Question about Plumbing
Dripping overflow from toilet cistern.
Hello, My toilet cistern overflow is dripping - the water in the cistern fills up just above the overflow level. I think probably the valve needs replacing as I have just read about this. It is a very old cistern. Is there a diagram so I can be really clear what to do as I do not want to use a plumber due to their high charges. Thank you, Carol.
  • Randy Marshall May 16, 2010
    Is there any way to adjust float in tank to shut water off befor eit gets to overflow pipe.?
  • Randy Marshall May 18, 2010
    did you Check the float for adjustment?
  • 34 Answers
There is an adjustment screw ontop of the fill valve assembly. Tighten this down and the water level should stop at a lower level unless the internal mechanism has crusted up.
Posted on Jun 08, 2010
Why is gas dripping/runnng out bottom overflow line of carb?
Could be one of the carb floats is stuck or the rollover caused it to come off its mounting position. As fuel enters the carb, the float rises with the fuel level until it reaches a position that shuts off any more fuel entering the float chamber and prevents an overflow. Fuel level drops, float drops and fuel flows again. Basically like the cistern in a toilet.
Feb 11, 2016 | ATVs
Toilet has dripping sound - NOT the flapper
As long as the chain on the flapper is slack after it flushes it will seal.
then put some weight on the flapper just to experiment to ensure a tight seal.
if you can see the drain elbow under the toilet in the basement with the ceiling exposing the drain that would be the guaranteed way to know for sure. I am assuming you have done that.
Last but not least the small line on the fill valve that goes into the overflow could be weeping from the fill valve as this is the bowl wash.. So it will drip or sometimes it runs a bit . If this helps
Jul 31, 2013 | Toto Home
I can hear a dripping of water but the washer is fine. The water tap is turned down low, I'm a female and not familiar with the makings of a toilet cistern how does the centre flushing mechanism come out....
Anytime that you have water dripping between flush cycles, it is caused by water leaking through the flush valve. Without being able to look at it I would recommend placing the entire flush valve assembly (flush ball/plunger and the valve seat (washer). The part is not expensive, although the labor may be. You could replace the flush ball or plunger (whichever type it is) yourself and that may correct the problem.
Nov 26, 2010 | Toto Aquia II Dual Flush Toilet
Even after filling up, water from the cistern keep...
That is the cistern overflow running.You need to adjust the fill level in the cistern by adjusting the plastic screw on the ballfloat or adjust the height of the float if its the silent fill tpe
May 20, 2010 | Home
Toilet system will not completely stop dripping, resulting in constant drip from overflow. How do I stop it?
Is the drip comming from the small fill tube going into the overflow? If so you may need to raise it a little. The nost common leak is from the flapper or seal. On rare occasioms the flush valve itself has a defect that will cause it to leak. Take a close look at the problem and Im sure you will find it. I hope this helps.
May 14, 2010 | Home
Constantantly dripping after tank is full
WHAT IS DRIPPING,?THE TANK ?OR IS STILL FILLING UP ?IT SOUNDS LIKE YOU NEED TO ADJUST THE WATER LEVEL TO THE PROPER 1.6 GALLONS PER FLUSH,WHICH IS MARKED ON THE INSIDE OF YOUR TANK SOMEWHERE,CAUSE WHAT YOUR HEARING IS THE WATER RUNNING DOWN THE OVERFLOW TUBE
Apr 09, 2010 | Toto Aquia II Dual Flush Toilet
The toilet cistern is filling up but the toilet pan is not getting enough water presure to empty
check that the water in the cistern is up to the mark etched on the inside
Do you have a close couple or a washdown [with pipe from cistern to pan]
Mar 04, 2010 | Home
My macerator turns on for a few seconds every couple of minutes, does anyone know why and how to cure it?
may be your overflow on your toilet cistern... check its shutting off the fill valve and not dripping into the overflow.
Dec 30, 2009 | Saniflo & Saniplus& Macerator Pump
Water drips into overflow valve after flushing
The purpose of the "Overflow" tube is to fill the toilet bowl. It should drip for a while. If it is continuously dripping there could be dirt or deposits on the ball **** valve. Shut off the water and dissasemble to see if there is deposits or perhaps a torn diaphragm.
Oct 15, 2009 | Toto Promenade, 1.6 GPF, Elongated...
Modern toilet cisterns without overflowprovision
Most modern flush units have built in overflow protection, if the water level rises above the flush device then water runs into the toilet itself rather than out of the overflow pipe to the outside as in older toilets.
You could always check by taking the top off the cistern and push down the float device with your finger to see what happens!
hope this helps
Mar 30, 2009 | Facebook Social Network
Plumbing Logo
1,113 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
