Question about Maytag 24 in. MDB4100 Built-in Dishwasher
Goes thru cycle but wont drain, check filter ok , water sits in t
Wont drain
    Problem Solver:
  • 4 Answers
Have you recently installed a garbage disposal?? If so, you probably didn't knock out the plug where the dishwasher hose attaches to drain. I had the same problem with mine. Thought it was going to be an expensive fix and just had to disconnect the hose and punch out the plug with a screwdirver and hammer. After you punch it out though, don't forget to pull it out of the grinder area. ;)
Posted on Jul 10, 2010
  • 31 Answers
Check the pump motor for obstructions like: broken glass, paper from labels, food. Also some maytags have a cover screen... check that it is not filled with debris (****)... How old is the unit?
Posted on May 16, 2010
Frigidaire FDP635RFR3 wont drain.
Theres a drain pump located at the bottom of the unit if you follow the hose from the pump then to the drain if your unit isnt draining you might have to call for service from a technician to have them change your drain pump. If the water is just sitting inside the unit and when u start the unit it should fill with water again.Also if you have a cancel function by pressing this you will make the unit drain if you dont hear anything when u press the cancel button you definetly need a pump
Apr 28, 2010 | Dishwashers
WM2487HRM goes thru the wash cycle then gives OE error message. after drain tub with drain tube and reinsert drain filter, will happen again. if drain tub and unplug for 30 minutes, it will do spin only...
Drain hose is kinked or clogged the pump filter needs cleaning .
always turn machine off when working on it . and donot forget there is always water in filter .so put blanked or towels down.
Feb 12, 2010 | LG WM2487HA Washer
My washer wont drain it goes thru all the cycles but wont drain. at first with clothes in it it would drain onto the ground and not thru the drain pipe. took the front cover off to see where it was leaking...
Sounds like the drain pump has failed. Try to turn the impeller to see if it is bound-up. It may just be debris blocking the rotation of the motor. Is there a filter that has plugged?
Feb 10, 2010 | Kenmore 98702 Stacked Washer/Dryer
Washing machine wont drain keeps bleeping ERR2
It will not spin with water in.
See if you can locate a filter, and clean same.
Jan 19, 2010 | Haier Washing Machines
Washer won't drain.
My washer fills up with water and goes thru the wash cycle but when it's time to drain, it just sits there and clicks.
Oct 17, 2009 | Tecnik TKL9260 Front Load Washer
Washing machine wont wash or spin, just fills and drains
THE MODEL NUMBER IS USUALLY FOUND SOMEWHERE AROUND THE OPENING OF THE TUB OR ON THE LID ITSELF
Apr 24, 2009 | Washing Machines
Won,t drain on rinse cycle
Ok mc we need a timer at this point. You see the timer doing several steps different than before.
Nov 01, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Dishwasher not draining
Hello Tony,
Before pointing the finger at the pump.. try these few things first..
Make sure your drain screen filter is free of food by products and not restricting water flow out
Make sure your drain hose is not pinched, clogged or restricting water flow out
Make sure the place your drain hose drains into is not restricting water flow out
If you have water remaining in the base of the wash compartment, bail out as much as you can then run a dishless cycle to see how much water remains in the comaprtment. If it drains completely, then you should be ok.. if not then, you may have a bad pump, obstruction in the line into or out of that pump.. Let me know how it goes after you run thru the checks listed above and the outcome of the wash cycle. Hope this helps..
Regards
Oct 11, 2008 | Dishwashers
Rinse water fills the washing machine when the spin cycle starts
Check your outlet filter, most likely it is blocked, preventing the water from draining out. Chk your pump too. Before this disconnect from the wall socket; and also check the pipe coming from the tub to the filter. Siphon out the excess water from inside the machine before you open the pipes.
May 17, 2007 | Frigidaire FGX831C Top Load Stacked Washer...
Maytag 24 in. MDB4100 Built-in Dishwasher Logo
115 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
