
Switch from one Video Input to another and then back to the original input.
2) Turn everything off, then:
Turn on the TV and set the TV Video Input for the Bose system video.
Turn on the Bose system and press DVD.
3) Turn off both the TV and the Bose system and then:
Unplug the HDMI cable from both ends.
Disconnect the power cables from both your TV and the Bose 321 system.
Re-connect power to the TV and to the Bose 321 system.
When the Bose 321 system startup message disappears from the display,
re-connect the HDMI cable to the TV then Bose 321 system.
Turn on the TV first, then turn on the Bose 321 system.
If all the above fail then disconnect the HDMI cable that connects the TV to the Bose 321 system and reconnect the two using a Component cable, an S-Video cable, or the Composite cable provided with the system.
Please leave feedback
Cheers
Andy
Apr 28, 2011 | Bose 3·2·1 II System
HOW TO INSTALL BOSE 321 SERIES THROUGH TV AND SATELITE RECEIVER
Hi! It would just be easy. Just prepare RCA cables and connect the cables to the tv and satellite receiver. Link the TV and satellite audio output to the BOSE audio input. Good luck and have a good one!
Apr 13, 2010 | Bose 3 2 1 GSX System
I cant get my ps3 to come through my bose 123 system
More specifics would be helpful. To connect a PS3 to a 321 via optical, it depends on what series of 321 you have, but you need to assign the optical connection via the system menu. If this is the series 1 321, it's the settings menu. It can be assigned to any input "AUX etc.."
Dec 11, 2009 | Bose Audio Players & Recorders
How do i get my playstation 3 to connect to my bose 321 system?
Very simple. Red and White RCAs into any available input on the back of the 321. If the PS3 A/V cable can't separate the audio from the video (yellow RCA) by length of cable then get an RCA extension.
You can also connect this digitally with an optical cable (better sound) but you need to assign the optical cable to an input from your system menu. Your system menu can only be displayed on the TV from the video out of the 321. Go to "media center" and then down to "optical source"
May 30, 2009 | Sony PlayStation® 3 (60 GB) Console
Communicating with your tv message on bose 321 series 2
Apr 01, 2009 | Bose 3·2·1 II System
Connecting bose 321 system to lg hd flat screen,bose receiver plays fm am ok threw speakers.tv will not play threw bose speakers.bose dvd plays sound ,but no picture
You will need a Component Video Cable
Connect the Red Green and Blue Connections from the TV to the Bose.
if your audio is coming from the TV, also connect stereo audio from the TV's audio out to the "TV" input on the bose.
if you want to hook up other devices (VCR, BluRay, etc) the video will go directly to the TV and audio will go directly to the Bose
Jan 18, 2008 | Bose Cinemate Digital Home Theater System...
Connecting headphones to bose 321
try pushing mute and then turn volume up
Aug 22, 2007 | Bose 3 2 1 GSX System
Bose 3·2·1 II System Logo
1,484 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
