Question about Onkyo TX-SR875 Receiver
Onkyo tx-sr875 no sound through hdmi.
Hi my tx-sr875 won't play any audio through hdmi devices. All my other devices are either connected through analog or component and work fine and I have the hdmi out connected to my Samsung plasma and projector via a hdmi splitter. But I am trying to connect my laptop via hdmi to the receiver. I can get the picture to work although it still says no signal on the receiver but cannot get audio whatsoever. I have tried everything in the menu including enabling hdmi audio but still no go.
Any help would be really appreciated as i have been searching online for months but haven't found any sollutions.
  • Official Brand Answer
  • 333 Answers
Hello, I suggest having your receiver serviced. Thank you, Onkyo USA
Posted on Apr 25, 2017
CremeStout
  • 115 Answers
SOURCE: Analog RCA input to HDMI output?
You have said the correct thing HDMI is digital therefore Analog will not pass.
You might have RCA audio outputs on your cable box so either send them into the TV from cable or into the AMP then use AMP volume to listen to TV audio (select unused input and remember it is for TV) the key is to remember that cable box will drive the initial vol so raise or lower cable vol then use AMP vol to obtain desired volume.
Posted on Dec 03, 2007
  • 151 Answers
SOURCE: No audio or video with HDMI connedction
AT THE START OF THE SET UP MENU CLICK ON IN/OUT ASSIGN.THEN MONITOR OUT APPERS,THEN HDMI NO,FLICK THIS TO ON.IFF YOU GET PICTURE AND NO SOUND GO TO THE HARDWARE SET UP AND DOWN TO HDMI AND SWITCH AUDIO OFF.
HOPE THIS HELPS.
Posted on Jun 02, 2008
SOURCE: Onkyo TX SR 702 AV Receiver
don't run you video from the projector to the reciever. just run it to the dvd and run the sound from the dvd through the reciever
SOURCE: Picture sound blackout (blink) when cable box/receiver HDMI used
Onkyo service told me, the second timethat I called them, that there is a known HDMI handshake issue with Motorola and Atlanta Scientific cable boxes. The only solution, and it was a solution, is to connect the box through the HDMI 1 port ONLY. All the other (2,3,4) result in blinking/dropping of signal. I did this, changed the cable/satelilte setting to HDMI 1 and all is well.
Posted on Apr 19, 2009
dunnbiker
  • 8546 Answers
SOURCE: I have an Onkyo TX-SR605 AV receiver that just
Goof information. Have you eliminated or proven the Onkyo as a cause by going direct to the projector? Try another Input and/or Output. It's best to know which component is broken and if it's limited to a specific subset of its function.
Settings are also indicated. Run through the video setup again. If it just stopped, what preceded it?
Posted on Nov 28, 2009
My Onkyo TX-SR506 plays cable and CD inputs to zone 2, but DVD won't play. Everything is connected according to the manual and I assigned zone 2 output correctly. What gives?
How are your cable and cd inputs hooked up? Analog connections? Alot of receivers cannot send an audio signal from hdmi inputs to zone 2.
Feb 06, 2013 | Onkyo TX-SR506 Receiver
Need universal remote code for ATT uverse remote for an avr Onkyo TX-SR875
hi! i do have a couple of codes here for your Onkyo 2006, 2219, 2220, 2318, 2410,5002, 5018, 5073, 5074, 5075, 5076, 5077, 5078, 5079, 5080, 5081, 5082, 5084, 5085, 5086, 5087, 5130, 5131, 5140 hope this helps! goodluck!
Mar 07, 2010 | Onkyo TX-SR875 Receiver
Sound won't play through Onkyo TX-SR605 when using HDMI
The chances are that you have selected an incorrect sound setting or not switched it on, for the HDMI you are using. With Onkyo receivers each connection will have it own settings for video and sound. You just need to look in the manual as to how to select the settings.
May 08, 2017 | Onkyo TX-SR605 Receiver
HDMI through - working, NO SOUND
try turning off HDMI Audio Out.
Jul 10, 2009 | Onkyo TX-SR875 Receiver
Onkyo TX-SR606 getting no sound from HDMI sources on speakers. I have a motorola cable box and a panasonic DMP BD-35K blueray player both attached to the SR606 via HDMI cables (HDMI3 and 1 respectively)...
Not sure if this is your fix, but I had what I thought was the same problem. I played with my Onkyo quite a bit ensuring the correct assignments for HDMI, audio and all that stuff. Turns out I neglected to make sure the output devices were properly assigned. Many devices aren't default to output sound over HDMI. I changed the audio out settings on the cable box to HDMI and suddenly the Onkyo worked great. I know, I'm an idiot for not checking that in the first place, but maybe someone out there is having the same trouble as well.
Feb 20, 2009 | Onkyo TX-SR606 Receiver
Onkyo TX-SR875
My mistake, HDMI in is not routed to any other output but HDMI out
Oct 04, 2008 | Onkyo TX-SR875 Receiver
Onkyo TX SR 875 HDMI switching
Hello, do the receiver inputs work with other HDMI sources? Thank you, Onkyo USA
Apr 07, 2017 | Onkyo TX-SR875 Receiver
Onkyo tx sr875 NO SOUND!!!
Check speaker cables are in the right way as ONKYO amps have the conections side by side not up and down like most amps,also if you are useing hdmi leads go to the hardware set up in the menu and turn off the audio out for hdmi.
hope this helps.
CABLE GUY.
Jul 01, 2008 | Onkyo TX-SR875 Receiver
HDMI Output with my Onkyo 875 Receiver
Hello, the TX-SR875 does not support up-converting from component or S-video to HDMI. Is the model number correct? You stated the receiver is "brand new". This model is from 2007. Thank you, Onkyo USA
Mar 23, 2017 | Onkyo TX-SR875 Receiver
No HDMI Output
My configuration:
ZONE 1 (living room)
DishNetwork Dual Tuner DVR Tuner 1 [S-Video out] -> [S-Video in] ONKYO TX-SR875 [HDMI out] -> [HDMI in] Sony KDS-60A3000 rear projection TV
ZONE 2 (living room)
DishNetwork Dual Tuner DVR Tuner 2 [Composite Video out] -> [Composite Video in] ONKYO TX-SR875 [Composite Video out] -> [Composite Video in] Samsung AQUOS LCD TV
Problem:
ONKYO receiver stops sending video signal to my ZONE 1 Sony TV through the HDMI connection. ZONE 2 may still receive video. (NOTE: the issue might be related to the upconverter circuitry?)
Symptom:
I couldn't see any video, but I could hear the Tuner 1 audio through my ONKYO. An important clue is that I couldn't see ONKYO's on-screen display menu on my TV when hitting the [Setup] button on my remote. But, I could see my TV's Sony-based menus and display options.
Solution:
1. Put all ZONES in Standby mode using the remote. Hit these buttons on remote: [Receiver], then [Standby]. [Receiver], [ZONE2], then [Standby], [Receiver], [ZONE3], then [Standby]. You should NOT see any lights on the ONKYO except maybe one red led near the power button.
2. Pull the power plug out of the back of the ONKYO, and leave unplugged for 20-30 seconds. Turning off any power center it is connected to isn't enough. You MUST unplug the power from the back of the ONKYO for 20-30 seconds.
3. Reconnect the power cord to the ONKYO.
4. Using the remote, set ZONE1 to a video source known to be working. If you don't see video, try leaving the power cord off for a longer period.
I know it sounds too simple to work, but that's what brought the video back for me the few times the video stopped displaying. Hope it works for you.
Jan 06, 2008 | Onkyo TX-SR875 Receiver
Open Questions:
See all Onkyo TX-SR875 Receiver Questions
Onkyo TX-SR875 Receiver Logo
260 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
