Question about Olympus Camedia C-8080 Wide Zoom Digital Camera
Help.Dust under first lens layer.
Good afternoon.
I have a problem. when I look at my lens from the front, I can see a bunch of dust specs have settled on the second element. I've tried blowing around the lens housing with canned air, but nothing moves. Big mystery. How'd it get in there? Anyway, I'd like to remove the first piece of glass. I have the parts diagram, but it isn't clear on how to remove the glass. Has anyone out there been down this road? Any help would be greatly appreciated!
Thanks, Carl
  • atomickat May 11, 2008
    Ooff! Yeah, I'll keep the dust. It doesn't show on images, you are correct, but I was looking at selling it and I think the dust will (unfairly) reduce the selling price. Thank you very much for the info. I hope that yours go back together successfully.
    Carl
  • 594 Answers
Same here. dust usually doesnt show up on photos as it is out of the focal plane. Many SLR lenses have dust in them and do NOT affect picture quality. I am in the process of attempting to take one apart. I have seen a damaged one that was seperated at the first 2 joints but it was glued back. this is one tough nut! http://picasaweb.google.com/pishta68/8080lens/photo#5199141246863292738
Posted on May 11, 2008
  • Steven Wander
    Steven Wander May 12, 2008
    Ha, I found the solution! If you get the lens off the inner lens barrel like I explained, you can tap the lens, open end down on a towel and the 2nd inner lens, a large heavy glass lens, will literally fall out onto the towel. Get your brush out, dust off both lenses and lower the outer lens barrel back onto the inner lens. It is a press fit as far as I can tell. Gently push the lens back in with a lens cloth covered pencil eraser end, and wipe the inner lens one more time. Good as new. The front lens retainer ring is somehow press fitted because there are 4 screws under it. I didnt need to get it off as the lens came out the bottom, but I dont know how to get to them. If you figure it out, you can clean both lenses without taking the camera apart. If you destroy the ring to get to the screws, you can always just screw a UV filter on to cover the screws.
  • Steven Wander
    Steven Wander May 28, 2008
    Found the answer. Pry the front trim ring( under the inner threads) off the first lens with a sharp object like a pocket knife blade. Cover the lens with something so you can pry against it. The thin plastic trim ring is held on by a rubber cement like adhesive, itll peel right off, youll see 4 screws under it, remove screws and the front lens carrier will come out, remove the next 4 screws and the 2nd fat lens will come out, dust them off and reassemble, clean as new!
SOURCE:
How can I clean the inside lens of my Ricoh cx5 camera?
Once you start blowing air from aircan (duster) it will move the dust sitting on the barrels' surfaces of the lens. The dust specs will end up on the interior of the lens glass even in larger quantities. The only way to clean it correctly is to take apart the lens and blow the dust out and assemble it back. If the same camera is listed on ebay under $50 buy another one with a clean lens. Sell yours on ebay for parts the difference will be around 15-20 dollars. Not a bad price for getting a cleaner version of your camera. You may even make money by buying a better camera cheaper than you can sell yours. If you camera is still valued at 100-200 range find a cleaning service on ebay for $30.
Jul 15, 2014 | Ricoh CX5 Digital Camera
Tamron AF 18-200MM XR Di II LD dust inside; how do I clean?
Dust and other small debris is drawn into the lens due to the vacuum created when zooming in. You can reduce the chances of drawing in dust and debris by slowly zooming in as opposed to rapidly zooming in.
Now that you how it gets in and how to help prevent it from getting in again, comes the bad news. There's really no way to disassemble the lens to clean it up at home. These are precision optics with many small moving parts that really need to be serviced in a dust free environment. You best bet it to contact Tamron (or authorized servicer) to learn how much it will cost to be cleaned by them. This will keep the warranty (if any) intact, too.
Feb 14, 2012 | Tamron Cameras
When i put a disc in the drive it trys to spin up but then fails and then winds down and it does that a whole bunch of times untill it just gives up. but when i go under my computer and click on the disc...
Nothing to do with the rest of the pc, it's the reading head inside the drive that is faulty: it's no longer capable of detecting the disk because it's covered in dust. Try to blow away the dust with a can of compressed air and then wipe the lens with a q-tip. If this doesn't help then the dust has been baked on the surface of the plastic lens and this is terminal - you will have to replace the drive.
Apr 19, 2011 | Samsung SN 124 (SN-124) Internal 24x...
Camera will not turn on. I turn it on, the lens moves very slightly, then the camera shuts down.
The camera is not coming on because movement of the lens is restrcted. The problem could be that some dust is stuck in the lens well between the lens housing and the well wall. Please use your hairdryer to blow the specs of dust and free the lens movement. Once the dust is dislodged, the lens will move freely and the camera will bootup.
Jan 29, 2011 | Kodak EasyShare Z712 Digital Camera
My powereshot sd870 LS digital camera work.lens wont close it says "lenserror, restart camera"..what to do?
It seems that there is some spec of dust thats lodged between the lens housing and the camera body. If you use your vacuum cleaner to pull the dust out while trying to shut it down, the dust may come out and the lens housing will start moving thus completing the process of shut down.
Nov 02, 2009 | Canon PowerShot SD870 IS Digital Camera
Lens will not close when camera is turned off
May be there is some spec of dust stuck in the lens well. You must use your vacuum cleaner to pull out the dust from around the lens housing while powering the camera on and off.
Oct 29, 2009 | Fuji FinePix S1000FD Digital Camera
Have lint and small specs on inside part of viewfinder, how do you clean this
It may not be the view finder. My guess is that there's some dust on the lens. It will look like the dust is inside the view finder but its actually not. Do these "spec" appear on pictures too? If yes then you will need to clean your lens/get it cleaned.
Let me know if you need more help,
Sai.
Aug 02, 2009 | Olympus Camedia C-700 Ultra Zoom Digital...
Dust
HI
If this is not the DG type what you do is to remove the name ring you can pleel it of it will restick
under the name ring you willsee two holes to use a compus to undscrew this ring do not put
to much presher on the ring when unsewing it next you will be able to unscrew the front element
just clean and blow out the dust out then rescrew all .
Jan 10, 2009 | Sigma 17-35mm f/2.8-4.0 EX Aspherical for...
Plays cd's but lots of skipping going on. I tried cleaning with a CD player disc cleaner that I got today. That didn't help. None of the CD's skip in another machine. Thanks!!
When optical lens got dusty or thin layer of dust on lens, cd starts skipping, as you tried cleaning with lens cleaner cd but no result.
You need to open the unit and clean the lens with good quality cotton bud / swab with care.
Still no joy, replace optical lens.
Oct 10, 2008 | Sony XPLOD CDX-GT200 CD Player
Olympus Camedia C-8080 Wide Zoom Digital Camera Logo
189 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
