Question about Vacuums
Regina 12amp bagless vacuum cleaner
I was using it and it suddenly shut off. I checked the outlet and its fine. i flick the switch and nothing. Maybe it was full? so i emptied it. it was warm, so i let it cool down. is there a reset button?
Please Help,
Ed Greenfield
[email protected]
  • 1 more comment
  • edi4g Apr 02, 2008
    Thank you for your reply. But that's part of the problem - we can't find the manual. I have tried to on line, with no success. Where might the fuse be located? fyi- i am able to turn on the vacuum for short periods, but within a 10-15 minutes it shuts itself off, any ideas?
    Thanks again,
    Ed Greenfield
    [email protected]
  • edi4g Apr 04, 2008
    Techzen, What have I got to lose, let me try that and i will get back to you. Thanks for all your help.
    Ed Greenfield
    [email protected]
  • nolady Nov 26, 2008
    vacuun is used for about 15-20 mins. Than shuts off. Wait for a while and does the same thing. Motor does not seem hot. Is there a reset for the vacuum?
    Problem Solver:
  • 12 Answers
I don't know about this particular model, but if you did opperate a full vacuum cleaner until it got hot and went off on it's own, this means you might have overloaded the motor and blown the protection fuse. in this case, you might have to change it. refer to the owner's manual about overload protection.
Posted on Mar 31, 2008
  • Anonymous Apr 03, 2008
    btw, your fyi was really helpful, if you can turn the vacuum on, this totally eliminates the fuse as the cause of the problem.
    check the suction power by placing your hand to block the hose, normally it should pull on your hand, if its weak this means that something is blocking the air way.
    try this:
    - check if there is a removable filter that you can take out and clean.
    - check the air way for any thing that might be stuck and blocking it. check the hose, brushes, and remove any thing you find stuck in them.
    - also touch the vacuum body right after it goes off on its own and see if it is up normally hot.
    i hope this does it for you, post again and tell me what happens.
    good luck.
SOURCE:
I was in the middle of vacuuming and all of a sudden the vacuum just stopped working. I looked, thought the bag was full so I changed it out and nothing it will not turn back on again.
If the bag was really full it could have restricted the airflow and caused it to get too hot and shut off. If it does not have a mechanical reset button it will come back on after it cools down. The filters may need replaced too.
Feb 20, 2017 | Kenmore Vacuums
I have a Hoover wind tunnel that suddenly stopped working when the cannister got full. Once emptied still would not start. Anything to fix this? Does it have an automatic shut off when full?
If the airflow is restricted the motor will overheat. Most vacuums have a thermal heat sensor built into the motor which will shut the motor off until it cools down.
Jan 05, 2017 | Hoover Vacuums
My dirt devil breeze turbo shut off while I was vacuuming. I've checked 3 outlets and nothing happened
It may have overheated from a restriction or clog. If so it will come back on after it cools down.
Mar 01, 2015 | Dirt Devil Breeze Turbo Upright Vacuum
My vacuum cleaner will not stay on
It may need a new switch. If it runs for a while and shuts off it maybe overheating and need new filters.
Feb 25, 2015 | Dyson DC14 All floors Bagless Upright...
Reset switch
There is no reset button it as a Thermal Cut Off
This vacuum cleaner has a special thermostat that protects the cleaner in case of motor overheating. If the cleaner suddenly
shuts off, turn the switch off and unplug the cleaner.
Check the cleaner for a possible source of overheating such as a blocked hose or clogged filters. If these conditions are found, fix
them and wait at least 30 minutes before attempting to use the cleaner. After the 30-minute period, plug the cleaner back in and
turn on the switch. If the cleaner still does not run, then call 1-800-282-2886 for customer assistance
this link below is the manual
http://dl.owneriq.net/b/b7517422-db37-404e-9da2-d898185942e5.pdf
Sep 05, 2013 | Eureka 4700A Maxima Bagless Upright Vacuum
I have a Kenmore Elegance Vacuum with Dirt Sensor, Model # 116.30750400C, Serial number M41901532. When vacuuming the carpet the power head will work for 3-6 mins then automatically shut off, power is...
It is an electrical problem in the handle, if you can or know somebody that has any fix it ability it can be fixed in about ten minutes. Oh, and Sears SUCKS!!
Oct 17, 2010 | Kenmore 34612 Bagged Upright Vacuum
Vacuums Logo
492 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
