What kind of dvd disc is used to record from a vhs tape to disc
Ive tried dvd+r and dvd+rw and it says it not readable is their a certain brand name to use with this or is it that I don't have it hooked up right in the back that it wont record
BE CERTAIN OF THE KIND OF DVD DISKS IT SUPPORTS. My experience is that the kind of discs while you would think would not make a difference actually do make a big difference depending on the equipment you are using. I just transferred 15 vhs tapes to DVD and realized that the machine only took a few formats luckily it was the one I was using, but not all formats may be compatible. There is a difference between DVD+R and DVD-R as an example.
How old is Toshiba DVR620KU recorder and how long it started this problem? Does it playback previously recorded discs correctly? Did you tried lens cleaning disc in recorder to clean optical lens? These info will help me to suggest a solution. Thanks.
I have researched the manual for this particular device and you will not be able to convert/record VHS tapes to DVD discs. You can however record content from a DVD to VHS tape as this model only has a readable disc player not a DVD burner. Sorry, but you may want to research DVD recorders that also have VHS playback.
Did you say you used a DVD-RW disc to transfer a videotape onto? The reason your PC won't recognise that disc is because the data format on it is a different language to what PCs understand - plus an unfinalised DVD-RW won't play in other DVD players - it is usually an incompatible format.
(DVD+RW discs with titles/top menus created in video mode CAN be played on a PC DVD drive or a normal DVD player as can finalised DVD-R discs (DVD-R discs MUST be recorded and finalised in the same recorder for compatible playback). DVD-RW discs can only be viewed on the unit they were written/recorded on.
The other reason for the 'remaining space' on the disc you describe showing less than 120 minutes is due to a title recently being recorded or erased - unless you format it - the 120 minute / 4.7GB DVD-RW will not show full available space. Erasing titles on re-writable DVDs does not increase space. The same rule applies to unfinalised +R / -R discs (you cannot re-format these to get the space back once recorded - they are 'once only' writables)
I recommend you invest in some DVD-R discs and re-copy your VHS tape to that - then if you are satisfied with the result, title etc., finalise the DVD-R - it will play on any DVD player or PC with DVD support (or it should). These discs are relatively inexpensive to buy just about anywhere.
Final note: do NOT finalise the DVD-RW you recorded (I hope you haven't already done this) - simply format/erase it - re-use it for something else or keep it until you need it.
You can use any brand of DVD, just take note of the format before recording/playing.
a while ago many vhs tapes had a protection sceme to prevent copying, i forget the namee right now, "something" vision" i think. it may be the vhs and not dvd disc.
Did you provide the correct model above? The EWD2203 is a DVD player. It can only record to VHS tapes. If you recorded to the -r or -rw discs on another machine, did you finalize the disc? Finalization is needed to make discs playable in other devices. Also check if the disc needs cleaning.
If you are dealing with another DVD recorder, try another brand of disc. Often the manufacturing differences can affect how well the recorder will handle recording to the disc.
I have the same unit, a SRDv495 and have also been having
a bad time getting dvd's that will work in my machine. I also
bought mine from Sears. I have found one that works every
time and that is a MAXWELL DVD-RW. The trick I think is
the speed of the DVD, so you need to use the ones that have
Up to Max 2X, 4.7 GBgo, 2 Hrs. I find these work every time.
Hope this helps.
