Question about Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve....
No hot water
There is no hot water whatsoever. And I can't seem to get the cartridge out.
  • 349 Answers
Check behind handle and see if there ia a dial to move to different settings. mark where it is and remove move about a 1/4 turn this affects hot & cold ratio. if turned to far all you will get is cold.
If you have to remove cartridge shut water off remove ring holding it in, you may be able to screw handle back to it and try pulling forward to get it to release. Some will stick if been in a long time. just be easy with it.
Posted on May 16, 2010
Barclay 4073-PL Diverter Bathcock Tub: Thoughts on why the water pressure is low on the hot spigot but not on the cold, and not on any other faucet in the house?
Debris can get into the shower body/cartridge. Pull out the cartridge and flush the shower body and clean out the cartridge. Sometimes you need to replace the cartridge.
Nov 07, 2014 | Plumbing
Replaced cartridge now only have hot water
You likely took out the anti-scald ring out when you took it apart and then put it in in a different spot preventing the handle from turning far enough. You may also have the cartridge or handle upsidedown.
Nov 25, 2013 | Price Pfister R897EBK Brushed Nickel...
How to clean Axor Terrano Showerpipe - hot water part of mixer seems blocked
There are filter screens on the thermostatic cartridge inside this unit. You will need to remove the thermostatic cartridge and clean the filter screens. If cleaning the thermostat cartridge does not resolve the issue you may need to replace the cartridge. If you need further assistance feel free to contact me at Hansgrohe Technical services. 1-800-334-0455. prees 2 for tech and ask for David Scarborough.
Aug 30, 2012 | Home
I just replaced a cartridge in my hot water shower handle to stop a leaky faucet, now the hot water pressure is less. It seems once cartridge is in place it doesn't have the range of motion it had when it...
you need to go back in and check your work it seems that it has been installed in a lower setting look at the directions, most shower assembly's have energy settings.usually just have to move the stopper to the farthest point to the left (counter clock wise).good luck.
Nov 14, 2010 | American Standard Home
How to set up a time guard ETU2000 timer
Looking for some help with my TimeGuard ETU2000. I'm not getting any hot water whatsoever, tried boost, reset, resetting timed hot water all that but still no hot water, in fact I kept the main switch button so that it heats up water but no joy till date. Please advice anybody out there..
Nov 08, 2010 | Heating & Cooling
The water doesn't seem to get hot . New cartridge installed . If turn right (Hot direction ) the knob will turn until water gets cold again ???
The cartridge sounds like it was put in 180 degrees out.
Pull it back out, and rotate 180 degrees and re-install & try that.
Jan 18, 2010 | Moen 1 Handle Lever Shower Faucet With...
Canon MultiPass F20 - "Wrong Cartridge error msg" - not new but hardly used
Take both cartridges out and then you will see a grey lever in the front of the assembly that holds the two cartridges in it.
If you lift that lever up it will allow you to remove the print head assembly.
Soak that in some hot water, use a straw to help blow out any remaining ink residue in the holes that the ink flows throw and once it is dry again put it back in and see if the error goes away.
I'm just running a head cleaning, nozzle cleaning etc. now but I appear to be back in business.
Mar 27, 2007 | Canon MultiPASS F20 All-In-One InkJet...
Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve.... Logo
114 people viewed this question
Top Moen Plumbing Experts
john h
Don Numinen
Don Numinen
Mike
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
