Question about Samsung NC10-14GW Notebook
When i power on the screen just says cont find operating system...and it just repeats this if yuo press anything...help 3 days out of warranty !!
  • 66 Answers
You need to run a reinstall or recovery call samsung and ask for recovery cd's .. if that does not fix the issue then the hard drive might need to be replaced
Posted on May 15, 2010
Black screen on start up with blinking cursor
Chances are, the operating system is corrupt.
Solution 1
1. Restart the computer, before entering the windows, press F8 to open the Windows Advanced Options Menu.
2. To enter the windows, select Last Known Good Configuration - enter. If that fails, repeat the process, select the Directory services restore mode. If that fails, repeat the process, select the Debugging mode.
3. After successfully entering the windows, press START - All programs - Accessories - System Tools - System Restore. Restore to a date when the computer is in normal condition.
Solution 2 (if the above solution fails)
Repair windows operating system with a bootable CD
Windows XP
1. Insert the bootable operating system CD, and restart
2. Perform booting from the CD room - Enter
3. Press enter - F8 - press R to repair the operating system
4. Wait until the process is complete. Finish
Windows Vista or Seven
3. Select Repair your computer - System Restore. If that fails, repeat the process 1, 2
4. Select Repair your computer - CompletePC restore. Restore a computer from CompletePC Backup Image.
Solution 3 (only for Win XP)
When done repair the operating system, drive C is detected: unknown or not formatted, it means the C drive for bad sectors.
To fix hard disk bad sectors, use the software HDD Regenerator bootable CD.
Nov 23, 2011 | Toshiba Computers & Internet
He dosent conting to opratur
Switch-off your phone. 1. Press and hold 3 keys; Green dial key, * Star key, no. 3 key on keypad and then press the power on/off to swtich on the phone. Remember, do not let go the 3 press and hold keys until you see a formatting word screen show! 2. After a few minutes when the Full phone formatting completed, your phone will back to original system and factory settting.
Dec 31, 2010 | Nokia 2220 Cell Phone
Ki need help programing my p that i bought used also i olnly have some of thehcodes for toulare county (porterville) thiat is where i live.... can yuo help me? thanks, kary ro 82 scanner
Before you start programming you'll need a list of frequencies (not codes). For a comprehensive database of active frequencies in your area, visit:
www.RadioReference.com
That site also contains a lot of other useful scanning data, including links to users groups.
To program a known frequency into the scanner:
1. Power the unit ON.
2. Press the PGM key.
3. Enter the desired channel number (1-200).
4. Press PGM again.
5. Enter the frequency, including the decimal point (ex: 462.365).
6. Press ENT to enter the data into memory.
7. Repeat steps 2-6 for other channels.
More detailed programming instructions can be found in the scanner operating manual which you can download/print here:
http://support.radioshack.com/support_electronics/doc69/69887.pdf
Bill B
Jun 29, 2010 | Radio Shack Pro-82 Scanner
My Sony Vaio PCG-K25 wont gp pass the black screen. I hear the fan and the power is on but the screen remains black. I took the battery out and had it powered through the chord. Still now working. Please...
Hello.
Either you have a memory issue or operating system problem.
First, try reseating (removing and reinserting) your memory (try one module at a time to test).
If still a problem, boot your system to Safe Mode (press F8 repeatedly). Go to System Restore and choose a date when your system worked OK. Note: with System Restore, everything, including your documents and other files you saved on the hard drive, will roll back to that date.
If still a problem, the last choices are Factory Restore and reinstall. Accessing Factory Restore (restores to the factory settings and will wipe out anything that you have installed or saved on your PC), is dependent on your hardware manufacturer. Boot your system and press F10, F11, Alt+F10, or Ctrl+F11 to access Factory Restore. Follow the prompts.
If still not resolved, you'll probably need to reinstall your operating system.
Hope this helps.
Dec 08, 2009 | Sony VAIO PCG-K25 Notebook
Samsung LE37A659A Black Screen and White stripe
Get in touch with the retailer straight away, and have them fix it under warranty.That is why they give yoyu a warranty, so taht if anything DOESgo wrong, they can fix it for you.
Jan 04, 2009 | Televison & Video
Fuse box diagram for 1996 linc cont
yuo have 2, one uder hood, one left side of dash
Dec 28, 2008 | 1996 Lincoln Continental
T.V won't turn back on
Sounds like a component shorted out for sure. I will guess he will say, "It needs a new power board". I would guess a transistor or microchip burnt out. Probably ESD damage from a new factory worker.
Nov 14, 2008 | Televison & Video
Dell 8400 boot up problems
There could be problem with the motherboard. You can try resetting the same.
1.Press F2 to enter the system setup.
2. Use the down arrow key and go to the option that says maintaince
3. Press enter and key down to the option CMOS defaults
4. Hit enter and reset defaults
5. Press escape and save changes and exit
6. check if the system boots up.
Before you perform the steps given above, unplug all external peripherals from the system like printers and webcams speakers etc. Your information is safe and there would not harm done to the information stored on the hardrive .
Thanks
proton
Nov 01, 2008 | Dell Dimension 8400 power supply ** FREE...
Instruction Manual
Normal 0 Conairphone Digital Answering Machine -- Model TAD2018CG
http://www.conairphone.com/Pages/quick_reference.html (try TAD920)
Answering System Operation
A. Recording your personal outgoing announcement
1. Press and hold down the ANNOUNCE control.
2. After the beep, speak towards the front of the base; you have 30 seconds.
3. When finished, release button. Your unit will play back your announcement and reset to
answer incoming calls.
4. Adjust volume control on the side of the unit to set the speaker to the desired level.
B. Setting the Voice Time/Day Stamp
1. Press and hold the TIME/REPEAT control for 2 seconds until you hear "Monday 12:00 AM".
Release the control. Press and hold the On/Off Control until you hear the correct day.
2. Press and release the TIME SET/REPEAT Control. Press and hold the ON/OFF Control until
you hear the correct hour.
3. Press and release the TIME SET/REPEAT Control. Press and hold the ON/OFF control until
you hear the correct minute.
4. Press release TIME SET/REPEAT Control. Press and hold ON/OFF Control until you hear PM.
Press and hold PLAY Control to return to AM.
5. Press and release the TIME SET/REPEAT Control to complete procedure. Unit will prompt
the day and time.
Apr 15, 2008 | Conair TAD2018CG Digital Answering Machine
I get CL blinking on the base
A flashing “CL” in the message window indicates that you must set the correct
day and time at the base unit.
1. Press the TIME button. The system announces the time and day of the week,
followed by "To set day and time, press TIME/SET."
2. Press the TIME button. The system announces the day.
3. Press the CHANGE button repeatedly until the system announces the correct day.
4. Press the TIME button to save the new setting. The system announces the setting.
5. Press the CHANGE button repeatedly until the system announces the correct hour.
NOTE: Be sure to select the correct time of day (e.g., 3 AM or 3 PM).
6. Press the TIME button to save the new setting. The system announces the minute.
7. Press CHANGE to advance the minutes one at a time. –OR– Press and hold the
CHANGE button to advance the minutes in increments of 10.
8. Press the TIME button to save the new setting. The system announces the year.
9. Press CHANGE to advance the year one at a time. –OR– Press and hold CHANGE to advance the years in increments of 10. When the system announces the correct
year, press TIME. The system announces the clock setting.
Mar 24, 2008 | Motorola Mobility E51 MD7161-3 Quad...
Samsung NC10-14GW Notebook Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
