Question about GE (PSS26MSRSS) Side by Side Refrigerator
My GE side by side (GSS25JFMD WW) is not cooling. It's blowing cool air, but not cold .
  • GE Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 06, 2010
Hotpoint HSS25GFPA WW Freezer not cooling
check for ice build up on evap coils ,,, bad efrost cycle
Oct 05, 2014 | GE Refrigerators
Just replaced mother board on Ge gsl25jfpabs to fix problem with cooling and running constantly. still not cooling but we can hear motor and fan running. no cold air blowing into fridge section. wh
NEED TO MAKE SURE FRESH FOOD DOOR IS HITTING LIGHT SWITCH TO OFF POSITION IF NOT NEED TO ADJUST DOOR UP ASSUMING THE FREEZER SIDE IS WORKING OK
If you need further help, I’m available over the phone at https://www.6ya.com/expert/elite_9cbd96cb0728162b
Jan 17, 2013 | GE GSL25JFPBS Side by Side Refrigerator
I have a GE profile side by side and the freezer works fine but there is warm air that is blowing into the fridge part.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Sep 02, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
My GE fridge GSS25JFMD: freezer seems to be working but the fridge compartment is worm, I don't see any cold air flow from the top. Condesor on thr back is very hot and cooling fan doesn't turn on. I...
The control to the fan comes from the main unit and it runs all the time,. So check out the wiring for the voltage to appear on the fan terminals , there can be break of contact in joints of wire connectors.
Once the fan works the fault must clear off with the cold air blowing.
Sep 19, 2010 | GE Refrigerators
Freezer woorking ok fridge not cold model GSS20DBPC WW
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 23, 2010 | GE GSS20DBPWW / GSS20DBPCC Side by Side...
Ge Side by Side Refrigerator model GSS22JFMC ww Is not cooling not frezzing properly and not making ice. The motor is still running ok
heatman101
rggasd
Jul 05, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer not worknig.
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jun 05, 2010 | GE GSS25JFM Side by Side Refrigerator
My frig is running but not cooling - frig is 50 degrees,freezer 40 degrees, cleaned the coils,etc GE side by side coils in bottom if frig side feel cool, "box" between freezer and frig side is not blowing...
I can help you diagnose the problems with your GE. Several things can cause these symptoms. All you need is a voltage meter patience and a want to, to repair and do it better than a paid technician. In most cases with the PSS26MSRSS the defrost heater is the cause for this. Look into rear of your freezer and back wall. Is Ice or frost building on rear wall? If yes unplug and prepair to remove contents in freezer compartment. Remove rear panel in freezer and use hair dryer to defrost ice until the defrost heater is visible. BRB , Sea Breeze
Jan 23, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Model is GSS25WGMD WW No cooling in freezer or refrigerator
look for ice or forst build up on the rear wall of freezer compartment, sounds like you may have a defrost problem. this will affect temps in freezer and refrig. the most common def problems for GE are bad defrost heaters. these are model specific and fairly easy to replace your self. i got this part number form Sears.com WR51X10055 good luck peyton
Jan 19, 2009 | GE GSH22JFR Side by Side Refrigerator
GE TFX20JR BK WW side by side won't cool or freeze
First point: The entire fridge is cooled by the freezer section. A fan blows air across to the food section.
2) Every 8 hours or so, a timer shuts off the compressor cycle, and starts up a heater to defrost the freezer coils. If the heater(s) are burnt out, or if the safety thermostat (to prevent overheating) is open, then you will have no defrost. The coils will frost up and eventually prevent airflow to the food section. Milk goes sour.
3) In rare circumstances, the timer itself can stall. This cause the same symptoms as above, but this is not as common as the other 2 causes of No Defrost.
Sequence: Check heater continuity. Check safety thermostat continuity while cold. Check defrost timer operation.
Hope this helps. I am a journeyman with 39 years exp. Happy New Year.
Dec 24, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
GE (PSS26MSRSS) Side by Side Refrigerator Logo
687 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
