Question about HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook
Invalid ip address on lan when I try to connect
    Sniper:
  • 51 Answers
Check IP settings on computer. If you are using router with DHCP support, I would suggest using that and avoid using any static IP addressing. Remove any IP addresses that have been manually set up on your PC, and let the router provide an IP address. If this seems to go "over your head", then please provide more information as to your setup and equipment, and I can elaborate on how an effective fix can be applied.
Posted on Jun 08, 2010
Invalid IP address for some client computers when powers goes off
If power goes off probably the network cards of the clients not work,PC must need to be on.
Apr 15, 2013 | Computers & Internet
Cannot connect to the internet on the Toshiba Netbook. Has very strong network signal.
Troubleshoot the issue by identifying the ip address that your computer has. May it be wireless or local area connection. Check IP Address thru command prompt or DOS.
· press <windows key>+<R>
· type "cmd"
· press ok button. a black box will appear
· type "ipconfig /all" then press enter key
· locate wireless connection and local area connection group by scrolling up/down.
NOTE: ignore highlighted physical address.
If the ip address is 169.xxx.xxx.xxx, this is an invalid ip address. Contact Internet Service Provider. If the ip address is 192.xxx.xxx.xxx, click start and open control panel. then open internet options. click on connections tab. click on lan settings. Make sure no tick box checked. All set your anti virus' firewall settings to default. Then try browsing.
I hope this works for you. KINDLY REPLY IF FURTHER ASSISTANCE NEEDED. Good Luck!
Mongkey
"Understanding explains better..."
Jan 27, 2011 | Computers & Internet
I run the Scangear tool, but it cannot find the scanner, by accessing by web, or physically on the display; the device says that the scanner is ready. When clicking in the discover button, it finds...
what kind of cable you use? is the computer and the machine connected to a switch or to each other?
if it is connected to a switch try a cross LAN cable.
Nov 11, 2010 | Canon imageRUNNER C2620 Color Copier
Can't connect to my linksys wrt54gx2 router and even when I do, it tells me there is an ip address conflict and disconnects me
try to connect using a LAN Cable (Wired) connection. and then try to access 192.168.0.1 you should be able to see wireless settings there.
IP address must not be the same with the IP Address of other computers in your house. look for the Range and Increase it so that the router could have a wider range of IP Address to choose from.
Oct 02, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
Using Nintendo Wireless Adapter - No Connection Anymore
If available networks are found, it means that the wireless adapter is working just fine. In case of Wi-Fi, the device has to acquire an IP address from the wireless router and the mutual communication is not taking place. This has something to do with the wireless router. Check for any kind of security filtering like MAC address filtering or lower down the encryption technique to 64-bit WEP. Try connecting to even an unsecured network, then check for the automatically acquired IP address. It should never be starting with 169.254.xx.xx (Invalid)
If you have other wireless computers going online in the same network, without security and filtering, then it means that your DS Lite is not acquiring an IP address. In that critical case, you may have to statically or manually assign an IP address in the range of the router.
And lastly, as you said LAN connection is active, it would be because it doesn't face any hardships while connecting!
Thanks..
Do get back if you need further clarifications.
Mar 18, 2010 | Computers & Internet
Where is the ip adress
If you want your WAN IP address(Internet IP):
www.ipchicken.com
If you want your LAN IP address:
Go to Start then Run
Type in ipconfig
There is your LAN IP, usually starts with 192.168.x.x
Oct 06, 2009 | NetGear RangeMax WPN824 Router
Getting error message: Invalid Ip address
This would normally mean that you have assigned the IP address manually but have also given that same IP to another computer and they are fighting about it.
If this is the case then just check your IP allocations and find out which computer is using the same IP and change it to one that is not in use.
It may also mean that your router is trying to use the same IP as your modem
With just your modem connected to the computer
go to the START MENU / RUN then type CMD and press enter.
Now in the black screen type IPCONFIG /ALL
Take note of the numbers esp in the default gateway, that is your modem)
Now with just the router connected by wire do the same thing.
This time the default gateway is your router if it is the same as your modem then you need to alter it in your router,
You haven't given a model so you will have to work this bit out yourself but your are looking for a setting on your router that starts with the same number you got.
If your default router gateway was lets say 192.168.1.1 then that is what you would be looking for. Change the third block so now it reads 192.168.2.1 and save the settings. This would clear any conflict between modem and router.
If you have assigned IP's to computers they would need to be changed to reflect the routers new IP and again you would just change the third block in the allocated IP to a 2
If in doubt read this a couple of times or print it out.
If this information was of any use please click below
Aug 18, 2009 | NetGear Computers & Internet
Says I have an invalid IP address
Go to control panel select network right click icon go to tcp/ip properties and choose get ip address automatically DHCP
May 01, 2009 | Gateway GT4016 Desktop PC
Can't connect to my router
Try this;
Just set it again via wired connection or LAN. Access it via Network Connections, and under Network connection look for for your LAN. Right click Local area connection,click properties, then highlight Internet Protocol(TCP/IP), click properties. Under General choose "Use the following IP Address ".
Input on IP address you should have router tutorial. Commonly its default is 192.168.1.1
Subnest Mask 255.255.255.0
Default gateway 192.168.1.2
Under it choose " Use the following DNS server address"
Input DNS address DNS of your ISP
Click ok
goto Inernet browser tab input 192.168.1.1 this will direct you to router configuration setting input its user and pass. If unchanged see tutorial of your router or at the bottom of the router. Then you can change setting of your router.
Hope it helps.
Apr 08, 2009 | Zyxel Prestige 660R Router (P660R)
HP Pavilion dv2000t 14.1" Notebook Laptop PC (Intel Core 2 Duo T5500 1.66 GHz, 1GB RAM, 100GB HDD, D... PC Notebook Logo
116 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
