Question about Bestec (ATX-250-12E) 250-Watt Power Supply
My compaq desktop will not power up and it has a blinking green light on the back of it were you plug in the cord
    Novelist:
  • 76 Answers
Hi ,
With what you have just told me it seems to be a hardware issue,as there is a light at the back panel of the computer tower it means that the computer is getting the power.The light that you see at the back is for the power supply ( SMPS) box and it seems that it is functioning ok.Generally in these kind of circumstances we have found the motherboard to be the culprit.I believe there is no light on the front panel and these are the steps if it is so .
Turn the computer off and then disconenct all the external devices and then open up the computer tower then once it is open look for the memory card's these are long green cards that looks like a scale and is around 4 inches long ,there can be one or more than one .So remove the memory cards and then turn the computer on and if you hear long beeping noise it means that the motherbard is fine but no sound at all indicates the motherboard to be bad and needs to be replaced or serviced ..Please do these steps and let me know...THANKYOU ...
hope this helps you .....all the best
Posted on May 15, 2010
I have two compaq desktop computers i usually switch from one to the other for personal preference. Anyways i plugged my 2nd computer in and it worked fine, when i go to change the cords (power supply,...
Your computer is not POSTing, the best solution is to get warranty support on it.
The other option is to take it to a computer technician and he/she will diagnose the faulty component. They have access to many computer components and can determine the fault by a process of elimination.
damnor01
Jan 30, 2011 | HP Compaq Presario SR1230NX (PJ518AA) PC...
I unplug my pc and put it back after a few hrs then plug it back but there was only a blinking green light it does not turn on or off i tried everything like plug off and plug it on still the same i tried...
check the back of the power supply and make sure the voltage selector is set properly. try to switch it back and forth to the correct voltage. Swap the power cord with the monitor. Switch it on again. If the blinking green still comes up, press and hold the power button for about 5 seconds and see how it goes. If this does not work, disconnect all removable items and cables inside the system including power connection and connect them all and test the system again. Hope this helps
Nov 13, 2010 | HP Compaq Presario SR1230NX (PJ518AA) PC...
Hi, when i plug in the power cord from the wall to the desktop the power button does not turn it on but the little green light in the back of the unit is blinking? how to fix this?
Hi, the green light I believe is just your networking socket. The fact nothing happens when you try turning on your PC could be serious. You will to take your PC in for repair, as this is not something I can diagnose without seeing the PC. Sorry this is not a straight forward answere.
Jul 22, 2010 | Compaq Presario SR1050NX (DW257A) PC...
I try to turn on my computer but nothing happens. i looked at it an in the back the green led light is blinking when I have the power cord plugged in so do I have to buy a new power cord?
No. It is likely that your problem is more serious than that. This generally means that an interior component has failed.
If the machine is no longer under warranty, then find a reputable shop to look at your Presario.
Apr 24, 2010 | HP Compaq Presario SR2150NX PC Desktop
HP Compaq Presario SR1820NX will not turn on
i worked for hp and compaq it is well known issue to reslove this issue
1#turn off the computer and uplug the power cable from the computer and then hold the power button for 20 second then turn on the computer and the momment you back to desktop screen
go to download driver from hp site and here is the web site http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=pv-43507-1&lc=en&dlc=en&cc=ca&lang=en&os=228&product=1841849 and restart the computer .
Apr 15, 2009 | HP Compaq Presario SR1820NX (ER919AA) PC...
Will not pwer up. Greenlight blinking on back
The green blinking light can mean there is a problem with the power supply.
Try unplugging the computer from the wall, and turning on the pc on switch.
After a few minutes, try plugging it back in.
If that does not start things up, you may have a bad power supply.
If the power supply is bad, these models take standard power supplies. You should get an ATX 350Watt or higher power supply.
They are easy to replace, unplug the power from the wall, disconnect all the cables inside the computer. Unscrew the four phillips screws outside the back of the computer where the power supply is attached to the case.
Remove and replace.
If you don't feel comfortable with this, a good local computer shop can help you out.
Apr 13, 2009 | HP Compaq Presario SR1330NX (PP161AA) PC...
Compaq Desktop won't start after city wide power failure
Dear! format your system and istall drivers after individual reboot ..
by khalid (Kashmir)..
E-mail:-shahworld_2998@yahoo.co.in
May 05, 2008 | Compaq Presario S6300NX PC Desktop
I have a Compaq SR 1000 desktop set and I can't get the power to go on. When I plug the unit in a green light in the back keeps blinking. When I disconnect, hold in the power button the blinking stops, but...
Hello shapscomp
The blinking green light is likely your Ethernet card's LED. Is the blinking light located near your Ethernet (network) cable?
It sounds as though your power supply has failed. You may be able to purchase a replacement power supply for it.
Would you like some assistance in deterimining if that is the case?
Thank you
BJ
Apr 05, 2008 | Computers & Internet
Bestec (ATX-250-12E) 250-Watt Power Supply Logo
246 people viewed this question
Top Bestec Computers & Internet Experts
Lawrence Oravetz
JonSnell Electronic
JonSnell Electronic
De ice
De ice
Are you a Bestec Computer and Internet Expert? Answer questions, earn points and help others
