Question about Kenmore Elite 45986 Front Load Washer
I have a Kenmore Elite Front Loader Washer Model 110.4282201, it is not ringing out all the water from the clothes, why??
  • 15,935 Answers
There is a water pump in the machine which pumps the water out of the outer tub and into the drain, after the wash and rinse cycles.
It is possible that this pump isn't working properly. I think if it weren't working at all, you wouldn't be able to get beyond the wash cycle.
It has been my experience that small articles of clothing may get washed or spun out of the inner tub and into the area around the pump pick up, thus partially blocking the flow to the pump.
It's also possible that the drain hose from the pump to the drain may be partially clogged.
It is also possible that the pump doesn't run sufficiently long to get all of the water out because its' motor gets hot and shuts down or because of a problem in the control mechanism which manages the the starting and run time of the pump.
First, I would unplug the washer from the wall outlet and probe under the inner tub, or possibly remove the tub to see that there is no blockage from clothing.
It's also possible that things left in clothing pockets like paper clips, small plastic items, etc. can get into the pump and lock up the impeller.
If you're sure it isn't blocked you can then run a "short cycle", no load and water only, and watch to see how much water comes out of the discharge hose where it's hung on the drain pipe.
It should gush out, and tub should be free of standing water prior to the start of the first rinse cycle.
If it does not, then you'll have to access the pump and clear it of obstructions or replace it, if defective.
As it drains, it should start spinning slowly, then speed up as it drains; the final portion of the spin cycle is very fast.
Essentially, the spinning tub wrings out the clothes using centrifugal force.
With the water remaining in the bottom of the tub, it would appear that it is:
a) not spinning long enough, or
b) there is something preventing all the water from getting out in the time allotted by the timer to perform this task.
A fair handy man can get to pump either from the rear of the machine with back plate off, or by removing the cabinet cover from the frame, depending on the model of the the machine.
As always - before attempting any repair, UNPLUG THE UNIT!
When clothes are wet at the end of a cycle, check these:
Motor coupler
To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
If it's spinning when you lift the lid, the coupler is fine.
If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning
If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve
Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
I have a Kenmore Elite front loading washing machine and it is flashing the FH code. I've had a repair man out to look at it and he thought it was repaired. The washing machine was running just fine through the rinse and spin cycle while he was testing it. After he left I was able to do two or three loads of laundry and then the code came back. Any help with this would be wonderful!!!
Posted on Jul 21, 2014
Smelly discharge water
smelly front loader???all front loader tend to leave a little water left over in the inner tub after every load,always leave washer door a crack open to reduce smell/mold on seal,to get rid of smell simply run a normal cycle,no clothes,with a dose of bleach or better yet AFFRESH,made by whirlpool,a bleach tablet with fragerance,sanitze and smells good!!answer,,,AFFRESH
Mar 27, 2012 | Kenmore Elite 45986 Front Load Washer
Bellow for Kenmore Elite front-loader washer
The Bellow should be available at a appliance part store. be sure to call with the model number and serial number, that way if they don't have it they will have time to order it.
Apr 12, 2010 | Kenmore Elite 45986 Front Load Washer
Not getting clothes clean
Check your drain hose for siphoning. this is a common problem, make sure only about 8 inches is sticking into the drain, and the drain line is higher then the mid point of the washer, ex: drain hose must not leave the washer and head directly to the floor, must make a loop upwards, then enter a drain appx. 3+ft high. Drain hose from washer not to enter drain plumbing more then 8".
Jun 25, 2009 | Kenmore Elite 45986 Front Load Washer
No water level in new Kenmore HE3T Steam front loader
high effeciency washes use very little water , the water is at the bottom of the drum (not visible )
Jun 07, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Front loader washer doesn't spin clothes as dry as before
The out-put pump is possible clogged up and not moving the water efficiently, also check the pully belt is tight
Dec 14, 2008 | Kenmore Elite 45986 Front Load Washer
Font loader washer water does'nt shut off
remove top replace fill valve left rear be sure not to remove the screens inside valve except to clean but be sure to reinstall or trash may get into valve and not allow proper shutoff
Oct 24, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore front loader washer model 11042822201 won't drain and spin
As I have not received a response, I'm assuming these hints have taken care of your problem. If you have any more troubles, feel free to drop me a note back.
Jun 30, 2008 | Kenmore Elite 45986 Front Load Washer
the drain pump on this unit has a clean out. There is probably debris in the pump. remove the lower front cabinets. There are three screws almost at floor level that hold it in place and open the drain pump it has a handle on the drain pump that you can twist to remove.
Nov 04, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
115 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
