Question about Weber Genesis E-310 Gas Grill
1st of 3 burners will not light. The other two have gas flow.
1st of 3 burners (the ignitor) burner does not have gas flow. I can hear gas flow on the 2nd and back burner..and i can light with a match. But can't figure why first burner does not have gas flow or how to fix it.
Can anyone help?
BW
  • Weber Master
  • 2,558 Answers
Blocked burner or gas injector or gas on off switch blocked
Posted on May 16, 2010
The igniters for the 6 burner are not sparking. The igniter for the griddle does spark. i do small gas when trying to light-how do I get to the spark modules
Gas Stove Top Burners Not Lighting / Not Working - YouTube
? 5:20
https://www.youtube.com/watch?v=dP3l5AW3YrI
Jul 19, 2012 - Uploaded by Bill Newberry
... not lighting. These are the 3 main reasons for gas range burners to not light. ... I see the igniter sparking but not lights up the gas. One thing I ...
Gas Stove Ignitor and Burner Not Lighting - YouTube
? 1:10
https://www.youtube.com/watch?v=1ZXz8_Md8hI
Nov 20, 2011 - Uploaded by Mike Klimek
Here is an easy fix if you hear the ignitor "clicking" but not lighting the burner. For more information, go to ...
How to Troubleshoot Gas Stove Burner Ignition Problems ...
homeguides.sfgate.com > Landlords & Tenants > Landlord Problems
Dec 19, 2015 | Kitchen Ranges
Hotpoint gas stove. burners work, oven and broiler do not.
Probably the safety valve. This unit broils and bakes off the same gas burner. A spark ignitor lights the pilot and this save gas because no standing pilot is needed. It takes a few minutes for the thermocouple bimetal combo to release the gas. When the temp gets to the desired rate then the bulb on the oven control closes off the flow of gas. To recap: The flow of gas comes from a regulator along a rail which supplys the gas to the top burners and the oven control. older models had pilot light tubing going down to the oven and to the top burners. This newer style uses a spark module to light off the top burners and the oven. So when yall turn the the oven on the spark ignitor lights the pilot first and then after the mercury bulf thermocouple heats up the bimetal inside the valve opens allowing gas to flow out to the pilot and ignite the gas burner. the temp rises and the mercury bulb oven control expands closing off the flow but not the gas safety valve. I would suspect the safety valve on this one.
May 09, 2011 | Hotpoint RGB528 Gas Kitchen Range
Kitchenaid gas oven very slow to start - can be 5 - 10 minutes before I hear it kick on. For a while I could get it to start by turning on a gas burner, but that is 100% effective. Any suggestions? Also...
Replace your ignitor, this is a very common problem. As the ignitor gets older, it gets weaker. When it gets weaker, it usually starts out by not giving good temps in the oven, then it starts to take longer and longer before it lights the oven burner, then it stops lighting the burner completely. A good ignitor heats up fast, allows the current to flow through to the gas valve, opens the gas valve and lights the oven burner within 30 to 50 seconds. When you order your ignitor ask if their is a cheaper generic ignitor for this model. Their can be a huge price difference in some units. You can also have a bad sensor, control board, gas valve, or wiring problem, however for the last 15 or so years every job I have done with your problem has been an ignitor. Good Luck, Appliance Specialists
Jan 26, 2010 | KitchenAid KESC307 Electric Kitchen Range
We have a 6 burner, nat gas cooktop....all unit light but the igniter clicking will not stop...unplugged it . question: all mechanics are closed is this safe gaswise?
What happens in this style ignition system is that the thermostat or electronic control switches power to the oven ignitor and gas valve circuit which are connected in series (one after the other). As power flows through the ignitor it heats and draws current (measured in amperage). Once the oven ignitor draws a specific amount of current the oven valve opens to allow gas to flow to the oven burner where the glowing hot ignitor (glow bar) ignites it. Power must continually flow through the ignitor and oven gas valve for gas to be released into the oven burner to create a flame. Once the set temperature is achieved the control stops all power to the ignition circuit which causes the ignitor to dim and the oven gas valve to close, stopping any burner flame. Cycling on and off continues to maintain the specific temperature the control is set for.
Jan 09, 2010 | Microwave Ovens
Gas furnace, main burner ignites the other 2 don't. then shutdn.
Between the burners is a small rail in the pressed steel where the flame runs across to light the other burners and it sounds like there is dirt or debris in the step over rails causing the problem. You will need to use some compressed air on those rails to clear them out. Once the rails are clear the other two burners should ignite right away.
Dec 21, 2009 | Heating & Cooling
GE gas range, model #jgbp33wen5ww, ignitors clicking and gas flow on all 4 burners, but none of the burners will light.
the burners on ge range are different in size / you may have the caps on the wrong burners . 2nd / ck for the hole in the burner are clean ( do not enlarge them when cleaning .. ) if this does not work . see if the ignitor's are in good cond . if chipped replace .. mm
Nov 22, 2009 | GE Profile JGB900 Gas Kitchen Range
Dead burner on kitchenaid gas cooktop?
it is strange that you have no gas and no spark! if you held a match to the burner and turned the burner valve on it would lite di spite a failed ignitor,but for it not to lite, the burner valve[its what the knob attaches too] would have to be blocked[thats rare]or ........i got it .....the knob is broken.thats the only thing the burner valve and the spark ignitor have in common.try a knob from another burner................again.you have spark,because others are working.spark on troubled burner would work if valve blocked at orifice outlet,and if spark failed you would still get gas they work independent of each other,[but in unison].thats why im thinking knob.its the item that works both .when you turn the knob it opens the gas valve and as the gas valve rotates by turning the knob it activates or turns the spark switch so it closes the curcit allowing the electricty to the spark moduel.hey i hope that helps a little. God bless ,tom
Feb 13, 2009 | KitchenAid Cooktops
GE Profile Gas Cooktop
Do you hear the spark ignitor trying got light the burner?
If not, then make sure there is not a residue or film of cleaning solution on the burner bases or burners themselves. It could be coincidental that the spark ignitor failed when she just happened to be cleaning the unit.
Jan 23, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Thermador Gas Range - Griddle ignition will not spark
I have a Thermador Gas Range PG364GDBS - Oven, 4 burners, and center griddle. All are gas. The four burners and gas oven work fine. The griddle just stopped working, no spark. Turning on the griddle control, the gas valve opens(hear it), gas flows (smell it), but the ignitor will not spark (no loud or faint spark that I can hear). I got a replacement ignition device (mount at the burner) thinking it might be the problem, but still no spark. I checked the AC voltage at the terminal and measured 39 VAC between the terminal and ground. Not sure if that is the correct voltage. Any insights or advice would be great.
Dec 07, 2008 | Thermador SGS36GS Gas Cooktop
Ge spectra gas stove top not lighting
If your top burners are not lighting or will not work, it is possible that the burners have become dirty or wet. Please follow the troubleshooting directions below before calling service:
  1. Turn you burner to the Lite position:
    If you hear clicking or sparking, go to Step 2.
    If you do not, check your circuit breakers. If the circuit breaker is ok, we recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
  2. Clean the burner and electrode:
    First remove the burner grate, cap, and head. Use a needle or paper clip to poke through the holes on the burner head. Re-assemble and try the burner.
    Remove the burner grate, cap, and head. Even if it looks clean, wipe the tip of the electrode with a clean, dry paper towel and PRESS IT DOWN. Re-assemble and try the burner, again.
    Check to see if the burner works, If not, then go to Step 3.
  3. Re-assemble - Make sure that each burner top matches its burner bottom. The burner top will lay flat if put on correctly.
    Check to see if the burner works, If not, then go to Step 4.
  4. The spark igniter is operating properly, but the burner is still not lighting. At this point, we would recommend that you schedule service by calling 1-800-432-2737 or schedule service online.
Aug 15, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Weber Genesis E-310 Gas Grill Logo
387 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
