Question about Acer TravelMate 6460-6752 (LXTED06059) PC Notebook
Bluetooth Hi. The Bluetooth on my Acer TracelMate 6492 just stopped working. Not sure why. Is there anyway I can check whether its a software or hardware problem? The notebook is only 2 months old. Would appreciate your assistance. Thanks. Kind regards Marcus [email protected] (South Africa)
  • marcusw Apr 01, 2008
    Not sure how I managed to solve the problem. All i did was uninstall my cellphone software and that seemed to solve the problem.
  • 81 Answers
Maybe you just turned it off. try to turn on the switch. i think it is near the wifi switch or look for the bluetooth symbol on you laptop
Posted on Mar 31, 2008
SOURCE:
Acer aspire one D270-1824 keyboard stuck
Hi what do you mean stuck.Does it lag or did it stop typing.This can be a hardware or software issue.If hardware remove your keyboard and check to see whether the cable has disconnected.And if software let me know.If you don't know how to remove the keyboard without damaging the computer let me know. I Can help.
Jul 13, 2014 | Acer Aspire 5315 Notebook
Bluetooth not warking
Have you tried reloading the drivers for the bluetooth? Or potential you turned of the bluetooth. Something this can be turned off by pushing Fn + 'some other key' or check the BIOS to make sure bluetooth is enabled
Oct 21, 2012 | Acer Aspire 5749-6492 Intel Core i3 2350M...
Does the acer aspire 5735-6694 have built in bluetooth
Yes it does, and you can download the driver here. Before you do, there are two things you should check. 1st see if the device is already installed, and whether the system thinks it is functioning properly, or if it is disabled. To do this: 1.) Click Start > Right Click My Computer > click properties > Click the Hardware tab (at the top) > click Device Manger. Scroll down to Bluetooth, and double click it. 2.) On the general tab, it will say whether the device appears to be working properly or if it is not or disabled. If it isn't listed or not working properly, reinstalling it from that link may help.
If that doesn't resolve it, my 2nd suggestion is click Start > Control Panel, Bluetooth, and see if it is disabled.
Please let me know if I can be of further assitance.
Thanks
Mar 13, 2010 | Acer Aspire 5735-6694 Notebook
Acer Travelmate 5620 bluetooth button won't turn on
Do you actually see the Bluetooth device in device manager? Normally if it's not turned on it won't appear in device manager. The next thing I can think of is that if the Bluetooth module was not turned on when you loaded the drivers then they won't work.
And lastly the module may have come lose or unseated from the slot. Are you absolutely 100% sure there's Bluetooth hardware on this laptop? Is this built-in or a USB dongle?
If built-in have you turned it on? Acer uses a slide switch to turn Bluetooth and Wireless LAN on and off.
The first thing you probably need to establish is whether the laptop has a Bluetooth module fitted. Plenty of Acer laptops support Bluetooth in some markets and not in others and actually have slider switches to turn Bluetooth on/off but don't have the Bluetooth module fitted.
Does the unit say that it supports Bluetooth on the sticker attached to the front of the laptop? The models that have Bluetooth typically have this listed on these and will also list it on the packaging that came with the laptop that lists its specs. If it doesn't mention it odds are it's not fitted.
Acer laptops have the Bluetooth buttons, but not always have the Bluetooth Module. Check the bottom white sticker for a Bluetooth symbol under the laptop. If you do not see it, there is no Bluetooth. Also, if you press/move the Bluetooth button, and the light doesn't turn blue, there's no Bluetooth module with your laptop (only the button), so your laptop did not come with Bluetooth.
Also, you can add Bluetooth, but you need to be able to take the laptop apart to a certain extent, such as taking off the cover (top portion), keyboard, and maybe the speakers. The Bluetooth should have a 4pin, 6pin, or 8pin Bluetooth Cable connected to a Bluetooth module. You need to purchase the Bluetooth module, and install it, but you need professional help for that.
In case your laptop won't have a Bluetooth module fitted. The switch doesn't mean anything, it's present on all Acer laptops whether they have Bluetooth fitted or not.
You can buy the module as a spare part from Acer and fitting it is easy however buying a cheap USB Bluetooth dongle will be a cheaper option.
Thank You for contacting Fixya.com
Feb 02, 2010 | Computers & Internet
Bluetooth not working on acer aspire 5738
Hi tallyman,
you lost bet ...when it has a bluetooth switch it will have a hardware installed.
Best solution is got is a simple call to acer service support,the problem very very simple in 5738 machines they installed foxcom bluetooth device a very much updated version.But the drives in your cd will be broadcom drivers install aspire 3810T model bluetooth drivers.
regards
Ar.Praveen(Architect)
[email protected]
Oct 01, 2009 | Acer Aspire 5720-6661 Notebook PC
Ace extensa 4220
If that's an Inbuilt Bluetooth, Software is not needed until and unless you have deleted that software.
USB bluetooth or Bluetooth Dongle is required when you do not have bluetooth option in your notebook.
It's not working means - You have lost this feature . You need to purchase a Bluetooth device and you would get a CD alongwith it for software.
Kindly make sure with the tech - Is that the software has been lost or Bluetooth Hardware is at FAULT.
Regarding software, download from :-
http://download.cnet.com/Bluetooth-Software-Ver-6-0-1-4900-zip/3000-2108_4-162222.html
Thanks.
Jul 02, 2009 | Acer 4220-2346 Notebook
Acer aspire 5335 no bluetooth? XP
go to control panel then find add hardware. There, it can manually detect the hardware.Thanks and God bless^_^
godlover
Jun 15, 2009 | Acer 4220-2346 Notebook
Graphix card on acer travelmate 6492
hi ken, give the laptop a 2GB RAM upgrade and you will be able to play any computergames that date from 2006 and 2007,
exchanging the graphic card it no option as it is onboard.some 3d features may not work with your graphixcard.
for gaming you definitely will have to have directx9.0 installed.
when getting a pc-game make sure your system meets them minimum requirements of your laptop,
to find out more about it, get the freeware 'pcwizard2008' program
from the net, it'll tell you all you need to know in detail about your laptop's hardware and software.
happy gaming, gta4 will work slowly!
Oct 06, 2008 | Computers & Internet
I have a problem to use my bluetooth on my laptop
First of all, check whether your Notebook is having Bluetooth devices or not since the Remote Controller you are using works based in Infrared like the Remote Controll like the remote controller in Televisions.
To check whether your Notebook is having a Bluetooth hardware or not, go to Device Manager by following the steps below :
Right Click on My Computer and select Properties in the list.
Now go to Hardware tab and click on the Device Manager button.
Device Manager window opens in a seperate window.
Check if there are any entries with Bluetooth in the the Device Manager.
If you find any entries with such name, click on the [+] mark next to it to expand the tree.
If you find any entries called Bluetooth emulator, it is just the software you had installed and not the Bluetooth Hardware which you can use to transfer data.
If the Bluetooth hardware is installed in your Notebook, there should be HP Integrated module with Bluetooth.
However, to use Bluetooth, the Wireless button should be turned on.
Just follow this steps and make sure that your Notebook is installed with a Bluetooth Hardware and get back to us if the Notebook is having Bluetooth hardware and unable to use it.
Aug 20, 2008 | HP Pavilion dv4000 Notebook
Bluetooth problem
unistall and reinstall with the last Update bluetooth software.
Jul 02, 2008 | Acer Aspire 5500 5570-2609 Laptop
Open Questions:
See all Acer TravelMate 6460-6752 (LXTED06059) PC Questions
Acer TravelMate  6460-6752 (LXTED06059) PC Notebook Logo
176 people viewed this question
Ekse
Alun Cox
Steve Sweetleaf
Steve Sweetleaf
