Question about Dell Wireless 2350 Router
Dell 2350 router configuration problem
I have a dell 2350 router that was working properly for some time. I use it with my Inspiron 6400 laptop. After installing different types of virus proectection several problems began to arise, not being able to access the internet via wireless being one. A so-called computer-savvy person thought he "fixed" my internet problem by I believe doing a system restore months ago, and we have not been able to access the wireless since. I tried re-installing the router and every time the compter goes through the installation process, it ends with unable to configure router (failure). Please help!! thanks
    President:
  • 1,851 Answers
Have you tried to use auto settings at ip adress, maigate and dns configuration at the laptop? Is it possible to browse the internet when the laptop is cable connected at the router?
Waiting clarification, don't hesitate to post.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on May 15, 2010
  • 2 more comments
  • bridgettsull May 15, 2010
    Thanks for your quick response. Yes, the ip is auto and I am able to connect directly to the internet but not by using my router, even if plug the cables through it. I have to connect directly from my computer to the modem. thanks
  • Stelios
    Stelios May 15, 2010
    In that case the problem is for sure at the router section, as you already mentioned. Have you tried to reset the router (or even better to restore at factory defaults?
    In case of a problem or clarification, don't hesitate to post me a reply.
    If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
    Thanks and regards
    Stelios
    direct FixYa link:http://www.fixya.com/users/technical114
    When I try to reinstall the router, the problem I get is that it is unable to configure, I am going to attempt your suggestion to restore my computer back to factory settings, I will let you know how this works. Thanks for all your help!
  • Stelios
    URGENT - URGENT Don't restore the computer at factory defaults. I asked you to restore THE ROUTER at factory defaults setting.
    Awaiting your results. In case of a problem or clarification, don't hesitate to post me a reply.
    Thanks and regards
    Stelios
Dell Inspiron 6400 will not power up. The Battrey light flashes four orange and one green all the time. Have tried the power lead from my other Dell but the same sequence happens. The battrey has been us...
Just to understand your problem your laptop is working properly when plugged directly to the power cord but not when running only on battery? Then it sounds like you need to replace the battery.
thank you,
Lee
Jul 11, 2011 | Dell Inspiron 6400 Notebook
My DELL Inspiron 6400 cannot connect to my DSL Internet, what should I install to make my Dell Internet connection Work... Further the Memory Card Reader also does not work, what else is missing?
You wrote:
"My DELL Inspiron 6400 cannot connect to my DSL Internet, what should I install to make my Dell Internet connection Work... Further the Memory Card Reader also does not work, what else is missing?"
YOu can try system restore, think of the possible time where your computer was working properly without hussel then that will be your restoration point, or better try to back up your files and do tjhe factory image . Since this is a DELL computer pressing CTRL+F11 will do the factory default setting of your system that is why it's highly recomended to back-up files first before doing this.
Jul 08, 2010 | Dell Inspiron 6400 Notebook
DELL LAPTOP INSPIRON 6400 MY LAPTOP BATTERY IS SHOWING STATUS ( UNKNOWN ) ON WINDOWS & ON BIOS IT SAYSS BATTERY NOT INSTALLED
Here are my recommendations for this issue:
1. Reseat the battery.
2. Remove All External Components
3. Check the battery connectors on the battery and the system. Examine the connector on the battery and the system. Make sure that there is no physical damage and that it is clear of debris.
4. Remove All External Components
5. Try a known-good battery in the system, if available.
Jun 09, 2009 | Dell Inspiron 6400 Notebook
Dell Inspiron 6400 PC Notebook-touchpad working erratically,help!
i cant figure out how to turn on the croll for my inspiron 6400 touch pad
Mar 05, 2009 | Dell Inspiron 6400 Notebook
Wireless internet dell inspiron 6400
Things you can do to try and improve the connectivity are:
1. Update the system BIOS to the latest version
2. Update the wireless driver to the latest version (Both are available at support.dell.com)
3. Try a different channel for wireless on your router (Most default to channel 6, so try 1 or 11)
Jan 24, 2009 | Dell Inspiron 6400 Notebook
Microphone doesn't work
My microphone in Dell inspiron 6400 doesn't work
Sep 25, 2008 | Dell Inspiron 6400 Notebook
Installing dell wireless 2350 router gets configuration failure
if its not broke dont replace it... you will need to contact your ISP for propper settings for that router. if that fails then the router needs upgrading.
Nov 11, 2007 | Dell Wireless 2350 Router
Open Questions:
Losing data is a disaster. Never let that happen Use Cloud Backup'Call +1888784-9316 Cloud storage services are great for sharing files with friends and families, keeping documents in sync between all your devices, and so much more. Free cloud storage is even better! Several backup services offer free online backup plans. DataAlign is known for having the finest free cloud data backup software in the world! Not just being simple and automatic it can be customized to a large extent and not to forget the scheduling capabilities that allows it to run at any time of the day. With several years of experience in its kitty, DataAlign is the trusted innovators in free online backup solution. DataAlign is proud to be known as a market leader in providing Server Cloud Backup Solution based storage and individuals is our primary motto. Our innovative platform has been designed while keeping you in mind. To provide Cloud Backup For Small Business optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly. Unlike other companies, there are no catch with DataAlign free cloud backup solution. With the kind of experience, you get with DataAlign, we strongly believe that you will eventually upgrade your account to a bigger one. And that makes us give awa Online Backup Pricing accounts as a free version with no strings attached. So drop your worries and and setup your free cloud data backup account with DataAlign. Just to clarify we will not ask for your credit card details upfront when you sign up for a free account. Keep using your free account as long as you need it. DataAlign has been designed with you in mind. You wouldn't require any technical skiil or IT degree to use it. Simply, upload your data and the technology will do the rest, enabling you to focus on what really matters; your business. Our dedicated support is readily available to answer any questions that you may have.
May 28, 2018 | The Computers & Internet
See all Dell Wireless 2350 Router Questions
Dell Wireless 2350 Router Logo
87 people viewed this question
Alun Cox
