Question about Kenmore 24032\24036 Top Load Washer
Machine fills up with water and stops what causes this?
  • 10,319 Answers
There is solenoids that switches on the differents modes of the washers capablities. The timer has a cogged wheel that trips switches which in turn runs power to the solenoid.If the solenoid is faulty when the timer gives power to a solenoid and the solenoid will not work the washer stops
Posted on May 15, 2010
My ge top load washer will not stop filling up with water
The water level switch shuts the water off when it gets to the desired amount. Also change the water level to low and see if it stops at different level.
Jan 06, 2015 | GE Washing Machines
Water level
Probable causes:
Faulty water inlet valve - unplug washer, if water continues to fill
replace the valve.
Water level switch, hose or dome faulty - service the assembly.
Timer faulty - unplug washer, if water stops filling test timer.
Regards,
Dennis
Aug 22, 2014 | Simpson Esprit 750 Top Load 7.5kg
My ignis washing machine stops in the middle of the washing cycle and makes a sound, kind of blowing.
there are many more likely causes for this fault. The program will stick if the heater isn't working, if the thermostat fails, if it can't fill up with cold water for the rinses, if it can't empty the water etc. There are too many possible causes of this fault to be able to give anything other than rudimentary advice. However, the common causes of a washing machine sticking that can easily be fixed are filling and emptying problems.
Check that the cold water supply is available to the washing machine, which is a common cause for sticking on rinses.
The most common cause of a washing machine not taking any water in is either a kinked fill hose or the tap becoming faulty whereby you switch it on but the valve inside doesn't turn. Another common cause is the tap getting accidentally switched off and people not realising. Other causes can be wiring faults, water valve faults or programme control faults. This advice was originally written when most washing machines were hot and cold fill and didn't have error codes. It's now been updated to reflect the fact that these days the vast majority of washing machines are cold fill only and should give an error code if they can't take in water.
If your washing machine is stuck full of water the water needs to be drained out and this article gives tips on how to do this. If the entire washing machine has gone dead leaving the machine full of water it may be worth checking that it isn't something as simple as a blown fuse ( Washing machine is dead, wont start ) in which case if you get the washer going again it should pump the water out itself.
If the washing machine appears to be functioning normally but simply won't pump away the water then the possible causes (in the most likely order) are a blockage somewhere, a pump failure, or an electrical fault stopping the pump from running.
Blockages are the more likely explanation, but pumps can fail.
Dec 31, 2010 | Amana NAV2330AW Top Load Washer
Washing machine wont stop filling
The fill cycle on your washer is controlled by the pressure switch. That's the component inside the console that has a (either rubber, or clear vinyl) hose attached to it. Its function is to respond to the air pressure associated with water filling the tub, by closing a set of electrical contacts and allowing the machine to go into the wash mode. If the air hose becomes clogged with debris or lint, the signal won't reach the timer, and the machine can overfill.
To determine whether this is the cause of your problem, set your machine on the smallest load setting and watch the fill. As the water exceeds the level you're accustomed to, unplug, or turn off the machine. If it stops filling, the problem is probably a clogged air hose. Disconnect it from the switch and blow through it until you can hear air going through (make sure you drain the machine, first). If it continues to fill after the power is disconnected, the problem is not with the level switch, or the air hose; instead, it's fouled water valve.
The water works by opening and closing by solenoids (one solenoid for each water temperature). When sediment from the cod water accumulates in the valve's inlet, it can foul the valve seat, and it will stop closing all the way. If it gets bad enough, it can cause a flood.
There's really no good way to clean a fouled water valve. It will have to be replaced.
Dec 23, 2010 | Washing Machines
Moffatt washer is washing and draining but not spinning out the clothes
All content © 2000 © 2009 Washerhelp
> Home / Repairs DIY washing machine advice (part 8) Washing machine sticks or stops mid-cycle repairs-sm.gif A very common fault on washing machines is when the program timer fails to complete the cycle and stops part way through. Many people blame the program timer for this but although it is a possible cause, there are many more likely causes for this fault. The program will stick if the heater isn't working, if the thermostat fails, if it can't fill up with cold water for the rinses, if it can't empty the water etc. There are too many possible causes of this fault to be able to give anything other than rudimentary advice. However, the common causes of a washing machine sticking that can easily be fixed are filling and emptying problems.
Check that the cold water supply is available to the washing machine, which is a common cause for sticking on rinses. If the washing machine appears to stop mid-cycle and isn't filling with water on rinses then see Washing machine won't fill with water (or no water goes into washing machine) before calling an engineer. If the washing machine can't drain the water out then it will stick on the rinses, or it will abort with an error code. If you can see water still inside the washing machine then check the following advice Washing machine won't empty water
Dec 03, 2009 | Washing Machines
Washer stop in middle of rinse cycle
Dec 02, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have a Frig. Gallery washer and it will fill up and drain but not spin. What could be wrong and how can I fix it??
Dec 02, 2009 | Frigidaire Affinity ATF7000E Front Load...
What would cause the washer to overfill the tub?
If water is overflowing and you disconnect power to the machine. then:
A. It continues to fill: Replace water fill valve. (the part the fill hoses screw onto)
B. It stops filling: Most likely has a plugged tube from the tub to the water level switch.
Jul 27, 2009 | Washing Machines
Kenmore 70 Series washing Machine won't stop filling with water
filling and never stops and never agitates? then check level switch and hose, any hole in the clear hose to the level sw can cause this. if airtight then replace level sw.
Apr 27, 2009 | Kenmore 22422 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
48 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
