Question about Mantis 2-Cycle Tiller
My mantis 7222m two stroke will only run for a few seconds
It will then die. Some times it will run for a few min. if i just let it idle will then die as soon as I give it any gas. I tried fiddling with the two adjuster screws on the carb but that did nothing but make it not run at all until they were lined up in the previous position. New plug, new air filter, new gas. nothing seems to work. any suggestions would be great. many thanks in advance.
Jeff
  • 97 Answers
SOURCE: mantis tiller 2 cycle seemed as if it was running out of gas
Check fuel filter and lines, if thay are good I would get a carb kit and set the adjustment screws at 1 turn out from lightley seated to start. Don't lean high speed screw too much.
You might check muffler & cylinder port for carbon first.
Posted on Mar 21, 2009
SOURCE: Would like to know what year this tiller would be.
replace primer bulb. If that's not the problem check the float in the carb for pin holes . check fuel lines and intake line
Posted on May 17, 2009
  • 15 Answers
SOURCE: Won't stay running...
I had the same problem with my mantis. It would start fine after a few pulls, but had no power. I changed the plug, replaced the carb completely...nothing helped. Took it to a shop and paid $70 for a tune up that didn't help at all, and the shop owner just said "sorry".
After everything else was done, I pulled the cover off the muffler, (3 screws) then removed 3 screws over a small spark arrestor screen and found it was clogged...cleaned it and guess what...IT WORKS FINE NOW!
The best and easiest fix I have ever done to a small engine. I felt like an idiot, because the exhaust side of the motor MUST be clear to work properly on small engines. The only reason I was removing the muffler in the first place was to check the compression and VOILA!!!
An easy and quick fix I recommend for all Mantis tillers before you waste money on carb issues (which is what the company will tell you to fix to solve this problem).
Posted on Jun 03, 2009
wolfwizard11
  • 5 Answers
SOURCE: MANTIS WILL NOT IDLE
I had the same problem. I adjusted the throttle stop IN until I got an idle without touching the throttle.
Posted on Aug 04, 2009
  • 150 Answers
SOURCE: 7222m mantis tiller need a diagram or set up
Set low speed jet 1 turn out high speed 1 and a quarter turn out
Posted on Sep 27, 2010
I need a mantis tiller primer bulb or one that will replace it
just got one at Lowes Hardware. Its a three pack with three different sizes. largest works
Jul 27, 2012 | Mantis Tiller
MANTIS TILLER WITH HONDA GX25 ENGINE STARTS FINE BUT WHEN GIVEN THROTTLE DIES OUT. ALSO A LITTLE WHILE BACK OIL WAS COMING OUT OF CARB BUT THIS HAS NOW STOPPED. THIS IS A 4 STROKE ENGINE WITH APPROX 4...
I also have Mantis tiller for 2 years. From the very beginning I had a problems. I was referred by Mantis to the repair store and was charged $90.00 for oil drainage. The second time I was waiting for handle replacement for ~ 1 month. This tiller can't handle even little jobs and the warranty doesn't worth a dime. Maybe I will be more successful using it in my living room . I have an equipment with Briggs and Stratton engines and I never had a problem.
To me Mantis mean big advertisement and waste of money.
Feb 20, 2011 | Honda Hmantis Mantis Garden Tiller with...
7222m mantis tiller need a diagram or set up adjustment for the carburator
Sep 27, 2010 | Mantis Garden
My mantis starts easily - but then dies. it sometimes doesn't even rotate. i can do about 3 seconds before it dies. help. what do i do?
The Carb is either cracked or needs to be rebuilt - OR - you might get luck and just blow it out with a professional dose of AIR from a larger compressor like used at mechanics shops.
Gary @ Fix Ya
Sep 05, 2010 | Mantis 2-Cycle Tiller
Mantis tiller starts but will not stay running
Carburetor problem. Two stroke engines use oil mixed with gas. Old fuel or setting over the winter will cause varnish and sludge in the Carburetor. Start by buying a can of carburetor cleaner and mixing a new can of fuel.
1) Dump the old fuel and check replace it with new.
2) Remove the air cleaner.
3) Pump the prime bulb 3 or 4 times, set the choke, spray the insides of the carb with the cleaner and then try and start it . It should sputter and run for a few second but chances are it will take a few sprays to clean the jets
Jun 06, 2010 | Mantis 2-Cycle Tiller
How do you start a 2 stroke Mantis? I lost the book. Will
first, push the primer bulb a few times to get fuel circulated and air out of the carb. Turn on the switch, put the choke on full. Pull the rope until you hear it fire. Then put it on half choke. Pull the rope; it should fire within a few pulls, and should run. Take the choke the rest of the way off once it's running well. This is a standard starting procedure that works well for every kind of 2-stroke engine used in the garden.
Mar 28, 2010 | Mantis 2-Cycle Tiller
May 15, 2009 | Mantis Tiller
Mantis 2-Cycle Tiller Logo
159 people viewed this question
Top Mantis Garden Experts
paulfvincent
Jim Parker
Jim Parker
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
