Question about YouTube Videos
Fix electric window how do you remove rear panel in 2001 cadalic
  • 503 Answers
Hi, if window will not go up ckeck window motor to see if it will go down if it goes down but not up the problem is in the drivers door master switch On a 2001 Safari van. You do not have to remove the whole door panel.
Remove the handle (two torx head screws) and remove a screw by the 2"speaker on the right (phillips head). The difficult part is inserting the screws, holding the motor, from the back. I used a very fine thread that i passed through the motor and motor bracket. I pulled the screw through the hole. Took a long time. To prove the motor or the switch. Use a volt meter and see if there is voltage present at the motor. If there is and the motor wont turn. Replace it. Hope this helps.
Posted on May 16, 2010
Right passenger rear window on my 1999 Cadalic DeVille will go down but not back up. Any suggestions?
Do you know how to test automotive electrical circuits with a DVOM - digital volt ohm meter , pull the inside door panel check for B+ voltage at the motor and switch . Power at up an down switch an motor , the window regulator is bad . Automotive Electric Window and Switch Troubleshooting Repair Guide
Feb 09, 2017 | Cars & Trucks
Where is flasher location on 2004 cadallic deville and how do you get to it
Your vehicle has a turn signal/hazard flasher module.
Remove the left knee bolster. Refer to Instrument Panel Insulator Panel Replacement - Left Side in Instrument Panel, Gages, and Console.
showgif.do?image=520017
Remove the turn/hazard flasher module (1). Disconnect the electrical connector.
yicfxererercshudbsrererexehjpaiiiiiiiiuharerereretehzdai4iiiiiiubasebererererdcai8iiiiiiujcsobfrerererccam8iiiiiiiicygbfxererercsek8ciiiiiiii6ebf5ererermsfkmcliiiiiii4ebj4ererererf0iclyiiiiii4kji4everererfwicbyiiiiiiigliyexerererfxetx69p8a7tyq7crxc80aaaaasuvork5cyii=
Jan 31, 2016 | 2004 Cadillac Deville
Fix windows they wont go down any more,, fuses look ok
There can be several reasons. When you say you "fixed" the windows, it makes me wonder what was wrong with them before you started. The part inside the door is usually a window regulator. It has teeth to be moved by the gear on the electric window motor. The position of the regulator teeth is suppose to match the position of the window. If you imagine setting the window 1/2 open, then that is as far as the window will rise when the electric window motor cranks. The electric motor gear will only travel so many turns for each cycle of the motor switch.
Mixing motors on the wrong side of the car is something else that can go wrong if you change W motors. The W motors are not the same from front to front or rear to rear. They are often compatible diagonally (right front to left rear) (left front to right rear).
Finally, you can have a switch box for the auto up/auto down feature inside the door panels. You need to check for power at the W motor and then backtrack.
Oct 23, 2014 | 2001 Ford Ka
I need help with replacing the driver side window in a 2003 ford f-150,four door super crew cab truck.
Removal & Installation
Motor - Front Door
  1. Before servicing the vehicle, refer to the Precautions section.
  2. Remove the window control switch
  3. Remove the front door trim panel and watershield.
  4. Tape the window in the full UP position.
  5. Disconnect the window motor electrical connector.
    NOTE Support the window motor while removing the window motor retaining screws.
  6. Remove the window motor bolts and remove the motor.
  7. To install, reverse the removal procedure.
Rear Door
  2. Remove the window control switch.
  3. Remove the rear door trim panel and the rear door trim watershield.
  4. Remove the door speakers.
  5. Tape the window glass in the full UP position.
  6. Disconnect the window regulator electric drive.
  7. Position the connector for the window regulator electric drive inside of the door.
  8. Remove the bolts.
  9. Separate the window regulator electric drive from the rear door window regulator.
  10. Remove the window regulator electric drive from the door.
  11. To install, reverse the removal procedure.
Motor & Regulator
Fig. Front Door Trim Panel
Fig. Rear Door Trim Panel-Crew Cab
Regulator - Power Windows
Fig. Window regulator arm nuts
Fig. Window regulator bolts
  3. Remove the door trim panel.
  4. Remove the door speaker.
  5. Remove the door watershield.
    NOTE Do not remove the window glass from the door.
  6. Remove the window glass from the window regulator.
  7. Tape the window glass in the full UP position.
  8. Disconnect the window motor electrical connector (power windows only).
  9. Loosen the window regulator arm nuts and pull the arm from the mounting position.
  10. Loosen the bolts and remove the window regulator.
Hope helped with this. Good luck.
Nov 16, 2009 | 2003 Ford F150 Regular Cab
My 2001 Town and Country's rear windshield wiper motor is kaput. How do I change it without destroying the rear tailgate paneling
Pretty straight forward.....here are the steps:
Please don't forget to rate--
Rear Window Wiper Motor Removal & Installation To Remove:
  1. Disconnect and isolate the negative battery cable.
  2. Remove the rear wiper arm.
  3. Open the liftgate.
  4. Perform the following to remove the liftgate trim panel.
    • If equipped, remove the lift motor link
    • Remove the upper frame molding
    • Remove assist handle screws
    • Disengage the hidden clips around perimeter of liftgate trim
    • Disconnect the electrical connectors.
  5. Disconnect the wire connector from the wiper motor.
  6. Remove the wiper motor mounting screws.
  7. Remove the wiper motor.
To Install:
  1. Position the wiper motor in the liftgate.
  2. Install the wiper motor mounting screws.
  3. Connect the wiring connector.
  4. Install the liftgate trim panel.
  5. Close the liftgate.
Jul 24, 2009 | 2001 Chrysler Town & Country
Replace driver side mirror on 2001 Nissan Quest
SECTION 501-09: Rear View Mirrors 2001 Villager Workshop Manual REMOVAL AND INSTALLATION Mirror —Exterior Rear View Removal
  1. Remove the front door trim panel. For additional information, refer to Section 501-05 .
  1. Remove the upper speaker.
    1. Disconnect the electrical connector.
    1. Remove the bolts.
    1. Remove the speaker.
  1. Position the watershield aside.
  1. Remove the exterior rear view mirror access panel.
  1. Disconnect the exterior rear view mirror electrical connectors.
    • Release the wiring harness locator.
  1. Remove the exterior rear view mirror.
    • Remove the bolts.
    • Feed the wiring harness through the door opening.
Mar 31, 2009 | 2001 Nissan Quest
Drivers door panel removal
The book says 1. remove power accesory switch panel by using suitable flat blade tool at front. 2. Disconnet electrical connections.
3. pry door handle plug by using small flat bladed tool
4.remove door trim handle mounting screws
5. remove door trim panel from retainers.Start at rear bottom corner and pry outward.
6. remove door panel.
KD does make a tool that will properly pry the door panel away from reainers. KD 3705 You might get by with a screwdriver.
One other thing you may need to have the window down to get the panel to come off. You will have to lift up on it once it is loose from the fastners.
Hope this helps you out.
Mar 23, 2009 | 2003 Chevrolet Malibu
Hey when i push the power botton for the rear window it doesn't go down,I checked the power button,and its good ! Can i replace the power motor in the rear window,and where is it located,i would like to...
  1. Raise and support the rear door window glass to the full up position.
  2. Remove the interior door handle.
  3. Remove the rear door speaker.
  4. Remove the water shield.
  5. Disconnect the rear door window regulator motor electrical connector.
  6. Remove the rear door window regulator rivets.
  7. Remove the rear door window regulator by sliding the regulator arms off of the window glass track.
  8. Installation is the reverse of the removal procedure, noting the following:
    • Cycle the door glass to make sure of engagement of the drive mechanism.
    • Remove the rear door window glass-to-regulator bolt or rivet.
    • Position the rear door window glass as necessary to access the rear door window glass-to-regulator rivet.
    • Secure the rear door window glass in the full UP position with tape.
    • Disconnect the window regulator motor electrical connector.
    • Remove the 2 window regulator nuts.
    • Remove the 3 window regulator motor bracket nuts.
    • Install the window regulator assembly. Tighten the 3 motor bracket nuts to 89 inch lbs. (10 Nm).
    • Install the 2 window regulator nuts. Tighten the nuts to 89 inch lbs. (10 Nm).
    • Connect the window regulator motor electrical connector.
    • Remove the tape securing the rear door window glass in the full UP position.
    • Position the rear door window glass as necessary to access the rear door window glass-to-regulator rivet. Tighten the bolt to 62 inch lbs. (7 Nm), or install a new rivet.
    • Install the window regulator motor
    • Remove the window regulator assembly.
Remove the window regulator motor
Feb 23, 2009 | 2001 Ford Explorer
Can't figure how to remove right rear door panel on 2001 Pontiac
These are bad about those Cable operated window devices .. If it is bad get on ebay and get one ordered its your best bet.. Just take a flat screwdriver and go around the bottom of the door panel and pop it loose and up the sides .. there might be a hidden screw or two in the middle around the handles.. good luck ..
Jan 25, 2009 | 2001 Pontiac Grand Am SE
Can't figure how to romove right rear door panel on 2001 Pontiac
rt rear door panel should be easy their may be screws in and around the trim panel check for little top covers take off and screws are underneath them. know when you pull the trim off its mounted by retainers so be careful pull at bottom and work your way to the top pull upward and then take off you should be able to see after that
YouTube Videos Logo
66 people viewed this question
Top YouTube Computers & Internet Experts
Rizwan Hanif
Level 1 Expert
Michael Terence...
Michael Terence...
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
