Question about KitchenAid A-9 Electric Burr Grinder
Where can I buy brushes for my Hobart Kitchen Aid A9 coffee grinder? The brushes in the coffee grinder have worn down and I would like to replace them. Where can I buy new brushes and spring for the coffee grinder?
  • 26 Answers
SOURCE: Parts and Grind Selection
The current Kitchenaid A9 burr grinder glass jar is interchangable with the original Hobart/Kitchenaid A9 glass jar; therefor, the gasket should also interchange - contact Kitchenaid customer service to order a gasket.
Setting the grind is accomplished by grasping the body of the ginder in one hand and the grind-selector ring (collar that the jar screws into) in the other. Hold the base tight and turn the selector ring clockwise for a finer grind, counterclockwise for coarser. Be careful not to completely unscrew the selector ring; if you are not sure how much adjustment is left, screw it all the way clockwise until it stops (finest grind); then, back it off, up to one full turn to make the grind coarser.
The selector ring has the words coarse, medium and fine cast into it; these are rough postition markers. There is a triangle cast into the body of the grinder, just above the brand name, that can be used to diral in a preferred level of grind. I use a medium-coarse grind for drip coffee makers; to do likewise, position the selector ring so that the triangle is pointing midway between the words coarse and medium.
Posted on Jan 18, 2009
  • 3 Answers
SOURCE: Where can I buy a glass hopper for the coffee beans?
Ebay his these.
Posted on Apr 18, 2009
  • 145 Answers
SOURCE: kitchen aid coffee pot says error 2
An ERR 2 may be cleared by a simple reset of the coffee maker. This means unplugging the unit and plugging it back in. When powered back on, select a brew function to see if the error reappears.
If it does, ERR 2 indicates an internal error with the computer of the warming plate. This may be covered under Kitchenaid's 1 Year Hassle Free Warranty. I would advise you to call Kitchenaid Customer Service to see what options are available to you. Repair is not recommended, as it is not cost effective for the company or the consumer.
Their toll-free telephone number is 1-800-541-6390.
Posted on Jul 08, 2009
  • 145 Answers
SOURCE: operating manual for kitchen aid coffee machine
Manuals and guides may be located online at KITCHENAID.COM.
In the upper-right hand corner of the site, click on CUSTOMER CARE and then click on LOCATE MANUALS AND GUIDES.
It will then ask you for your model number.
For a coffee maker, the model number is located on a white sticker underneath the machine.
On the website, type in your model number exactly as it appears on this sticker and click GO.
This will then bring up the literature listing for your particular unit. You will need Adobe Acrobat Reader to view the files.
Also, Kitchenaid Customer Service will send you a physical copy of an instruction manual at no charge if you choose to call them. Their toll-free telephone number is:
1.800.541.6390.
Posted on Aug 08, 2009
  • 34 Answers
SOURCE: coffee maker wont turn on
maybe you bought a false one.
try bringing it to a specialist, to a technician. or bring it where you bought it.
or maybe you a new one.
try this link. hope it will help you with your concern.
http://www.coffeemakerwizard.com/4-cup-coffee-makers.html
Posted on Feb 01, 2010
Took my mr coffee burr apart a little spring fell out now the grinder doesnt work where dose the spring go
Im first wondering why u took a good grinder apart ??? could it be that it was working only intermittently ?? if that is so , im betting the little spring is either the spring that pushes the start switch back up when u let go (otherwise it would run forever) or it might be a motor brush holder tension spring , that's most likely why its working only intermittently the brushes are worn down and need replaced , a neet hack 4 this is to use electric drill brushes ! I found they fit and can be sourced from a well stocked hardware store !!
Dec 21, 2016 | Coffee Makers & Espresso Machines
Where can I get an Kitchen Aid A-9 burr grinder repaired?
Softly Scrambled: Kitchenaid A9 Grinder Refurbishment.
softlyscrambled.blogspot.com/.../kitchenaid-a9-grinder-refurbishment.ht...
Mar 1, 2014 - This is an original A9 from the days when Kitchenaid was owned by Hobart. ... Yes, it worked and would grind coffee, but the motor seemed to labor and the grinds were ... I am now doing this for mine, but I can not for the life of me get to the bushings. Does ... I don't recall a ball bearing from repairing my A9.
KitchenAid Burr Coffee Mill KCG200 (aka A-9) - Automatic Washers ...
www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?44466
Jan 13, 2013 - 49 posts - ‎12 authors
I'll definitely use that cleaning method if I can't get the grinding mechanism .... I'd try lifting the lower burr assembly out with the aid of two flat ...
Kitchenaid A9 Coffee Grinder - HubPages
hubpages.com > Food and Cooking > Beverages
Sep 20, 2013 - Where can I buy a retro Kitchenaid A9 Coffee Grinder? ... are paying for (is it new in box, has it been used for 20 years, or does it need repair).
KITCHENAID A-9 INSTRUCTIONS MANUAL Pdf Download.
Dec 21, 2015 | Coffee Makers & Espresso Machines
My A-9 KA coffee mills are working perfectly. 2003 never quits, 2006 was a royal pain and burrs/pin replaced and working perfectly. Now, I have a 2004 used for decaf, actual use from purchase about
I don't see a question in the paragraph but common problems for the A9 are 1) Shear pin 2) Motor brushes 3) slow motor operation
If shear pin then the grinders won't turn or may intermittently rotate if pin is half broken
If motor brushes worn to nubs then a fast clicking noise and sporadic on off operation followed by no operation
If motor is slow then the commutator may need cleaning requiring removing the rotor
Jul 03, 2014 | KitchenAid A-9 Electric Burr Grinder
Kitchen aid mixer 5kpm5 motor doesnt go round freely
Any appliance with a motor should rotate freely. These are basically gear driven devices, Kitchen Aid makes different quality equipment. So either the gears are worn or possibly if you notice an electrical smell the problem could be at the tail of the motor. there are 3 major components 1. the brushes where the armature spins if you look inside the vent holes you might see a slight arc while it is running 2. the tail piece which is how the motor is kept straight. or as I said worn gears. this is especially common when companies use plastic gears instead of metal ones. Commercial appliances made by people like Hobart are expensive, but they outlast most others..
Apr 09, 2013 | KitchenAid 5kpm5eer Pro-Line Heavy Duty...
The mill is defect . . It can`t grinding the coffee
Hi The grinder motor brushes are worn out. Either replace the bruhes(quite hard but cheap) or replace the grinder( easy, but expensive). Dazza REPAIRER
Sep 27, 2011 | Saeco Odea Go
My KitchenAid A-9 (or perhaps it is a KCG200GC) retro style coffee grinders are both broken, and a local appliance repair store says they are irreparable. I suspect my wife didn't keep the chute...
You can find these on ebay for far less than it will cost to repair the ones you have. Here is one for a current bid of $39.99. You can find many more on ebay and around the web. http://cgi.ebay.com/Kitchen-Aid-A-9-Model-KCG200-Coffe-Mill-Grinder-Heavy_W0QQitemZ140487372005QQcategoryZ13930QQcmdZViewItemQQ_trksidZp4340.m263QQ_trkparmsZalgo%3DSIC%26its%3DI%252BC%26itu%3DUCI%252BIA%252BUA%252BFICS%252BUFI%26otn%3D10%26pmod%3D120646381982%26ps%3D63%26clkid%3D5577154654479827015#ht_500wt_922 You can also buy a new one as KithenAid has started making the A9 again. Amazon is showing it out of stock at this time. http://www.amazon.com/KitchenAid-KCG200OB-Classic-Model-Coffee/dp/B00009K3SX You can more than likely sell the 2 units you have on ebay as they are very popular and someone will buy them as is. My advice is to buy another one that is working. I think you will be money ahead.
Dec 11, 2010 | KitchenAid A-9 Electric Burr Grinder
Kitchen aid burr grinder adjustments
You are correct, the grider positions are locked internaly so the grinder will not go too fine since this can damage the blades and also too fine need more power from motor and also can block it by rottating normaly. However you ir open the grider you can overcome the lock and udjust so the grinder can grind more fine coffee. In order to be always at the safe side just move gradualy step by step until you find the perfect grinding and adjust so that will be the minimum plus one mor move for furure adjustment if you need.
Just for reference the corect grinding is for 7 to 7.5 gr of coffee the running time of the coffee from your machine should be 25 sec for 25 cc of coffee aprox.
Good luck.
Rember to vote for this answer.
Mar 02, 2010 | KitchenAid KPCG100PM Electric Burr Grinder
Dec 21, 2008 | KitchenAid A-9 Electric Burr Grinder
Kicthen Aid Coffee Grinder BCG100
The two small little guides you refer to are a pair of switches that get depressed when the top is pressed down. In the top is supposed to be a plastic pin in the top of each one of the grooves. When both pins push both of the switches down (look like black dots) the grinder wil operate. The proper solution would be to replace the top.
May 24, 2008 | KitchenAid BCG100 Electric Blades Grinder
KitchenAid A-9 Electric Burr Grinder Logo
246 people viewed this question
Top KitchenAid Coffee Makers & Espresso Machines Experts
Dan Webster
Dan Webster
graybeard32301
Ismael Rodriguez...
Are you a KitchenAid Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
