Question about Lexmark X2600 InkJet Printer
I refill black cartridge but still show no ink
  • 4,041 Answers
Hi There
It simpble you cant refill Lexmarks they made there inks so it will fuse so cant use the for refilling
Sorry .
Posted on May 16, 2010
giovarodrigu
  • 24 Answers
SOURCE: How to reset ink level warning when refilling?
EASY!!!!: push the cancel button by 6 seconds, this deactivate the ink level sensor.
Posted on Jul 25, 2009
SOURCE: I want to refill the ink cartridges (black 30 - colour31) myself....how do I do it?
thanks this is helpful
Posted on Aug 09, 2008
SOURCE: How to Override Ink Level Gauge When Using Refilled Cartridges
Amazing solution:
http://journal.drfaulken.com/trick-your-brother-inkjet-into-working-when-an-ink-cartridge-runs-dry/
Brother ink empty cyan yellow magenta..
Posted on Aug 13, 2008
  • 52 Answers
SOURCE: refilling lexmark cartridges x2500
There are a couple ways to trick it into accepting the cartridge. You can put a different one in, take it out and then put the filled one in. Or you can find a refill kit with instructions on what contacts to cover with tape and you have to do it 2 or 3 times to get the printer to reset. Sometimes you can shut off the computer and printer for 20 min and start it up again. Or you can get the sledge hammer and smash the stupid printer before it sucks up your life savings and vow never to buy from a company that profits from causing problems that they tell you can only be solved by using more of their overpriced solutions.
Posted on May 05, 2009
  • 123 Answers
SOURCE: My refilled ink cartridge still displays empty and will not print
The ink cartridge is most likely chipped & you would not be able to reset the ink level. Purchase an original or a good compatible cartridge. Refiling newer cartridges is not a good idea.
Posted on Oct 21, 2009
Just tried top new black cartridge in - seems ok, but scanner not working and shows red light over ink sign
Clean cartridge with sof tissue and alcohol and insert it again, carefully.
btw: are you sure ink is NEW and not a refill? Refills should be good too but sometimes they fail.
May 06, 2015 | Office Equipment & Supplies
Hello,after refilling ink cartridges HP21 and
Since HP’s ink technology is different from other manufacturers, they do not recommend to use refilled or remanufactured ink cartridges. Though the cost of genuine HP cartridges are bit expensive than the other cartridges, HP cartridges are manufactured in keeping mind the important factors print quality and customer satisfaction. Using the refilled cartridges may degrade the print quality and may damage the printer’s internal hardware.
I request you to use genuine HP Inkjet cartridges and verify the result.
:) Dr Tony
May 10, 2010 | Office Equipment & Supplies
Installed new hp black cartridge 56 ink but won't print
it shows if your using refill cartridge. & if you r using refill cartridge clear cartridge sensor with soft hands your problem would be resolved.
Jan 20, 2010 | HP PSC 1315 All-In-One InkJet Printer
Oct 21, 2009 | HP Photosmart C4180 All-In-One InkJet...
I refilled the ink with a refill kit
You can't reset the ink level on all Canon Pixma printers.You need to turn off the function on printer to show the ink level.On your printer this happen with push consistently buttons for black copy (for turn of level on black cartridge) and color copy (for turn of level in color cartridge). The printer
shows empty cartridges but it will printing.
Oct 07, 2009 | Canon PIXMA MP150 All-In-One InkJet...
How to refill hp 818 inkjet cartridge
i have injected 5 ml black ink in my 818 cartridge and inserted in my HP deskjetF2418 printer but it is not working and showing empty signal
Sep 30, 2009 | HP DeskJet F380 All-In-One Printer
Estimated ink levels are incorrect
The simple solution is to buy the HP cartridges. Often times,.. MOST times, aftermarket ink cartridges and refill kits are an inferior product. The difference is not always noticeable right away, but almost always rears it's head in the end. This is usually due to the ink being of a different viscosity than the original ink. Which leads to sloppy prints, sensor errors, leaky or dead jets.
Personally I recommend everyone buy Laser printers. With prices where they are these days, there is no reason for anyone to buy an inkjet printer. Lasers will cost more up front, but are much cheaper per page and generally longer lasting.
Feb 15, 2009 | HP PhotoSmart C4280 Laser Printer
Dell 926 injection refill kit didnt work
The ink your purchased is likely a cheap watered down version of what your printer is meant to take. You may notice that the ink smears when you rub the page directly after printing. Why you chose to use the blue and red ink to make black blows my mind. These refill kits are insanely cheap and buying the black could not have been much more. Not using black ink in the black cartridge would explain why your print is faded. Also, there is no way to reset the ink levels on this type of cartridge. As long as the printer still prints, just ignore the ink level indicator and print until the ink runs dry. I recommend Cartridge World for ink refills because they use high quality ink to manufacturer specified volumes while still saving you money.
Feb 05, 2009 | Dell 926 All-In-One InkJet Printer
Refilling ink cartridges
hp74a.jpg HP #74 Cartridge Refill Instructions
Black cartridge
Instructions
1. Put the cartridge on some paper towels in an area where you can tolerate a spill.
3. Fill the syringe with 20ml. of black ink.
4. Very S-L-O-W-L-Y inject ink into any hole (they all go to the same sponge, HP just used the same color mold for the black ink cartridges).
5. When finished, replace the top label or leave it off (it will make no difference in the printing).
6. Replace the cartridge and run 1 - 3 cleaning cycles as per printer instructions.
Or print the following pages:
http://www.refillinstructions.com/black.htm for Black
For best results, leave cartridge in printer for 8 hours after refilling so the ink can saturate the entire sponge.
A Refill Kit should include Ink plus the following:
One 30cc Syringe
Jan 14, 2008 | Office Equipment & Supplies
Lexmark X2600 InkJet Printer Logo
234 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
