Question about Lexmark Computers & Internet
I have an apple mac computer and a lexmart z611 printer. It was working until the the ink ran out. I instaled new ink ,but I brough the wrong one .I have the right one now. still don't print. What do I do now?
  • icradle May 15, 2010
    No that was not my problem.
First, remove the seal tape from the top and bottom of the new ink cartridge. Install your ink cartridge and do a “head cleaning” cycle using the Lexmark software that downloaded from the original CD when you bought the printer. Next, disconnect the printer from your computer.
Press the “Cartridge Change” button for three seconds.
When the Ink Cartridge carriage travels to the changing position, pull the power plug (NOT the “OFF” Switch). The Ink Cartridge carriage should now slide freely on the rail as long as it isn’t pushed to the right so that it goes under the shelf to the “homed and locked” position. Fold up a paper towel (use one sheet) so that it's final width is about the same as the width of the gutter under the print head on the carriage and so that it is thick enough when folded to contact and lightly press on the print head. Saturate the folded paper towel with ~ 70% Isopropyl Alcohol. Manually slide the carriage and print head over the wet paper towel. A slight amount of drag should be experienced if the thickness of the paper towel folds is correct. Let the print heads rest on the saturated paper towels for a few minutes or hours. Too long a Treatment may pull out all of the Cartridge’s Ink: Check the Paper Towel Frequently to Assess if Ink is coming out onto the Towel. Run a Test Pattern via the Computer connection WITHOUT first running the Head Cleaning Utility. If the pattern isn’t ok, try running the head cleaning utility to see if it makes it better or worse. If Worse, repeat the alcohol paper towel treatment: The paper towel may be gently pulled back and forth under the Print Heads to wipe them off
Posted on May 15, 2010
  • 952 Answers
Thanks for using FixYa.
If you have installed the wrong ink after you bought it, there is a chance that you've damaged the printer head. Try using a different computer and install the printer drivers there see if it still won't print. If it doesn't print, you've just isolated the issue and it is the printer head.
I hope this helps. Thanks and good day.
HotRatchet
Lexmark z611 printer
First you removed old driver and PC restart and some time wait restart PC and Installation before PC full scan and removed it virus if virus available in PC then be be not proper driver installed or many error show, better of virus remove then installed driver. Driver installation after check it ink label if ink shoot then not any print if ink available or not print then open printer cartridge or check it damage you ink cartridge.
http://support.lexmark.com/index?segment=SUPPORT&userlocale=EN_US&locale=en&productCode=LEXMARK_Z611&page=product&frompage=null#1
Thanks,
Lexmark Printer Support
May 21, 2014 | Apple Computers & Internet
/usr/libexec/cups/backend/lpd failed
This sounds like a printer issue rather than something wrong with your Mac. When you refill your printer ink cartridges the ink level setting won't change, and if you let the ink level go down too far before refilling the printer marks the cartridge as empty and locks it out. (something like that)
Try this... It should work on most newer model printers.
Shut down your Mac. (important) Turn the printer off and leave it off for one or two minutes. Turn it back on and wait until it goes through all of its whirring and clicking and chugging start-up noises. When it's quiet you should end up with a flashing "E" or an upside-down "u" on the display. Find the Reset or Stop button on the printer and hold it down for 6 seconds. The display should clear and show the number "1".
Turn on your computer and print. If it works, you're done.
If that didn't work pull down the Apple menu and choose "About This Mac". If it says Version 10.6.8 you're about to spend $29 because the message "/usr/libexec/cups/backend/lpd failed" was common with that version of OS X, and that was the last version of Snow Leopard 10.6. Click the "Software Update..." button which will open the App Store. Shell out your 29 bucks for Mavericks OS X 10.9.
The only other solution would be to replace "lpd" from a different computer that's running 10.6.7, which is doubtful. (unless you have a backup)
Good Luck!
Oct 23, 2013 | Apple MacBook Pro Laptop Computer with...
I just purshased a lexmart pro 705..How do you install the ink???please help
Replacing ink cartridges
Make sure you have a new ink cartridge or cartridges before you begin. You must install new cartridges immediately
after removing the old ones or the ink remaining in the printhead nozzles may dry out.
1 Turn on your printer.
2 Open the printer.
Note: The printhead moves to the cartridge installation position.
3 Press the release tab, and then remove the used ink cartridge or cartridges.
4 Install each ink cartridge. Use two hands to install the black cartridge.
Note: Install the new ink cartridges immediately after removing the protective cap to avoid exposing the ink to air.
5 Close the printer.
The setup guide is on theCD you received with the printer.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 23, 2011 | Lexmark Office Equipment & Supplies
I WANT TO PUT THE SOFTWARE TO A NEXT COMPUTER
Here's the link for the available Lexmark Z611 drivers: http://bit.ly/d3ryl7. Click on the Microsoft drop-down found below the page to choose the version of your computer's operating system. If you are using Windows 7, use the Vista drivers. Download and execute the file. Unfortunately, printer is not compatible Mac. There are no drivers for Mac.
Aug 25, 2010 | Lexmark Z611 InkJet Photo Printer
I have a Apple imac desk top, and a Lexmark Z611 printer I put the wrong ink in. I replaced the right one. It is saying I no ink in it. How can I fix this?
z611_lg.jpgWell, first of all, you should check if there's physical damage with the cartridge head, clean the heads for both cartridge and printer. com10n0026.jpgcom10n0016.jpg Now you need to reset the printer settings, remove all the cartridges, power cord, usb cable, open the printer cover and keep it for few minutes. Also unplug the Adaptor from the Mains socket. Do this while you clean them. Dowload the driver from this link http://www.siliconguide.com/drivers/device/212/ and update your printer's drivers. After finishing all these process, reconnect all the cables, (don't power on the adaptor), put the cartridges. Restart your system while you power on the printer, to power on the printer, this time, you will need to press and hold down the power button, otherwise it might not take effect. This will reset your printer and you'll not get the error. You can also try another trick, remove both the cartridges while the printer is still On and reinsert them one by one. Sometimes this also works and get easily fixed. Do let me know if there's still problem. Good luck.
May 20, 2010 | Apple iMac G5 MA064LL/A Desktop
Dell All in One 922 won't work with my Mac!!!
you could try the lexmark drivers as that is what it is, what happens when you try to print?
Oct 05, 2009 | Apple MacBook Pro Laptop Computer with...
Lost disk
Assuming your new computer came with Vista, here is the place where you can download your driver:
Lexmark Z611 for Vista
Lexmark Z611 for XP
Just Click on the file, select run, and it follow the onscreen prompts.
Jun 23, 2008 | Lexmark Z611 InkJet Photo Printer
Printer now working
Should work, try to print and you should get the print window (press the apple key and P together works) the top line is also the printer select feature, click the blue box to the right with 2 little up and down arrows and you should get an add printer button, follow instructions , if it cant see the printer (make sure it is connected and on) look on the laxmark site for a driver (there is an option when installing the os to not install all the drivers that apple inlclude)
Jan 13, 2008 | Lexmark Inkjet Z517 Photo Printer
Computers & Internet Logo
21 people viewed this question
Top Lexmark Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Robert Monigold
Robert Monigold
micky dee
Are you a Lexmark Computer and Internet Expert? Answer questions, earn points and help others
