Need to go to video 1 ... i have a older tv - Televison & Video
    President:
  • 3,130 Answers
You may need to go to the original remote or a lot of older sets the video inputs activate on channel 99 or above that channel???
Larry AKA Techman
Posted on May 15, 2010
Just purchased alexa fire stick, have only 1 hdmi port on TV, what to do?
If your TV is an older model and only has a couple HDMI ports, but you have several media sources, such as Blu-ray players or video game consoles, an HDMI switcher is exactly what you need. Connect all the media sources to the HDMI switch box via anHDMI cable and then connect the HDMI switcher to the TV.
Jul 30, 2017 | Televison & Video
My screen is broken but I want to play xbox can i hook up a older TV to the broken screen your TV and play xbox through the broken TV but using the screen of the old TV to play
You'd be much better off just hooking up to the older TV directly instead of trying to run an input on the broken TV and then direct the output through another TV.
You can always find cheap video adapters to connect to the older TV if needed.
Dec 27, 2015 | Video Game Consoles & Games
Video camera hookup.
there should be an av button on the tv turn the camera on to play back on the tv find the av button and hit it depending on the tv ther might be 1 or 2 av ports also depends on how the camera connects is it 3 wires red white and yellow or something else
Jul 19, 2013 | Sansui Hdlcd19wb
I have an older sharp tv from an older sibling and the cable works, but I'm trying to connect what I believe to be an older dvd player to it. The dvd player has the 3 color cords (red yellow and white)...
Those modes you gave are for what TYPE of signal is comming in to the Cable/Antenna connector.
You need to switch from that input device to the other input device, the RCA plugs. These are often displayed as Aux or perhaps Line etc. It would help if you had the remote from the tv and were able to choose Aux or Line, or if it has TV/Video button. But if not, try channel button on the tv itself and go down below Ch 1. If using the cable remote to control TV, it may have a TV/Video button too. Maybe.
Good luck
Jun 07, 2011 | Televison & Video
I Have recently Purchased a new LG 22" HDTV and want to connect to an older style video recorder. should i connect the old RF way and if so what input do I select on LG remote.what channel should I...
Your old video recorder should have the cable with the red, white and yellow connection. Plug them into the red, white and yellow boxes in the back of the TV. Usually there is a small white box painted around those three boxes and it says "Video 1" or "Video 2" on it, depending on how many video connections you have. If you turn on your TV you need to push "input" on your remote control and select the option "Video 1" or "Video 2", it needs to match with where you plugged it in the back of the TV.
May 04, 2011 | LG Televison & Video
Can a Sony DVP-NS710H work with a non-HDTV? I have an older TV model (2001) and need a new DVD player. I am looking at this Sony model and would like to purchase.
yes, you must have at your tv one of this plugs: Connector Type Sony DVP-NS710H 1 x Composite video output ( RCA phono ) - Rear , 1 x HDMI output ( 19 pin HDMI Type A ) - Rear , 1 x Component video output ( RCA phono x 3 ) - Rear , 1 x Audio line-out ( RCA phono x 2 ) - Rear , 1 x Digital audio output (coaxial) ( RCA phono ) - Rear on your tv the connector is input.
Feb 14, 2010 | Televison & Video
DVD and older magnavox TV
On most of the older sets the video input is found by channeling down below channel 2 where you will find the video input source.
Nov 23, 2009 | Philips DVP3140
How do I link my IBM t21 to my TV. The sounds works ok from the sound port, and i have an S-video cable to RCA connected, but do not get any picture on my TV
http://www.youtube.com/watch?v=XqjJtdH_EI8
  1. 1 Determine what kind of inputs your TV has. Many sets have the HDMI, DVI or even VGA inputs common on most newer PCs. If you have an older TV with only an analog signal, you will have to get a video card that supports your TV's connection. To determine what kind you need, take a look at the audio/video inputs on the side of your TV. S-video is circular with a bunch of pins; composite video is yellow; and component video is red, green and blue.
  2. Step 2 Find out what kind of video output you have on your computer by looking at your video card. DVI is pretty standard on most computers manufactured in the last four years. Multimedia PCs will have DVI and HDMI. Of course, if you swapped out your video card to accommodate an older TV, your machine will not have either of these connections any longer, but will instead have the one that matches your TV.
  3. Step 3 Purchase cables to run from the TV to the computer. The video cables you need will have the same name as the type of connection on your TV. (For example, if you have S-video, look for an S-video cable.) Note that you will need a stereo-mini-to-RCA cable for the audio as well. All cables are available at most electronics stores. If you shop online, try MonoPrice.com to save some money. (See the link in Resources.)
  4. Step 4 Connect the cables. No matter what type you have, one end will go in the TV and the other into your computer's port (the video cable in the video card and the audio cable in the audio card). It will be fairly obvious what goes where due to the shape and coloring of the ports. Once both cables are hooked up, make sure the picture and audio on the TV both work. If not, check your connections.
Oct 07, 2009 | IBM ThinkPad T21 Notebook
I have a older tv so i pluged it in with the
plz ask complete qstion bcoz i cant understand ur qstion.........as u know that three cords . 1 for +ve & 2nd for -ve & one is for neutral.......try combination of different wires............& ur tv will work normally
Mar 08, 2009 | Sony Playstation 3 (PS3) Console
AUX mode
Try to disconnect power for at least one day.
good luck---------tomtaso
Nov 04, 2007 | Zenith B32A24Z 32" TV
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
Electro Med Services...
