Question about Casio Office Equipment & Supplies
I am using FX-83GT calculator when I divide a few numbers it gives the answers in fractions. I need them in decimals. eg. 40/24 it gives me 5/3 but I need to see the answer 1.6666
  • 3 Answers
Try using the S<>D(above the orange DEL button) button after you've obtained your result..
Posted on Aug 22, 2010
  • mmm_gardenin Dec 04, 2010
    how do you default it to show a decimal first time?
While using Casio fx-300ES , I am unable to get answers in decimals. For eg. 3/10...should give 0.3, but the answer is again displayed as 3/10. any way to solve this issue?
The calculator has two Input/Output modes: MathIO and LineIO.
LineIO
LineIO is the old way of entering numbers in calculators and results are always displayed as decimal numbers. Some calculators have a fraction feature and would convert a fraction to a decimal number and back.
MathIO
In MathIO you enter expressions as you would by hand or as you see them written in textbooks.
In this mode, results are by default displayed as fraction or fractions/ radicals.
Conversion
To convert the fraction/radical to decimals you just press the [SD] key. If you press again you cycle through all the available display formats.
So you can (if you want) use the MathIO to manipulate expressions and convert only the last result to decimal. By the way, fractions and radicals are generally more accurate than their decimal representations.
SetUP
If however seeing fractions and radicals is too painful, just set the LineIO as your default mode. To do so press [SHIFT][MODE] to open (SETUP), then select [2:LineIO]
Feb 17, 2011 | Casio fx-300ES Calculator
1 divided 5 =
Yeah? What do you want with it?Do we have to play good cop, bad cop to make you reveal what you want?
Could be just a fraction 1/5 or a decimal number 0.2
If you calculator gives you a fraction use the [S<->D] to convert it to a decimal number. If it gives you a decimal number, you can convert it to a fraction by pressing the [S<->D key.
Feb 14, 2010 | Casio FX-115ES Scientific Calculator
When i divide it gives me a fraction answer. eg, 4/3 = 4/3 instead of 1.33
You are not specifying the brand and model number of your calculator and that makes things more difficult for me. On the Casio calculators (FX-300ES, FX-115ES, FX-991ES) there is key labeled [S to D] which toggles between Fractions/Radicals To Decimals.
On other calculators (Sharp), the key may be labeled F To E.
You should look for a key that has two letters with a two-sided arrow linking the letters.
Why I even try to answer a question that lacks basic information and give the opportunity to the asker to shoot me dead is beyond me.
Anyway, I hope it helps.
Dec 10, 2009 | Casio Office Equipment & Supplies
I ask a dividing question like: 8 divided by 10, and it gives it in a fraction how to I cheange a setting so it gives the answer in a decimal?
If a number is displayed as a fraction or a radical (square root or other roots) you change it into a decimal number by pressing the [S<=>D] key, just above the red [DEL] key.
If you do not care for fractions or radicals, you configure your calculator to display only decimals. To do that you press [SHIFT][MODE][2:LineIO].
Warning: If you do that you will not be able to enter fractions or radicals in the natural (textbook display)
Another way to display a fraction or a radical as a decimal is to press [SHIFT][=] to get the result not the [=] alone.
Hope it helps.
Nov 11, 2009 | Casio FX-115ES Scientific Calculator
When I try to divide numbers that would leave a remainder like 1 divided by 6 which should give me an answer like 0.16666666666 instead all it says for an answer is 1/6. it does say in the manual to input...
To convert from fractions to decimals, and from decimals to fractions use the [S<-->D] key. If you want your decimal results to have a fixed number of decimal places press [SHIFT][SETUP][6:Fix]. Screen shows Fix 0~9. Enter the number of decimal places exemple 3.
Dans ce cas 1/6 is displayes ase 0.167.
Hope it helps.
Sep 23, 2009 | Casio FX-115ES Scientific Calculator
My calculator won't give me decimal numbers
Use the [S<->D] key to switch between the two.
Hope it helps.
Sep 21, 2009 | Casio FX-115ES Scientific Calculator
Problems with fractions on the Casio fx-115es
To convert fractions to decimals or decimals to fractions, you use the [S<->D] key. Each time you press the key the result is displayed in the other format.
Alternatively, If you multiply or divide two integer numbers put a decimal mark at the end of one of the numbers (any one). The result will be displayed in decimal format.
Hope it helps.
Jun 01, 2009 | Casio FX-115ES Scientific Calculator
Any way to make decimal answers the default? (casio fx-83ES)
you want a line output
Shift > Mode > 2:LineIO or on the graphics one its sometimes 10:LineO etc.
look for something with line in it
Steve :P
May 14, 2009 | Casio FX-115ES Scientific Calculator
When I divide answers are always given in Fractions. Can I change it to come out in decimals?
To change from Fraction display to Decimal display on the Casio fx-300ES (and probably other calculators)
1) Press the "SHIFT" button
2) Press the "MODE/SETUP" button
3) Press the "2" button
This Changes it to LINEIO (Decimal)
Doing all of the above but pressing the "1" button instead of the "2" puts it back into MATHIO mode (Fraction)
Hope this Helps
(SHIFT)(MODE/SETUP)(2) to change to decimal
Nov 07, 2008 | Casio fx-300ES Calculator
849 people viewed this question
Top Casio Office Equipment & Supplies Experts
k24674
Are you a Casio Office Equipment and Supply Expert? Answer questions, earn points and help others
