Broken cassette deck
My dual cassette deck is broken. One deck would not open and I had to force it open. (luckily, did not break it). I have kept both decks open since then. Now whenever I turn on the unit and use anything else, like the cd chamber, it makes a noise like the cassette is trying to realign itself. Ca-chunk, ca-chunk ca-chunk, etc. Is this worth fixing and does anybody work on stereo equipment anymore?
  • dashap54 Mar 30, 2008
    What a ****
Just buy a new 1 you gipo
Posted on Mar 30, 2008
How do I get fast forward & rewinds to work on my Teac W450-R dual cassette deck..?
Check the belts, inside the unit you should see a rubber belt which is what pulls the tape fast forward or rewind. Some belts with time get loose and slip, they can also break and fall off which will not let you fast forward or rewind.
Open your cassette player and look where the plastic pulleys are located and check for the belts, they might not be broken at all but very loose and slip on the plastic pulley.
Jun 07, 2015 | Teac Audio Players & Recorders
Model TC-W233 when I push the power button nothing comes on???
There is either a burned out transformer or more likely a broken solder joint or defective power supply part in the unit- it needs professional work.
Sep 10, 2013 | Sony TC WE435 Stereo Dual Cassette Deck...
Sony TC-138SD cassette deck starts to play then stops after 3 secs. Same when trying to rewind/fast forward
It sounds like the belt is slipping or broken which monitors the speed of the tape movement. When you play or rewind the tape, it thinks the tape has reached the end of play and shuts off. You can try a different tape to make sure the tape does not have too much tension on it. If the second tape has the same result you will need to remove the top cover of the deck to inspect the tape drive mechanism. Make sure the belts and pulleys are clean and replace any belts which have glazing or cracks. If the belt is broken you will need to replace it with a compatible belt of the same length and width.
Aug 15, 2011 | Sony CASSETTE DECK Single Dual Cassette...
When playing a tape it may stop randomly and the counter displays zero. I have to push play button again and it goes on; but may stop after a while. It does not depend on cassette type or tape length (I...
This would indicate a power supply problem in that the counter being reset. I would check the entire power supply for a any thermal broken solder joints and redo them with the power off. If you need further help I am in the Chicago area and am known as Skywave Tape Deck Repair.
Feb 07, 2011 | Teac V-8030 Dual Cassette Deck
Wheels on the tape deck don't turn on either side, forward or reverse on Sony dual cassette tape deck
You have a broken transfer belt and it needs replacement.
This will require you to take the tape deck apart to service it.
Mar 24, 2010 | Sony CASSETTE DECK Single Dual Cassette...
My record button won't go down. How can I fix it?
This is normal if the cassette tape has a broken tab. Try a different cassette or inspect the cassette to ensure that the write protect tab is not removed. where to look? On the cassette opposite side to where the tape is there are two possible places, each on the side of the cassette case. The broken tab is a feature that prevents accidental recording over an existing program. It also stops the record button from being pushed. The tab is a plastic part that is easy to break with a pen tip.
Jul 18, 2009 | Technics RS-TR272 Single Cassette Deck
Sony Dual-Deck Cassette Player/Recorder, doors won't close
Are both sides not staying shut? If it's only one side, look to see if the latch is broken. You should see an arm move when you press down the eject button - while the door is open, press the eject button and see where the arm moves. You should see a hook that catches the door and keeps it closed. It could be broken, or just jammed. Look at the other side of the deck and see it it looks like it's working the same. Unjam the latch arm if it's stuck, or replace it if it's broken.
Feb 23, 2009 | Sony Dual-Deck Cassette Player/Recorder...
Play function won't disengage on Technics dual cassette deck
Remove the cover to see if any belts under the cassette player is cut. Or to see if there are any obstructions.Remove the front cover.which will remove the tape housing of the cassette player. you can check for any broken plastic compoments that might be keeping the housing from opening.Or any belts that may have been cut.
Dec 25, 2008 | Audio Players & Recorders
Teac A-21 Stereo Cassette Tape Deck turns un, but won't play cassette tapes...
very likely that the drive belt has broken. I have fixed a TEAC myself using a large O-Ring from a hardware store (I know I was lucky to find a very close match). Open the unit and find the broken belt and take it to a hardware store to "size up" a replacement. Use the opportunity to oil the gear shafts and clean the rubber pinch roller.
Jun 22, 2007 | Teac DUAL CASSETTE A/R 110/220 Single Dual...
63 people viewed this question
 Grubhead
Grubhead
